186 Timing Marks
CK timing 71 timing cover
23 replies to this topic
#1 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 14 March 2015 - 08:22 PM
Hi Red Six Gurus,
Ok so today I get my timing light out to check the timing on my 9 month 71 CK engine prefix 186 and to my complete surprise it looks to be about 30 deg advanced at idle with vac off.
My questions are:
1) Is the longer mark on the timing cover 5 deg BTDC or 0 deg BTDC
1) Given that the cam is stock Im thinking the static timing should be around 10 deg BTDC
2) Total should be around 38 deg at approx 2500-3000RPM
3) How do you wind these engines over by hand to check for TDC
Cheers Brian
#2 S pack
  • 15,727 posts
Posted 14 March 2015 - 08:36 PM
Hi Brian
Dr Terry has advised that the longest mark on the 186 timing cover pad is 5 deg advanced (BTDC)
Remove the spark plugs and turn the engine over using the engine fan and always turn the engine fan clockwise.
Oldjohnno may be best to answer your other questions.
Dave.
#3 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 14 March 2015 - 08:57 PM
Hi Dave,
I saw that post and was unsure that GMH would break with "tradition" and make the long mark anything other than 0 deg, but I guess this is so.
Hopefully someone else can way in about the timing. I always thought, perhaps incorrectly that 38deg total made up of static plus advanced would do the job.
Anyway thanks for your input as always. Hopefully one day I get to meet you and buy you a beer.
Cheers Brian
#4 Dr Terry
Dr Terry
  • 3,325 posts
Posted 15 March 2015 - 07:55 AM
OK, this one always causes confusion & the CK XU1 engine is in a very 'grey' area.
AFAIK all red motors pre-HQ (i.e. 149, 179, 161 & 186 & also early LC 2250) have the long mark on the timing case as the actual initial timing position which in most cases is 5º BTDC.
From HQ on (173, 202 etc.) reverted to the more conventional long mark indicating 0º timing, marked in 2º increments up to 8º.
Which leaves the question, which timing case do CK XU1 engines use, because they are the only 186 built after HQ intro. All balancers pre-Blue motor are marked in the same position, so that bit is easily sorted.
BTW, to answer the OP's question, it sounds like the balancer's outer ring has slipped & the zero mark is no longer valid. A quick check for no. 1 TDC will tell the story.
Dr Terry
#5 S pack
  • 15,727 posts
Posted 15 March 2015 - 08:31 AM
Dr Terry
Hmmm, an interesting one to say the least Dr Terry.
As you pointed out the 138 (2250) engine also spanned HQ 202 & 173 release and if memory serves me all post HQ release 138 engines were fitted with the 2nd type timing cover.
A pic of your timing cover pad please Brian.
Dave.
#6 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 15 March 2015 - 08:38 AM
Im thinking the long mark is most likely 5deg BTDC as it is reasonable to assume that CK initial timing would be around 8-10deg due to the cam change.
Therefore it is logical to expect this to be easily set/measured, with long mark being 5deg this would give 9 deg advanced with the remaining two marks. Just a wild and crazy thought.
Dr Terry Im almost 100% sure your right about the balancer - this will be todays job to check.
Cheers Brian
No worries Dave will post pic
#7 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 15 March 2015 - 09:18 AM
Hi Dave,
Timing Pad
Attached File  TimingPad.jpg   203.83K   10 downloads
Pic is a little large - sorry
Cheers Brian
#8 S pack
  • 15,727 posts
Posted 15 March 2015 - 10:42 AM
Hey Brian
Yours is the 149, 161, 179, 186 & early 138 timing cover so the longest timing mark is 5 deg BTDC, the two marks to the left of the 5 deg mark are 8 and 10 deg BTDC.
Dave.
Edited by S pack, 15 March 2015 - 10:42 AM.
#9 Dr Terry
Dr Terry
  • 3,325 posts
Posted 15 March 2015 - 11:29 AM
Dave, given that the long mark is 5º BTDC & the marks are 2º apart, wouldn't the two marks to the left of the long mark be 7º & 9º ?
Also Brian's pic of his CK timing cover answers my query about which cover that engine uses. In that case, is the CK the only Red 6 post-HQ that uses the old style cover ?
Dr Terry
#10 S pack
  • 15,727 posts
Posted 15 March 2015 - 11:39 AM
The longest mark is also fatter than the short marks so it fills the space between 4 and 6 deg.
After 43 years I believe we may need more evidence to say conclusively which timing cover is correct for the CK 186
Dave.
Edited by S pack, 15 March 2015 - 11:39 AM.
