Silicone hose for exhaust joins
5 replies to this topic
#1 _nowaynicko_
_nowaynicko_
Posted 17 June 2015 - 03:40 PM
Hey guys,
Just wondering if anyone has any info or used silicon hoses (the ones the turbo guys use) on their exhaust systems.
I was thinking I could cheaply and easily join up a system that would get me by until I had enough saved to get a stainless system made (I have most of the components already).
Worried that the hose will become blobs of goo or charred mess or whatever it turns into when it overheats.
The Turbosmart page says their hose is rated to 180c and I have seen google images where the connection off the turbo intake is silicon.
Would it be ok to go silicon off the bottom of my headers (355 EFI) into the cat? Then subsequently all joins after that?
Would I need more hangers because it would be more flexible?
Any tips or ideas much appreciated.
Nicko
#2 ido09s
ido09s
  • 337 posts
Posted 17 June 2015 - 03:53 PM
you are aware some exhaust gases go as high as 600 degrees aren't you? Although turbo charged, I regularly see 500 degrees with my car.
Silicon intercooler will not work with exhaust pipes
#3 neglectedtorana
neglectedtorana
  • 1,041 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 17 June 2015 - 04:22 PM
There are other higher temp rated exhaust hose used on marine engines but I don't think they would cope with 500c that a cat would run at
You can buy flexible metal exhaust pipe joins but if it is just from the end of the headers to the cat cost to get a pipe made would be cheaper than a hose that would cope with that temp
#4 _Bomber Watson_
Posted 17 June 2015 - 04:40 PM
THe marine stuff is designed to work with water injected before them, It dies real quick if the water stops for whatever reason (trust me)
Short answer to the original question, no.
#5 _Gunmetal LH_
_Gunmetal LH_
Posted 17 June 2015 - 07:46 PM
Seen this type of thing on a few trucks-
http://www.ebay.com....=item3a88c46019
There's all sorts of diameters and lengths.
#6 _nowaynicko_
_nowaynicko_
Posted 18 June 2015 - 01:47 PM
Thanks for the replies guys. I think I will go with a steel tube and clamp. Just till I can get it to the shop.
Sent from my GT-I9305T using Tapatalk
The convo hose would work but it's exxy man
