6 cyl Powerglide
Removeable bellhousing?
29 replies to this topic
#26 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 14 June 2016 - 08:30 PM
Ok thanks yel
She did say it was out of hg
#27 yel327
  • 13,637 posts
Posted 14 June 2016 - 08:40 PM
I actually stuffed up my last replay, should be HD-HT as the only HG with a powerglide was GTS350.
#28 Dr Terry
Dr Terry
  • 3,325 posts
Posted 14 June 2016 - 10:39 PM
I just checked Byron, the 253/308 Powerglide also comes in 2 versions, column shift & console shift, for the same reason as the 6.
SBC V8 Powerglides have only the one lever type in Holden applications.
Dr Terry
#29 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 14 June 2016 - 10:52 PM
Haaa. I accidently pushed g instead of t lol
and was too late to change it.
Can you guys see the rectangle block
In front of the selector.what is that
Is it something to do with kickdown?
Attached File  20160614_200057.jpg   556K   3 downloads
Edited by madtoranajzedded, 14 June 2016 - 10:56 PM.
#30 yel327
  • 13,637 posts
Posted 15 June 2016 - 07:17 AM
Dr Terry
Well there you go, never knew that one. Learn something new every day.
Mechanical kickdown. These use a linkage setup rather than a cable like a TH350.
