identifying stub axles
HK HX
6 replies to this topic
#1 restoration
restoration
  • 21 posts
  • Name:Nathan Bishop
  • Car:LJ torana 2 door
Posted 06 October 2015 - 10:05 PM
Hi all
I'm sure this has been covered but i can't find what model they are off my thought's are HK but unsure, can anyone identify from the part numbers they are hard to read but i will try and put them up.
Left side starting at top:  0997
What looks like                44
                                       GM NF
Two circles at bottom       S  S
Right side                       0996
What looks like                40
                                       GM NF
Two circles at bottom      P  K
Any info appreciated.
#2 S pack
  • 15,726 posts
Posted 06 October 2015 - 10:18 PM
You have a pair of HX Holden (excl 1 Tonner) disc stubs for use with cast iron calipers.
#3 restoration
restoration
  • 21 posts
Posted 07 October 2015 - 07:59 PM
Thanks for the info s pack do you recognise these by sight or have you referenced these from part numbers, I just need to be 100% sure because they have to pass engineering and rego checks once completed.
#4 yel327
  • 13,643 posts
Posted 07 October 2015 - 08:15 PM
HK to HX are the interchangeable other than the heat treatment on the cab-chassis examples. The alloy caliper ones changed in some way for HX-WB.
#5 S pack
  • 15,726 posts
Posted 07 October 2015 - 08:28 PM
Referenced by the numbers 0996 & 0997 being the last 4 digits of the part numbers.
#6 restoration
restoration
  • 21 posts
Posted 07 October 2015 - 08:45 PM
Cheers guys now i can order a brake upgrade kit and continue the build.
#7 Bigfella237
Posted 07 October 2015 - 08:50 PM
The part numbers are:
2820996/7 - all (except 1 tonner) up to mid HX with steel calipers
9943693/4 - all (except 1 tonner) mid HX onward with alloy calipers
9943964/5 - 1 tonner (only) up to mid HX with steel calipers
9943695/6 - 1 tonner mid HX onward (and Torana A9X) with alloy calipers
The heat treated 1 tonner / A9X spindles should have "HD" stamped into them too.
Edited by Bigfella237, 07 October 2015 - 08:51 PM.
Also tagged with one or more of these keywords: HK, HX
