lj brake / clutch pedal bushes
31 replies to this topic
#26 _mikecatts_
_mikecatts_
Posted 07 May 2015 - 08:54 AM
yep... 4 bangers have the same bits..
Edited by mikecatts, 07 May 2015 - 08:54 AM.
#27 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 07 May 2015 - 12:06 PM
Mike, do you have the length of the bushes ?
#28 _mikecatts_
_mikecatts_
Posted 07 May 2015 - 01:42 PM
12mm overall and 6mm in the cut out where it pivots.
#29 Davis
Davis
  • 343 posts
  • Name:Drew
  • Car:LC 2 door
Posted 20 June 2016 - 08:51 PM
How did the test sample go, was the ford bearing an appropriate replacement to use on the lc/j pedal box?
#30 _SableMet7/73_
_SableMet7/73_
Posted 23 June 2016 - 03:10 PM
Went looking along the 4 banger line & got a hit on a UK website for Vauxhall Viva HB/C
brake pedal bush #6368033.
This is them...
Attached File  NuBush.JPG   326.44K   3 downloads
Looks like the left ones in the 2nd of Mike's bush pics in post #17.
Fits the pivot shaft snug & all but 1 measurement are the same. The shoulder between the underside
of the flange to the "barbed" inner end is 8.8mm rather than 6mm due to a shallower barb.
The flange thickness & depth is the same so once assembled I don't see it being a problem, altho I havn't
fitted these to the clutch pedal as I got these as spares coz mine aren't flogged out yet.
Found them at vauxhallgreenparts.co.uk but I remember them telling me in 1 of the emails that these were
the last 2 or there was 2 left?...Thought they would've ordered more as they look more of a replacement bush
than a NOS bush.
Happy to drop into my local Rares with veniers & bush in hand if someone's got the part # for the bush in Mike's pic.
#31 S pack
  • 15,764 posts
Posted 23 June 2016 - 03:36 PM
Jono
Your new HB/HC Viva bearing Pt #6368033 looks more like the length of an original HB, LC,LJ,TA Torana bearing Pt #6368033 rather than the shorter Ford bearing Mike posted a pic of.
#32 _SableMet7/73_
_SableMet7/73_
Posted 23 June 2016 - 04:28 PM
OK. Not by much tho....
the above bush on left still in my pedal = 11.7mm, new bush is 11.88mm
