Anything wrong with a grub screw as a scotch lock like i usually use and Jonesy used?
Not that I know of. People have been using them successfully for decades. The only possible downside I can see would be if you were experimenting with offset keys or testing different several camshafts. In those cases you'd be better off with a washer and bolt but otherwise the scotch key is easy and very secure.
