LoHla
173 replies to this topic
#51 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 18 December 2015 - 09:25 PM
My Dad had a few days free this week so spent some time on the Torana... Now has a Torana column but with VE indicator stalk and wiper stalk   :)
#52 Bigfella237
Posted 19 December 2015 - 05:17 AM
Major improvement over the Torana blinker switch there Justin, does that mean you're going with the full BCM/SW-Can/GMLan system? (That will be an endless amount of fun!)
But I'm still waiting to hear if the HVAC fits?! :clappin:
BTW, I assume that column, not having an ignition "lock" as such, no longer complies with ADR 25, which goes into great detail about types of locks and keys and anti-theft devices etc.?
I was of the belief that the car still had to comply with all of its original ADRs?
#53 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 19 December 2015 - 06:06 AM
yes will still have steering lock  ;) theres more than one way to skin a cat.... along with yes  car is running full VE (minus airbags and abs/esp)
so think of it this way it is a VE with a Torana body   - and trust me .. this will be fully engineered... before i bought the car and engine the engineer was consulted with and as i move along he knows exactly whats going in and which way i am going.... its not the normal build of listening to what others say can work and wont work and then rock up at his door step and say pass me... cause i know this just wont work... have had 2 other cars engineered before so know the effort etc.. you need to go to
also this is not a dig at you etc.. just explaining my process as everyone who sees the car says "oh this wont pass... or you need to do this... or this is the only way"
i want the knowledge of knowing that i can cruise down the road and the car not only be safe for me and my family but pass legally and if i get a defect that it can easily be driven down and removed
#54 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 19 December 2015 - 10:46 AM
Impressive.
#55 Bigfella237
Posted 19 December 2015 - 01:11 PM
 ~ also this is not a dig at you etc.. just explaining my process as everyone who sees the car says "oh this wont pass... or you need to do this... or this is the only way" ~
No problem at all, I wasn't having a go or anything, I'm just really interested in pushing the engineering envelope myself (and you're certainly doing some pushing with LoHla)!
I get that you're all over the engineering side of things, I was just looking for more information than "my engineer says it's okay" because, as we all know, (to paraphrase Sol from the old Castrol ads) 'engineers ain't engineers'.
Sounds like you're lucky to have found one who's prepared to think outside the box.
#56 orangeLJ
Posted 20 December 2015 - 08:17 AM
Thankyou!
For doing something about the column.
So many of the retro-mod dash swaps leave the standard column shrouds. Looks so out of place once finished.
Pretty amazing build. Well done.
#57 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 21 December 2015 - 06:34 AM
Thankyou!
yes well i think along the same lines as you orangeLJ...  looks out of place when there is a gaping big hole round the column
Started fabricating up the tunnel cover ... we did just enough so can start on the HVAC install .....  also welded in all the top VE seat mounts/brackets - will do the underneath another time
Made the VE brake pedal potentiometer/switch bracket (same will need to be done to the clutch pedal when installed)
Coil bracket made up for the drivers rear coil to clear the booster
#58 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 21 December 2015 - 07:35 AM
G'day Justin
Do you have any other pics of the mod to the coil bracket
I am just playing with this as we speak
Cheers Kevin
#59 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 21 December 2015 - 08:07 AM
G'day Justin
Cheers Kevin
the under side of the coil bracket
#60 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 13 January 2016 - 11:41 AM
Back from holidays so decided to purchase a Mal Wood underdash clutch master/pedal asm.
test fitted
then modified it to have a VE pedal pad
then made a bracket asm for the VE Accelerator pedal and bolted all in
#61 _LS1 Taxi_
_LS1 Taxi_
Posted 13 January 2016 - 01:15 PM
Very tidy!
