Torana LX Park Lights
14 replies to this topic
#1 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
  • Car:1977 Holden Torana LX
Posted 23 April 2015 - 06:56 PM
Hey Guys
Im putting my car back together after getting a body restoration.
Just wondering where the park light socket goes into?
My head lights are sealed and i cant figure out where the park light globe fits in?
My wiring has a head light socket and park light connection.
  • Attached File  h1.jpg   44.27K   3 downloads
  • Attached File  h2.jpg   61.79K   1 downloads
#2 hanra
  • 11,020 posts
Posted 23 April 2015 - 07:54 PM
Set up on my LH
00000000-0000-0000-0000-000000006BC1_zps
00000000-0000-0000-0000-000000006BC0_zps
00000000-0000-0000-0000-000000006BC2_zps
#3 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 23 April 2015 - 08:07 PM
I need a different head light for that connection?
How are the original park lights fitted?
#4 hanra
  • 11,020 posts
Posted 23 April 2015 - 08:13 PM
Mine shines through the little clear window at the back of the sealed beam.
00000000-0000-0000-0000-000000006B90_zps
Edited by hanra, 23 April 2015 - 08:14 PM.
#5 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 23 April 2015 - 08:21 PM
No, the head light plug you have has had the park light piece removed, originally they look like the pics above, the park light shines through the small window below the bulb pins.
You could change the sealed beams to some H4's and maybe or maybe not the current mount for the parker might fit the H4, or more likely it will have to be changed.
If you are going for an original look then the above pics are what you need and will be available from Rare Spares or someone.
#6 hanra
  • 11,020 posts
Posted 23 April 2015 - 08:23 PM
#7 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 23 April 2015 - 08:36 PM
Oh i see, if i buy the park light holder will it fit on mine? or has my plug been modified?
I just had a look on eBay, they sell complete headlight and park light holder?
Would that be better? and would i need to alter the wiring?
http://www.ebay.com....=item35bec81d86
#8 hanra
  • 11,020 posts
Posted 23 April 2015 - 08:47 PM
Your plug has been butchered.
#9 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 04 May 2015 - 09:11 PM
Is it possible to drill a hole in my head light for park light?
#10 hanra
  • 11,020 posts
Posted 04 May 2015 - 09:35 PM
Probably easer to just use the correct plug.
#11 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 04 May 2015 - 09:47 PM
I can't find the plug anywhere!
#12 hanra
  • 11,020 posts
Posted 04 May 2015 - 09:50 PM
http://pages.ebay.co...id=141643260813
#13 MR77LX
MR77LX
  • 401 posts
  • Name:Rabs
Posted 04 May 2015 - 10:07 PM
Thanks mate
#14 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 05 May 2015 - 03:01 AM
i have 1 and a nos plastic plug minus the chrome light reflector  .the 1 near complete is missing the earth wire..no biggie.
you can just see the small bit of wire sticking up
Attached File  torrie pics 543.jpg   118.41K   0 downloads
Attached File  torrie pics 540.jpg   112.87K   0 downloads
#15 76lxhatch
  • 7,215 posts
Posted 05 May 2015 - 07:05 AM
If you wanted to spend a bit more money and go to the H4 conversion, the park bulb pushes into a grommet/hole in the reflector and you could use your existing plugs. Don't drill into the sealed beams.
