engine building/simulation software
27 replies to this topic
#1 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 16 September 2015 - 11:32 AM
Hi everyone,
Just wondering if anyone has any experiences they would like to share regarding the use of engine building software... What did you use, how good is it, how much did it cost etc etc...
I am considering planning an engine build and would like to use simulation software to check my data with (for reference).
Advice?
#2 Peter UC
Peter UC
  • 770 posts
Posted 16 September 2015 - 12:54 PM
I've used Pipemax and I know there are very good engine builders that use the same. It's not fancy but it works and it pretty cheap.
#3 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 16 September 2015 - 01:15 PM
I have heard some use pipemax for engine building- but as i havent used it, I am not sure of its limitation as an engine simulation software (I know its highly regarded for exhaust simulation).
i have been playing with http://performancetr...ownload.htm#ea3
There is a demo for the engine anaylser- I have been playing with it and it looks quite good, but I am limited to what I can do. They only give you one engine and you cannot modify the head much, but you can see the effect of valve timing events, and intake/exhaust setups.
I have gotten the demo engine up to 400hp from 210hp by optimising the intake/ exhaust to the cam. I have noticed that good flowing intake and exhausts really like close centerlines for peak HP. With a more restrictive exhaust, the wider LSAs seem better...
Why dont we have a challenge? See who can extract the most peak HP and Torque using the demo (which limits us with block and head), and re-post the specs...
NOTE: don't use the 'optimiser' its cheating! This will calculate the best figures for you. No fun in that...
Edited by LC-GTR-1969, 16 September 2015 - 01:16 PM.
#4 myss427
myss427
  • 1,636 posts
Quarter junior is pretty good also.
#5 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 16 September 2015 - 02:55 PM
I have used engine analyser but i found it was cumbersome and too many inputs were required. Now i use dyno 2000 which is much simpler. You just select an engine similar in design to yours so if you were doing a 202 a Slant six is selected and u change the bore and stroke. It requires head flow , cam and intake specs and is a good tool to see the effect of combo changes
#6 _Bomber Watson_
Posted 16 September 2015 - 03:05 PM
Desktop dyno now has golden sixes and eights in the library.
#7 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 16 September 2015 - 03:40 PM
Awsome do u have it bomber
Edited by STRAIGHTLINEMICK, 16 September 2015 - 03:40 PM.
#8 _Bomber Watson_
Posted 16 September 2015 - 03:42 PM
Yeah mate. Bought it a while ago.
I would get the pro version if I was buying again, as the basic version doesn't do forced induction.
Pipemax is on my list of things to buy.
#9 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 16 September 2015 - 07:45 PM
It helped me chose a cam duration that maximised hp but kept some torque at lower rpm . The duration was spot on but not sure about the lsa, best lsa was found the old way . Hp was about 280 @5800 which is what the head flowed and is close because it makes 210 Moroso at the track .
Anyway i was running my own business at the time and  the aim was to come up with a repeatable street/race combo that i could sell on . I think its an important  tool to have because if used as a guide it takes a lot of trial and error out of engine building.
But the main thing to remember with these programmes is if u put bullshit numbers in you'll get bullshit numbers out .
#10 _oldjohnno_
_oldjohnno_
Posted 16 September 2015 - 09:12 PM
Here's an interesting exercise: choose a realistic combo and peak rpm figure and run these through a few different simulators. Obviously if we are running the same cam and rpms each time then we should get very close to the same intake and exhaust dimensions from each simulator. I've tried this with EA, Quarter Junior, PipeMax, DD and a couple of others I forget the names of and they all came up with different numbers, sometimes wildly different. Likewise they'll give different cam recommendations for the same combos. EA especially seems to give wildly optimistic predictions and I consider all the cheap packages to be useful only as a way of getting in the ballpark. They all make too many assumptions to be accurate but the only one I really like (Pipemax) isn't really a simulator at all - but a handy tool just the same. Stan Weiss's Carfor is handy at times too; kind of a swiss army knife of car and engine calculators. Bloody ugly though.
