Fact or Fiction.
768 replies to this topic
#626 _76lxJAS_
_76lxJAS_
Posted 17 September 2015 - 11:04 PM
Fiction. I was called to a dedicated LPG Commodore recently with a flat tyre. It didn't have a spare but it did have a can of goop and a compressor. Problem was it went flat at 110kph on the freeway and by the time he got into the service lane the tyre was trashed. The goop would not of fixed it and I doubt whether a field of freshly slashed grass would have fixed the side wall.
Fact
its fact it was on bush mechanics years ago.
much to my surprize they jammed in as much grass as they could poking it in with sticks. after they broke the bead, side walls where still ok though.
they got far enough to get it repaired,  maybe not high speed though.
#627 N/A-PWR
  • 9,639 posts
Posted 17 September 2015 - 11:08 PM
he he, Rob Dammit knows nothing.  :clap:  :spoton:
Like Button for you Jason.
#628 Potta
Posted 17 September 2015 - 11:34 PM
They pretty much replace the air with grass yeah?
#629 Shiney005
  • 9,609 posts
  • Car:Toyota Mirai
Posted 17 September 2015 - 11:57 PM
They used spinifex. I have heard of others using it as well. Not too many Bob Jane t marts in the Great Sandy Desert.
#630 _76lxJAS_
_76lxJAS_
Posted 18 September 2015 - 08:51 PM
yep sure do. it gets u out of trouble for a short trip.
F or F
ladies stockings can be used as fan belts?
#631 Indy Orange
Indy Orange
  • 2,948 posts
  • Name:Paul
Posted 18 September 2015 - 09:08 PM
F or F
. Fact
#632 S pack
  • 15,727 posts
Posted 18 September 2015 - 09:11 PM
F or F
If you have a Gilmer drive you'll need to tooth them first :)
Edited by S pack, 18 September 2015 - 09:11 PM.
#633 _76lxJAS_
_76lxJAS_
Posted 18 September 2015 - 09:58 PM
haha very true maybe tape a heap of twigs across them first.
correct paul.
fact it is.
Edited by 76lxJAS, 18 September 2015 - 09:59 PM.
#634 Bigfella237
Posted 12 November 2015 - 03:27 AM
Speaking of Gilmer drives...
Fact or Fiction: The Holden V8 prototype was originally designed with a cam drive belt?
#635 Bigfella237
Posted 12 November 2015 - 03:35 AM
Ah who am I kidding, I can't wait for all you clowns to wake up...
Fact. This is one of the first ever Holden V8's fitted to the 1969 Hurricane prototype vehicle:
Attached File  1969-Holden-Hurricane-16.jpg   408.15K   3 downloads
#636 TerrA LX
Posted 12 November 2015 - 05:18 AM
I fail to see ANY CAM belt drive.
AND, FWIW, that car has been way modded from it's original concept...
#637 Shiney005
  • 9,609 posts
  • Car:Toyota Mirai
Posted 13 November 2015 - 11:20 AM
Belt is driving water / power steering / whatever pump at front of right bank?
#638 TerrA LX
Posted 13 November 2015 - 01:09 PM
Water pump, most probably to clear the cockpit.
#639 Bigfella237
Posted 13 November 2015 - 03:55 PM
Look at the thickness of (what would be) the timing cover, it's only about a third as thick as the later chain-driven design and has nowhere near enough space to house sprockets and a chain.
The only thing in there would be the cam retainer, oil pump drive and an oil seal.
Attached File  1969-Holden-Hurricane-16_cropped.jpg   228.23K   3 downloads
#640 TerrA LX
Posted 13 November 2015 - 05:15 PM
It is thinner due to the face there is no water pump present.
#641 Bigfella237
Posted 13 November 2015 - 05:29 PM
Time to go out to your shed and have a look at the width of a typical Holden V8 timing cover...
#642 TerrA LX
Posted 13 November 2015 - 05:34 PM
LOL, it still has a balancer on the front, with a seal behind, what lives behind the seal??????????????????????
#643 TerrA LX
Posted 13 November 2015 - 05:36 PM
Remember, all the first Holden V8's had single row timing chains...
#644 Bigfella237
Posted 13 November 2015 - 05:44 PM
The balancer on the prototype engine obviously must have a sprocket behind it to drive the belt so I assume the oil seal would be further in toward the front main cap?
Anyway, I guess there's no way to prove one way or the other unless someone has keys to the Holden museum and a basic tool kit?
I'm just going by what my eyes tell me, why else would they bother with a toothed belt if not to time the cam? I don't think Gilmer drives were around in 1969 were they?
#645 TerrA LX
Anyhow, you probably right, what I thought was the water pump is the A/c pump, the front of this motor have obliviously been modified from it's first incarnation, I doubt very much there was access to CNC alloy machining.
Also, that radiator...
Would love to see an original photo of this engine insitu.
#646 TerrA LX
Posted 13 November 2015 - 05:58 PM
It is a new water pump, fitted by daviscraig, wonder what else have been modified???
#647 rodomo
  • 18,039 posts
Posted 13 November 2015 - 08:38 PM
The motor in it now is not original. I'm with you Terry. Cam not belt driven.
#648 Shiney005
  • 9,609 posts
  • Car:Toyota Mirai
Posted 14 November 2015 - 11:38 AM
I am as hung over as hell this morning so probably dribbling, but it seems like a lot of work just for an ancillary drive. Why wouldn't they just run the pump from the crank? I also don't buy that the standard water pump would not do the job. It would certainly fit in the same space as the inlet and outlet pipes currently used. I also think if this setup was all for the water pump they would have used a larger sprocket on the crank and smaller ones for the pump and idler.     Man I have a headache.
#649 TerrA LX
Posted 14 November 2015 - 12:13 PM
OK, to prove my point, look real hard at the timing pointer, there is a wire stuck in the center of the top pulley, to point at the marks on the balancer.
If the whole top part was a gear and not an idler pulley you would not be able to leave a piece of wire in there to time anything whilst rotating the crank/cam...
Edited by TerrA LX, 14 November 2015 - 12:15 PM.
#650 Shiney005
  • 9,609 posts
  • Car:Toyota Mirai
Posted 14 November 2015 - 01:10 PM
Fair call.
