Replacing stud pattern?
#76
_LS1 Taxi_
Posted 01 May 2015 - 11:44 PM
MEASURE IT PROPERLY!!!!!!!!!
#77
Posted 02 May 2015 - 12:16 AM
Commodore PCD 5 x 120 mm Studs 12 mm x 1.5 mm
HQ PCD 5 x 4.75" Studs 7/16" UNF (The HQ was designed using imperial measurements hence the PCD of 4.75" which is approximately 120.65 mm.)
Using the table EunUCh posted the Commodore measures 70.535 mm and the HQ measures 70.916 mm between the studs. You will need to be able to measure with an accuracy of around 0.1 mm to determine the difference between the two.
If the measurement is around 70 mm then the studs may help determine between Commodore and HQ. If the studs are 12 mm x 1.5 mm then it is likely that it is Commodore pattern. If the studs are 7/16" UNF then it would seem likely that it is HQ pattern as it would be unlikely that someone would drill Commodore pattern and fit 7/16" UNF studs.
Edited by ls2lxhatch, 02 May 2015 - 12:26 AM.
#78
Posted 02 May 2015 - 12:30 AM
I doubt that it applies in this case, but just for the sake of accuracy...
VB to VZ Commodores are 5x120mm PCD with M12 studs and a 69.5mm centre bore
VE & VF Commodores are 5x120mm PCD with M14 studs and a 66.9mm centre bore
This means that older Commodore wheels won't fit on later Commodores (because the M14 studs are too big); and
Later model wheels won't fit on early Commodores (because the centre bore is too small)
#79
_UC Kid_
Posted 02 May 2015 - 08:29 AM
So the link I posted to the vb dragway rims won't fit ? :(
#80
Posted 02 May 2015 - 09:02 AM
#81
Posted 02 May 2015 - 09:09 AM
What I would suggest is that you forget about buying wheels for now.
Swap the motors over, get it registered and on the road, then when you see a set of wheels for sale, you can drive the Torana out to look at them and most times the seller will let you jack up the car in his or her driveway and try one on, guesswork eliminated, problem solved!
#82
_UC Kid_
Posted 02 May 2015 - 09:11 AM
yeah bigfella the wheels are just a side thing, because i was bored last night and may as well haha, but yes your right my main focus is swapping engine!.
that is a good point about driving the car there buut most rims that i like are in brisbane and places were its a bit too far to drive :/
#83
Posted 02 May 2015 - 09:17 AM
Still think you have commodore wheels with a HQ stud pattern
#84
_LS1 Taxi_
Posted 02 May 2015 - 09:21 AM
Patience grass hopper all in good time Still think you have commodore wheels with a HQ stud pattern
THIS!!! And it should be the number 1 priority to check and fix BEFORE you kill someone.
Broken record time...MEASURE!!!!
#85
Posted 02 May 2015 - 09:22 AM
I wouldn't even consider buying wheels and tyres from interstate, unless they're extremely rare or similar it will cost you more in freight than the wheels are worth.
It's a pretty safe bet that once you hit the road you'll be looking for any excuse to go driving anyway, and half of Sydney is only an hour away from where you are, it's just a matter of patience.
EDIT:
DOH! Beaten to the submit button yet again...
Edited by Bigfella237, 02 May 2015 - 09:23 AM.
#86
_UC Kid_
Posted 02 May 2015 - 10:19 AM
all very valid / true points guys . im with you ice and cant see the logic in putting commodore rims on torana?, its probally all he had on him and just put them on for time been?. dont worry daz, i will make sure its the correct stud pattern before driving on road with the rims!
i got a quote for like 250 from e-go to transport 4 dragways rims and tyres to wollongong... thats not too bad, but if its hq pattern than theres alot more choice and can buy some from sydney
'Patience grass hopper all in good time'
haha best quote of the day! made me laugh so hard
#87
Posted 02 May 2015 - 11:32 AM
buy some verniers , like this http://www.bunnings....a90113_p5660301
cheap crap but better than a tape measure
Edited by UCSLE, 02 May 2015 - 11:33 AM.
#88
_UC Kid_
Posted 02 May 2015 - 02:16 PM
i am going to try fit a hq on and than see the differance...
my measuring skills arnt the best ^
#89
Posted 02 May 2015 - 02:58 PM
Make sure you try it on the front as well just incase it touches any wherei am going to try fit a hq on and than see the differance...
lift the front up and turn steering left to right
#90
_LS1 Taxi_
Posted 02 May 2015 - 03:07 PM
#91
_UC Kid_
Posted 02 May 2015 - 08:31 PM
ok taxi, i will take some pictures tomorrow and post them on this to confirm what they are.. just to be safe
