Replacing stud pattern?
90 replies to this topic
#26 _Bomber Watson_
Posted 13 April 2015 - 11:26 AM
Torana is 4.25", ford is 4.5" and hq is 4.75"
#27 _Liam_
_Liam_
Posted 13 April 2015 - 11:35 AM
Can you put Ford Hubs on H series Stubs?
#28 _Bomber Watson_
Posted 13 April 2015 - 11:53 AM
Not sure, don't think so, easily at least.
#29 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 13 April 2015 - 12:52 PM
Tried that, didn't end well.
#30 _Liam_
_Liam_
Posted 13 April 2015 - 01:28 PM
I guess Chev Pattern it is...
#31 Bigfella237
Posted 13 April 2015 - 04:48 PM
Was thinking of getting the axle drill to HQ but they are close to the edge.
As Bomber pointed out...
...the difference in the Pitch Circle Diameter of the ford vs HQ stud patterns is ¼" so dividing that in half to get the radius, a HQ stud would only end up just over 3mm further out than the ford stud, there's bugger all in it.
#32 _UC Kid_
_UC Kid_
Posted 13 April 2015 - 06:21 PM
Hey guys I iust measured my stud pattern and the front is 114mm and the back is 115. It currently has intercepted on it and fits really good. Is this commodore stud pattern?
#33 _Bomber Watson_
Posted 13 April 2015 - 06:25 PM
No you have ford pattern already....assuming you measured it correctly.
Have a google on how to measure a 5 stud hub.
#34 _UC Kid_
_UC Kid_
Posted 13 April 2015 - 07:09 PM
I did look up how to do it and that's what it is.. How can interceptors fit on ford stud??
#35 Ice
  • 15,200 posts
Posted 13 April 2015 - 07:13 PM
Ford have intercepters to
Put a pic of of one of your rims up
#36 _UC Kid_
_UC Kid_
Posted 13 April 2015 - 07:20 PM
It will be great if it's ford stud!!!! :) there are a lot of Fire dragways😆
#37 Ice
  • 15,200 posts
Posted 13 April 2015 - 07:21 PM
Need a close up
#38 _Bomber Watson_
Posted 13 April 2015 - 07:22 PM
Sorry mate, well done :D
Cant see shit in those picks, but guessing you have Ford rims. Are they 15" or 16"?
#39 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 13 April 2015 - 07:37 PM
They look like AU steel rims to me.
#40 Ice
  • 15,200 posts
Posted 13 April 2015 - 07:42 PM
Are they 14s or 15s inch rims take the size of the tyre
#41 _UC Kid_
_UC Kid_
Posted 13 April 2015 - 08:29 PM
A guy that looked at them said they are 15 chaser rims..?
#42 _Bomber Watson_
Posted 13 April 2015 - 08:41 PM
Chaser rims dont exist. The lad who looked at them is a wanker.
Just a nick name given to steel rims of that era.
Take a close up pick, theres some subtle differences between Holden and Ford. Hell Falcon ones had "ford" embossed on them if you look close enough.
#43 _UC Kid_
_UC Kid_
Posted 13 April 2015 - 08:43 PM
Hahahah hahahaha bomber 😂😂😂😂. I'll have a look at them tomorow and post a picture :)
#44 rexy
rexy
  • 3,739 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 13 April 2015 - 08:46 PM
Sort of. You use blank HQ discs drilled and studded to whatever pattern you like.
#45 TerrA LX
Posted 14 April 2015 - 08:24 AM
Yeah, they are actually called Interceptor rims :)
FWIW I think the rims look like Ford chasers too.
#46 _Lazarus_
_Lazarus_
Posted 15 April 2015 - 11:33 AM
CRS used to sell HQ rotors drilled to Ford pattern. Hot rodders like them.
As has been said, they are probably AU wheels. The front ones anyway.
AU and on are 35P offset, your UC is 32P. Another reason I like the Ford option.
114 is Commodore isn't it ? Commodore is 45P, not good. Either redrill some axles to Ford pattern or get Torana suspension mounts welded to a mid 70s Toyota Crown diff if you don't mind 3.9 gears. (I think other ratios are fairly readily available). It is a 4 pinion diff with big drums. Or you can go pre IFS Hilux. Same story.
#47 _Bomber Watson_
Posted 15 April 2015 - 11:36 AM
Commy is 120 ford is 114.3
#48 _UC Kid_
_UC Kid_
Posted 29 April 2015 - 07:09 PM
Hey guys here's some pictures.. Now I noticed it didn't say ford and instead it said Gm so I'm guessing that's General Motors? But is it possible that they put com rims on ford stud pattern cause there is a ford 9 inch in ...?
#49 _UC Kid_
_UC Kid_
Posted 29 April 2015 - 08:14 PM
Hey guys is there such a thing as dragway tims with com stud pattern !???
#50 UCSLE
UCSLE
  • 710 posts
  • Name:troy
  • Car:Goggomobil
Posted 29 April 2015 - 10:06 PM
no way it is a ford pattern . they are commy rims, but it looks like you 7/16 wheel studs which could make it a HQ pattern.
You need to measure the stud pattern more accurately .
