![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
any nifty ideas of accelerator cable in an LC
_LC2250_
Posted 25 July 2006 - 04:57 PM
my problem here is I have the twin barrel stromberg which requires a throttle cable (or some serious prefabiration to use the old linkages)
I'm just wondering if anyone has any good working setups that give the accelerator pedal fairly unrestricted movement over the full range of of throttle (open to closed).
I understand obviously I'll be connecting the cable throttle body on the carby but with specifics or even pictures if anyone can be bothered how do I go about this at the firewall end.
Any input, suggestions or ideas are greatly appreciated!
-Al
_Lc fan_
Posted 25 July 2006 - 05:38 PM
LJ. I bought it from a auto shop, it was for a 350 holle but i have modified it
for a 4 barrel. Here is the pic of the fire wall. Lets hope it works.
![Posted Image](https://cache.gmh-torana.com.au/i54.photobucket.com/albums/g93/chippy2210/DSCN0537.jpg)
Lc fan...
_LC2250_
Posted 25 July 2006 - 05:50 PM
Any chance of an enlarged version of that pic?
Otherwise Cheers
-Al
_Lc fan_
Posted 25 July 2006 - 07:09 PM
Will see if this is a better version.
The bracket is just tek screwed to the top panel..
lc fan
Sorry i dont know how to enlarge it yet pm me with your email and i will send it to you that way..
Edited by Lc fan, 25 July 2006 - 07:12 PM.
_Torana308_
Posted 26 July 2006 - 07:28 PM
_lx5008_
Posted 26 July 2006 - 08:21 PM
Posted 26 July 2006 - 08:26 PM
_73LJWhiteSL_
Posted 26 July 2006 - 11:40 PM
Steve
_@milco@_
Posted 26 July 2006 - 11:48 PM
thats what i have done on the gtr, the Hz style and commodore pedels are the sameish, you have to use a v8 throttle cable tho not the 6cyl one, the pedel dont matter wether its a 6 or 8......... best set up i have had the previously mentioned one i have had on a 4 door it was pretty crap compared to the hz/commo stylea mate has set up a hz style in his lj, the hz pedal will have to be screwed to the fire wall, drill a hole in the fire wall and file it so its square and the cable clips into that. its not a bad conversion to do.
Posted 28 July 2006 - 07:55 PM
Les
![Posted Image](https://cache.gmh-torana.com.au/i38.photobucket.com/albums/e135/mrlctorana/accelerator.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i38.photobucket.com/albums/e135/mrlctorana/accelerator2.jpg)