#11 Dr Terry
Dr Terry
  • 3,325 posts
Posted 15 March 2015 - 11:54 AM
Dave.
Anyone with info on this ??
Dr Terry
#12 Dr Terry
Dr Terry
  • 3,325 posts
Posted 15 March 2015 - 12:01 PM
Dave.
The centreline to centreline distance is the same for all of those marks !! From the centre of the 5º mark to the 7º & the 9º is the same as back the the the 3º & the 1º etc.
The way I read the marks on that timing case from the top is:- -3º, -1º, 1º, 3º, , 7º & 9º, with the long one being the 5º. I believe that their intention was that the marks represent 2º either side of the 5º static mark.
Dr Terry
#13 N/A-PWR
  • 9,639 posts
Posted 15 March 2015 - 12:35 PM
Hello Brian, Dr Terry and Dave,
I measured the Harmonic Balancer, and is 6 inch in diametre,
so 6000 x 3.142 / 180 = 0.1047", which is close to 3mm per timing mark of 2°
#14 S pack
  • 15,727 posts
Posted 15 March 2015 - 12:41 PM
The short mark directly below and in line with the vertical leg of the R is supposed to be 0 deg, apparently.
According to Holdenpaedia.
Edited by S pack, 15 March 2015 - 12:51 PM.
#15 N/A-PWR
  • 9,639 posts
Posted 15 March 2015 - 01:18 PM
Well, if the long mark is 5°, then I see the equal spaces like this:-
Attached File  timing mark.jpg   245.92K   9 downloads
notice the graph showing an accurate equal spacing between each mark.
#16 N/A-PWR
  • 9,639 posts
Posted 15 March 2015 - 01:20 PM
6 to 6 1/2 squares per mark
#17 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 15 March 2015 - 01:41 PM
Hi Dave, Dr Terry & Dave,
Thanks for that - so Im clear the long mark is 5deg BTDC and the two marks to the left (advanced) side are 7 and 9 BTDC.
Dave (SPack) it would be nice to dig up a few more CK's and check what timing pad they have. (John Gong may have view on this)
Two more questions I have now confirmed that my balancer has slipped as the timing mark is a good bit off when the rotor lines up with the cyl 1 mark on the dizzy.
1) So where do I re-nick the balancer with the rotor in this position?
2) What is the initial timing for a CK engine?
Thanks for your help
Cheers Brian
#18 N/A-PWR
  • 9,639 posts
Posted 15 March 2015 - 01:53 PM
Hi Brian,
remove the #1 spark plug, and with a screw driver, you can feel the piston raising to the top,
and also as the rotor is aproaching the #1 mark in the dizzy,
stop when piston is top-most and mark the harmonic balancer at zero degrees.  :D
Cheers Brian
#19 Dr Terry
Dr Terry
  • 3,325 posts
Posted 15 March 2015 - 02:16 PM
Don't bother remarking the balancer, it will only move a bit more tomorrow.
They're cheap enough, just replace it.
From memory, all XU1s had an initial timing setting of 10º.
Dr Terry
#20 N/A-PWR
  • 9,639 posts
Posted 15 March 2015 - 02:41 PM
you will know if the timing mark is close,
by drawing a line from the timing mark towards the centre,
which will pass the start of the long elongated slot,
and the key-way centre line is about a 1/4 inch off that line:-
machined-step-supercharger-dampner-300x2
http://www.aussiespe...ner-300x225.jpg
I checked mine, and is the same.
Edited by NA-PWR, 15 March 2015 - 02:48 PM.
#21 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 15 March 2015 - 03:18 PM
Okay, so a new balancer it is, suggestions on where to get a period correct one?
Thanks for the help
Cheers Brian
#22 N/A-PWR
  • 9,639 posts
Posted 15 March 2015 - 03:32 PM
not sure about period correct,
but here is one:-
$T2eC16h,!)8E9s4l90eZBRjIuVOppw~~60_57.J
http://www.ebay.com....id=796862776204
#23 _Bomber Watson_
Posted 15 March 2015 - 03:40 PM
http://precisionintl...229&Category=54
Bit annoying, they used to have one that wasnt powerbond, was like $45....Now the standard one is over $100....
edit: One dave linked is the same, there bloody expensive now days, but sitting side by side you wouldnt pick the difference from the stock one.
Edited by Bomber Watson, 15 March 2015 - 03:42 PM.
#24 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 15 March 2015 - 04:50 PM
They look pretty good but farcking expensive, this little car is keeping me broke.
On a much brighter note I ran a comp test as well ranges from 150 to 153  :D
And my new 3568 timing light is a beast.
Cheers Brian
Also tagged with one or more of these keywords: CK, timing, 71 timing cover
