It is about the only colour car they look good in. I don't think I have ever seen them painted to match any other colour.
From Sunbird to Phoenix
#476
Posted 19 June 2024 - 09:39 AM
#477
Posted 19 June 2024 - 04:26 PM
Yeah, I don't mind the silver-on-silver tail light surrounds... if you had chrome bars it would be a bit funny but with silver bars it looks nice.
Are you going to black out the radiator support panel so you can't see it through the grill?
#478
Posted 20 June 2024 - 02:01 PM
Not sure Heath.
#479
Posted 20 June 2024 - 02:07 PM
The fuel tank is painted ready for installation, always looks the part with the black straps .
Cheers Aaron
#480
Posted 21 June 2024 - 09:22 PM
great job mate , and built in your garage !!
Cant wait to see it and hear it !
#481
Posted 24 June 2024 - 05:28 PM
Thanks Tony
Great satisfaction getting the build done yourself.
Cheers Az
#482
Posted 24 June 2024 - 05:53 PM
come on Aaron, we need to see the interior !!!!
Ok Tones here ya go,
The dash pad was refreshed by vacuumed formed with original type grain by Ian at Dashboard Recovering Services, I did have an original White needle SL/R dash that was going in although once I had seen a Peter Nash dash I had to have one.
#483
Posted 13 July 2024 - 06:41 PM
I purchased the Chamois hood lining & vinyl kit from C & G Upholstery and I got to say how good the quality is, pre getting it installed i laid the hood lining and the door vinyls out on a flat board basically for months unit it was time for Lewis from Moore Style Upholstery to install.
Lewis mentioned….. I wish everyone laid out the vinyls and lining as it made the install so much easier as he didn’t have to deal with creases.
I’m absolutely stoked with the outcome & can’t wait to get my carpet,seats & door trims.
#484
Posted 13 July 2024 - 07:05 PM
#485
Posted 14 July 2024 - 11:12 AM
I'm heading to the shed now to do the same to mine.
#486
Posted 15 July 2024 - 10:38 AM
I wish I had gone white numbers instead of yellow with my dash... I wanted to keep the SLR/LX theme, but white looks cleaner than the yellow. Still happy with it. Looking good mate!
#487
Posted 15 July 2024 - 01:04 PM
G’Day Viewers
How difficult is the sound deadener stuff to apply? I have to do my HK GTS at some stage soon. Is it a problem for water retention (old Holdens always leak!) and thus rust, or is it pretty good that way?
#488
Posted 15 July 2024 - 03:40 PM
The chamois trim looks fantastic!
The peel-and-stick insulation is pretty easy to install, you want to use a roller with it.
I don't imagine it's much of a drama for water retention... as in on the inside of a door skin under a winding window where water might be inside the door when it rains hard? I would not worry if you prep everything and apply it correctly so it's not catching water under it, lol.
#489
Posted 15 July 2024 - 04:37 PM
I'm thinking more about water leaks and under the carpet. These old cars always seem to leak from their cowls if you get in really heavy rain. I don't think I've ever had a HK to WB or Torana (I've had them as daily drivers since the early 80's) that didn't leak somehow. I'm not talking rust leaks but the plenums getting overwhelmed in torrential rain where the drain tubes can't keep up or they get blocked with a leaf and you get overflow onto your feet. Plus HK coupes have glass sealing against rubber. Hatchbacks are bad enough with door seals letting heavy rain in, but HK coupes have no frames and water gets in. My current GTS is being built so it can be used as a daily if I want to, with air, steer, big brakes, sensible tyres etc. At some stage it'll either get rained on when parked or driving. And I remember too well that wet carpet underlay smell!
#490
Posted 15 July 2024 - 05:39 PM
My method is to lay soft heat and sound insulation on the lower floor without glueing it down. Factory mat on top. Every time I get back from a wet trip I pull out the mat and insulation and dry everything out.
#491
Posted 15 July 2024 - 11:33 PM
Interesting. Mine has probably spent 20 nights getting absolutely pelted with rain and since I actually glued the sunroof seal onto the sunroof panel, it has been fine if the sunroof is closed.
Except for the rear boot sub-floor. Not sure if that's tail lights or something else, but that area does leak.
Most of my deadening products aren't glued to the floor, but there is some that way. I reckon it would be more likely to rust at the edge of the sheets considering how the glue goes down and seems to act as a sealant. I guess you probably want a bit of overlap between the sheets or a sealant between them, but they possibly prevent some rust issues if you're happy to put a heavy amount of it on. I haven't done it that way.
#492
Posted 16 July 2024 - 08:45 AM
#493
Posted 16 July 2024 - 12:13 PM
Really easy to install yel327 as the sheets are a peel off backing & stick on, you can lay the sheet in place and shape it to the area, trim and cut where required then a couple of markers where the sheet will lay. Definitely clean the surface & Peel the backing off & stick down…. Roller required to bond it 100% to the surface.
The CarBuilders product I purchased came with an install kit… Roller, knife & foil tape for the joins between sheets.
Cheers Aaron
#494
Posted 16 July 2024 - 12:20 PM
Hey Laurie
Certainly made a difference on the installation, Lewis had the hood lining & door vinyls all done in a few hours.
#495
Posted 21 July 2024 - 06:57 PM
Ticking more shit off the list, I purchased a new windscreen from Glass for Classics which I’ve got to say how great they are to deal with, I wouldn’t bother dealing with anyone else if you want perfect glass.
I had ol’mate come around to install my front & rear glass… you can never beat old Skool experience as he’s done a fantastic job although I did make the job easier having my window & windscreen seals on the glass taking shape for many weeks.
#498
Posted 06 September 2024 - 07:34 PM
Well Done Aaron
I heard a rumour that this hatch will make a special appearance at Breakfast at Tony's on the 13th of sept 2024
#499
Posted 06 September 2024 - 09:50 PM
That would be awesome
#500
Posted 07 September 2024 - 07:06 AM
Well Done Aaron
Thanks Tony
It sure will be buddy,
What a perfect way to make its debut appearance surrounded by a family of beautiful Torana’s.
Cheers Aaron
