Lh rear torana lowering
8 replies to this topic
#1 _parsons5000_
_parsons5000_
Posted 04 July 2015 - 05:44 PM
Hey guys trying to get ideas on what springs to run in the rear . I measured rear from bottom of rim to centre of gaurd which measures 505 mm and diff pinion touches bumpstop above diff centre . The springs are king springs compressed another 20 mm from being lowered already but feels like they are to soft , what are my options ?
#2 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 04 July 2015 - 08:43 PM
standard rears unless running a drop tank full of fuel and half a dozen "bunnies" that need a ride home ?
#3 76lxhatch
  • 7,202 posts
Posted 04 July 2015 - 09:06 PM
Once you have the springs sorted you may still need to trim the bump stop a bit shorter
#4 dattoman
  • 16,487 posts
Posted 04 July 2015 - 09:47 PM
9" is abit bigger than banjo ... hence why its so close
#5 _parsons5000_
_parsons5000_
Posted 04 July 2015 - 09:49 PM
If the bump stop gets trimmed can't that cause other issues?
#6 _Bomber Watson_
Posted 05 July 2015 - 07:47 AM
The lowly plebb models didn't have them, at least mine didn't, so probably wont cause much of an issue.
#7 _parsons5000_
_parsons5000_
Posted 05 July 2015 - 08:28 AM
This is the problem I have if I remove to much bumps top , as my fuel pump is above diff .
#8 arrimar
arrimar
  • 3,134 posts
Posted 05 July 2015 - 07:21 PM
On my standard L34 theres 65mm between the bump stop and the carrier. The intended meeting point is above the pinion bearing.
With the larger carrier yours is going to contact somewhere it was never designed to.
I'd unbolt it and put it in a safe place.
#9 hanra
  • 10,936 posts
Posted 05 July 2015 - 09:25 PM
I notice the below shown in the workshop manual, but in the parts book it lists a bump stop for 4cyl and 5 litre?
D7937D73-519C-404F-B252-C773379A4E39_zps
Edited by hanra, 05 July 2015 - 09:26 PM.
