VY clock spring replacement.
7 replies to this topic
#1 rodomo
  • 18,018 posts
Posted 13 September 2015 - 11:30 AM
Google answers are conflicting.
What do I disconnect?
1 Battery?
2 Fuse?
3 Just don't turn the ignition on?
4 All of the above?
And also, your methods to centralize the clock spring?
Only interested in advise by those that have actually done this please.
#2 _Macca97_
_Macca97_
Posted 13 September 2015 - 12:21 PM
ive been told to unhook the battery and leave the headlights on :/
#3 neglectedtorana
neglectedtorana
  • 992 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 13 September 2015 - 12:24 PM
Might be the same,
On my VX I started with the wheels pointed straight and disconnected the battery and waited about 10min, my Haynes manual says 10sec to disable the SRS
When centralising the clock spring I did it before I put it in by counting the turns from left to right and finding the centre, when it is in the centre there was a small green piece visible in a window, as you turn left to right to the stops the green piece can be seen on it's way past but is only fully visible when in the centre
don't turn it to hard to each end as apparently that is how it could be broken
#4 arrimar
arrimar
  • 3,134 posts
Posted 13 September 2015 - 02:19 PM
I changed my vy clock spring. Getting the horn pad off is the hardest part.
Battery disconnected.
Few different varieties available dependent on trim level.eg amount of controls on steering wheel.
About $50 for non genuine part.
About $40 for an auto elec to wipe the code once your done.
#5 rodomo
  • 18,018 posts
Posted 13 September 2015 - 09:20 PM
Er ................well....................um............ I opened the box and the instructions are there on how to centralize.........Disconnect the battery would be the safest option I reckon? I think I have the radio code in the books.
Thanks for your input :spoton:
#6 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 13 September 2015 - 11:10 PM
Instructions are for wimps.
#7 _mello92_
_mello92_
Posted 14 September 2015 - 09:57 PM
Strange. Any half decent clock spring should come pre-centralised and with a clip in place so it cannot move. But yes if need be the above method of counting rotations and turning back to the mid point is general practice. Slowly though.
Correct, disconnect both battery terminals and wait for 5 mins or so before unplugging any SRS wires. This allows any capacitor to fully discharge. Use this time to remove steering wheel. Or drink, whatever. But I'd prefer you didn't on this job.
#8 rodomo
  • 18,018 posts
Posted 20 September 2015 - 01:42 AM
Genuine article, bought new from Holden. The clip is part of it and can't be removed. What the instructions don't tell you is that the centralizing was done at the factory. I guess they lost some thing in the translation from French?