Edited by oldjohnno, 16 September 2015 - 09:13 PM.
#11 _Bomber Watson_
Posted 16 September 2015 - 10:09 PM
Yeah I just pick the one thats mots favorable out of the bunch, then go to the pub and talk up my new combo.
#12 _oldjohnno_
_oldjohnno_
Posted 17 September 2015 - 05:51 AM
The 440hp 161 with dual 4 barrels?
#13 _Bomber Watson_
Posted 17 September 2015 - 07:09 AM
Pfft that's old tech, its making 720 now with six ls1 throttlebodies.
#14 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 17 September 2015 - 08:33 AM
Wow bomber im impressed. what was the rpm.
Ive never entered enough bullshit to make that much power.
#15 myss427
myss427
  • 1,636 posts
Posted 17 September 2015 - 11:40 AM
Oldjohnno, what do you think of Quarter junior?
#16 _oldjohnno_
_oldjohnno_
Posted 17 September 2015 - 10:13 PM
I haven't played with it for a couple of years and even then I didn't spend much time with it. From memory it was one of the ones that gave weird runner lengths though I could be wrong. Having said that Patrick Hale is undoubtedly a smart guy and was one of the first if not the first to offer this kind of software. I suspect it would be much the same as the others - a bit of fun and good enough to use as a rough guide but certainly not gospel.
I bought some two-stroke expansion chamber software and after you enter all your engine details it sits there for about 20 seconds with squillions of numbers scrolling quickly past the screen. I think it's pretending to be doing some incredibly complex calculations to design you the Worlds Most Powerful Pipe. Never mind that the actual sums are pretty simple and could be performed by any old computer in a fraction of a second, it all looks hugely impressive and somewhat hilarious.
I think the 4 stroke stuff is kind of similar - by outputting masses of data precise to the 2nd decimal place the user is led to believe the results just might be accurate. For example some will give ignition timing recommendations at various rpm intervals after being given nothing more than the broadest hint of the chamber type, and nothing at all about swirl or heat or mixture motion at all. So of course the recommendations are bogus though they do look convincing.
Which is not to say I don't think simulation can't be accurate - I'm sure the higher end stuff is very good. But it often costs tens of thousands of dollars, and literally requires days to enter all kinds of data that the average racer doesn't even have.
I'm going to produce my own software specifically for Holden sixes. It'll have just one button labelled "Design me a fast motor"
Pressing it will produce three lines of output:
1, Suggested intake port flow - as much as you can get out of it
2, Suggested cam: as much as you and your available gear ratios can put up with, on a 107 LSA
3, Suggested runner dimensions: whatever Pipemax tells you to use
I might even make it do the scrolly number thing to make it look like it's working really hard to come up with the answer...
#17 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 18 September 2015 - 07:02 AM
Funny...
#18 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 18 September 2015 - 08:05 AM
I'm aware of a 186 just got 700 on a dyno...
#19 _Bomber Watson_
Posted 18 September 2015 - 09:55 AM
Saw that vid... frOckin beast.
#20 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 18 September 2015 - 09:56 AM
I only heard about it.
Link me please!
#21 orangeLJ
Posted 18 September 2015 - 11:20 AM
Supercharged thing?
#22 kiwi-lilj
kiwi-lilj
  • 1,428 posts
  • Name:Blair
  • Car:LIL J
Posted 18 September 2015 - 11:53 AM
350 Holley I would guess?
#23 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 18 September 2015 - 12:50 PM
Yes.
Supercharged thing.
Come on, DJ.
I even went trawling through Facebook looking for it and couldnt find it.
Put me out of my misery.
#24 _Bomber Watson_
Posted 18 September 2015 - 02:47 PM
Will have a dig tonight when um on the outer.
#25 _GreenLH LS3_
_GreenLH LS3_
Posted 18 September 2015 - 07:47 PM
Yes.
Supercharged thing.
Come on, DJ.
. Google Pro 186 . Blue LJ . Mick Douglas owns it. Jack bros in qld builds the engine
