Hoppers stoppers installation
126 replies to this topic
#126 lx008
lx008
  • 52 posts
Posted 27 February 2021 - 02:25 PM
Hopper used to supply two versions of the 290 mm AU twin piston kit.
One version used a hub with a 8 mm offset to suit the offset used on Commodore stud pattern rims. There was also a standard offset hub that was supplied with Torana stud pattern.
This is a picture of the Hoppers 290 mm AU twin piston set with Commodore offset. You can just see the larger silver spacer between the caliper and the caliper adaptor.
The extra 8 mm offset gives better clearance between the caliper and the control arm on full lock but could be enough to cause tyre clearance problems if you were not replacing the rims.
So Hopper's no longer sell the kit with the Torana offset?
#127 ls2lxhatch
  • 5,332 posts
Posted 27 February 2021 - 04:14 PM
No idea. You will have to ask them.