#62 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 16 January 2016 - 04:33 PM
another challenge faced was incorporating a switch into the car for the electric handbrake setup. Decided to go with a VF unit
Managed to get hold off a mate who lives in the US a RH side blanking plate (which is where an aussie's handbrake goes)
Made up an alloy plate to fit the handbrake switch
all fitted now ready for trimming
#63 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 16 January 2016 - 05:04 PM
Biggest job to date was trying to get the HVAC unit to fit having the AC Evaporator still in the factory spot along with heater core and having dual zone, front demist and face vents... if it didn't fit it would have been onto another plan of making the controls fit an aftermarket unit.. but persistence pays off and all in they with a custom top duct made to route both face and front demist through the top of the unit.
HVAC modified from single zone to dual zone and then cut down to fit into Torana
Unit in now and brackets all made
#64 _Bomber Watson_
Posted 16 January 2016 - 06:39 PM
As much as I hate the principle of this build, and will likely hate the finished product, your workmanship astounds me and makes me keep coming back for more.
Fantastic work.
#65 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 16 January 2016 - 07:18 PM
yep I know that many true torana people will hate this build all the way to their grave... and I am fine with that.. I am 43 and have loved Toranas since I remember Brocky driving them round Bathurst (I was 6) and have owned 2 Hatchbacks before... first was a build to resemble a A9X cause I love them.. the second took a similar but not his far turn to modern (efi engine power windows walkinshaw wheels)... this one though is made to suit me and I know others are fine with it as well...   I just didn't want a plain jane build cause I know when I go to car shows (toranafest was a perfect example) I just walk past all the stock looking ones cause they just don't stand out... its cruel to say but its very hard to see how much hard work would have gone into them as they all look the same and are just different colours, any way that's my opinion.. and everyone is allowed theirs ...
and thanks for the praise... keeps me and my dad off the streets on weekends   :)
#66 _Bomber Watson_
Posted 16 January 2016 - 07:22 PM
Well said mate.
I personally hate late model commy seats and dashes in Toranas, and Fail to see why you would start with a nice light car then add 400kg worth of electric seats/hvac/etc to it.
But if you like what you have envisioned as a finished product, and building it is keeping you happy, then cudos to you, as your a lot better off than most people.
#67 Ice
  • 15,221 posts
Posted 16 January 2016 - 07:36 PM
Keep going cant wait to see the finished product i for one love your idea
always good to be different look at Bomber
#68 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 16 January 2016 - 08:01 PM
Absolutely love this!!
#69 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 16 January 2016 - 08:07 PM
Thanks Ice...   you and me both LOL... its progressing along nicely now.. the HVAC prob took a good 2 weeks to nut out the most of it.. the console is the next step and will be a fairly intricate piece to the puzzle as it has to house a lot of different parts for this to all work...
Thanks Barry... as I said .. I know there are some out there that like the idea :)
#70 cameron
cameron
  • 371 posts
  • Name:Cameron
  • Car:LX SS Hatchback
Posted 16 January 2016 - 11:01 PM
Curious as to what it aprox will weigh at rego time?
Cameron
#71 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 17 January 2016 - 07:39 AM
Would have no idea and not worried at all. Weight is going to worry it with an LSA engine anyway
At a guess be round the 1400 mark maybe over a little
#72 bob2s
bob2s
  • 2 posts
Posted 17 January 2016 - 10:01 AM
As Justin wrote "weight is not a worry with the LSA", may even delay the onset  of burning rubber smell  !   :D
#73 cameron
cameron
  • 371 posts
  • Name:Cameron
Posted 17 January 2016 - 11:57 AM
Fair enough I thought maybe you had a target weight for rego. Looking at your photos you do very nice work. Having seen lots of LS based Torana its tough work to get it right. No doubt with 6.2l supercharged it will go a lot better than my 308.
Cameron
Edited by cameron, 17 January 2016 - 11:57 AM.
#74 _LS1 Taxi_
_LS1 Taxi_
Posted 17 January 2016 - 03:36 PM
I'm one of the one who doesn't get excited over stock cars.
I love customising, therefore, I love this build.
#75 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 17 January 2016 - 07:07 PM
Restoration certainly has it's place but doing your own thing is way more fun.
