Posted 18 June 2023 - 12:26 PM
Posted 18 June 2023 - 12:33 PM
looking good , can't wait to fire this up
Posted 19 June 2023 - 01:31 PM
Exciting!!!
Posted 22 June 2023 - 06:09 PM
Posted 22 June 2023 - 07:00 PM
You have an odd pair of heads! Only one of them is an early head. The driver side is a HQ-HJ but the passenger is HT-HG!
Your red VP SS reminds me of the $1000 special I used as a donor car for the engine that went into my Overlander. It was identical to yours but white. I cut a lot of the mounts for the fuse box and cruise control out of its engine bay and it was scrapped. Shame how many were scrapped for their drivelines. There was a complete black manual one rusting away near me until a year or two ago, I tried to buy it but last I saw it there was rust holes around the rear screen.
Posted 22 June 2023 - 08:53 PM
Posted 28 June 2023 - 07:01 PM
Posted 28 June 2023 - 07:34 PM
Posted 08 July 2023 - 05:52 PM
Posted 09 July 2023 - 12:27 PM
your attention to detail is outstanding
can't wait to see it
Posted 10 July 2023 - 09:19 AM
Looking good.
Posted 16 July 2023 - 04:58 PM
Looking good.
Posted 16 July 2023 - 05:32 PM
Posted 16 July 2023 - 07:15 PM
Posted 16 July 2023 - 09:39 PM
Love it.
Posted 22 July 2023 - 07:09 PM
Posted 22 July 2023 - 07:59 PM
Posted 26 July 2023 - 07:45 PM
It’s a pity you couldn’t make the good old after market FE to HK clutch master mount horizontally.
Posted 28 July 2023 - 11:17 AM
Would fit in just fine if you deleted that useless booster.
Tidy hard lines mate.
Posted 29 July 2023 - 08:29 AM
When I restored my hatch in the early 2000s I reused the Dellows clutch master cylinder assembly as you also have. After years of heavy clutch pedal pushing, a bugger to top fluid without spilling brake fluid on the paint work, low take position from the floor and big piss off was every time I wanted to check and set tappets I had to unbolt the master cylinder to gain enough room to get the drivers side rocker cover off. The heavy spring pressure plate to handle the torque just don't like that system. I ended up making my own system using a Ford BA falcon clutch pedal assembly and modified it to suit the Torana. Very easy to do and install, I can now push the pedal to the floor with one finger. Much better feel with a take up point at mid travel. One of the best mods I have done to the hatch and a real pleasure to drive a manual again. I didn't even blink an eye lid and did the same conversion to my SLR. Also frees up lots of room in the engine bay, looks so much neater, you can only see the remote reservoir under the bonnet.
Posted 29 July 2023 - 11:50 AM
What cast date was your block Aaron? And did it have a timing chain tensioner when you bought it?
Posted 29 July 2023 - 08:48 PM
Posted 29 July 2023 - 09:19 PM
Posted 30 July 2023 - 08:54 AM
Hey axistr
I’m very interested in your BA clutch master set up you’ve done in your Hatchback, can you send me more details or better still are you heading out to the Nsw All Holden day next weekend ?
Cheers Aaron
G'day Aaron, yep I'm going, have both Toranas entered and will be parked with the Sydney Torana Club. I will have a dig around and try and find the link of the conversion.
Cheers Lenny.
Posted 30 July 2023 - 09:18 AM
Aaron see attached link below to my clutch master cylinder mod.
updating the hatch - Members Projects & Plans - GMH-Torana
I will try and get a power steering rack kit finished this week and throw it in the back of the Hatch if anyone wants to see one at the all Holden day.
