LoHla
173 replies to this topic
#151 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 17 June 2017 - 09:32 AM
Honestly don't know if there will be enough room or not. Will cross that bridge when I get to it. The good thing is my mate who will make the exhaust is the one who made the cross member so all will be an easy fix.
#152 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 02 September 2018 - 09:25 PM
Thermo fan shroud made and mounted
#153 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 04 September 2018 - 07:37 PM
Nice work Justin, cowl looks neat and very enclosed.
Which radiator is under it? Is it a Commodore type?
Nice to see the engine sitting in the bay
Is that a VN booster?
Cheers, Tom
#154 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 04 September 2018 - 07:41 PM
Yes commodore
Booster is a cross between an XA (rear)!and a LH (front) from memory with LX push rod. Made by Hydroboost
#155 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 04 September 2018 - 08:32 PM
Don't know why but for some reason I presumed a Commodore radiator wouldn't fit in a Torana, well done.
#156 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 31 May 2019 - 09:21 AM
been a while since any work or updates - work getting in the way along with waiting for a mate to have time to do a bit more welding/pipe work
headers made - once given final nod they will be removed and fully welded.
#157 Bigfella237
Posted 31 May 2019 - 04:47 PM
Never seen it done like that before... I wouldn't have thought you'd have enough ground-clearance to run the primaries under the outriggers like that?
#158 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 31 May 2019 - 06:11 PM
you need to get out more :) most shops that run 1 7/8" primaries 4 into 1 do it that way...  1 3/4 amd tri Y's dont need to
although i did work on a car with 1 7/8 all through the normal position but was a nightmare with the steering and concentrates alot of heat on the starter etc...
#159 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 31 May 2019 - 10:45 PM
Been looking forward to an update, well done Justin!
Headers look too good to use, I would have liked to fit the cats where you did but I didn't realise that until I finished and it was too late
Which lower control arms do you have?
Cheers, Tom
#160 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 01 June 2019 - 07:54 AM
Thanks Tom. They are McDonald Bros. Top and bottom arms. Bought them because it allows me to not shim to do the wheel alignment as I need the room because of AC compressor. But they weren’t cheap :(
#161 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 01 June 2019 - 02:33 PM
mocked up a fuel tank out of thin MDF board .. made it to size i wanted (around 70L) and has a step in it to allow fitment of a space saver wheel on one side and also has the cut out for a drop in VF MRA unit
#162 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 01 June 2019 - 02:47 PM
Great to look at the progress. Well done.
#163 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 01 June 2019 - 08:41 PM
No shims to do the wheel alignment, do they have some sort of eccentric adjustment?
What is that Moroso accumulator under the guard? Vacuum?
#164 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 02 June 2019 - 12:11 AM
No shims. Runs rose joints that are adjustable front and rear. The Moroso acumulator is for oil. Dumps are way to small on a torana for LS. They run 8L on LS ‘s. And bigger on LSA’s. This way I know that st the end of a dyno run or drag strip I am not purging the limit and about to run out
#165 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 02 June 2019 - 10:15 AM
Great way to mock up tank. Im gojng to borrow that idea.
#166 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 02 June 2019 - 11:28 AM
Thanks for the answer Justin,
Great build!
#167 Heath
  • 18,393 posts
Posted 03 June 2019 - 11:39 PM
Hectic fabrication work. Love it.
But there's no way in hell any Torana I've ever owned could run a primary pipe under the outrigger like that. The standard rear-mounted swaybar is bad enough for trying to get ripped off when I drive over shit, but maybe you run at a very different height to me.
#168 myss427
myss427
  • 1,636 posts
Posted 04 June 2019 - 08:31 AM
I have remade extractors for mine more than I can count trying to get ground clearance. My pipes are 2 1/8 primaries into 3.5 inch collector, I have 10mm clearance to the floor, just enough room to squeeze a heat mat in there and I still cant get more than 90mm ground clearance unless I jack the coil overs up. You will be riding very high with those pipes to not scrape.
#169 Shiney005
  • 9,604 posts
  • Car:Toyota Mirai
Posted 10 September 2019 - 09:40 AM
How is this coming along Justin?
#170 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 10 September 2019 - 09:45 AM
yes have done a bit more (mainly boot area .. boxing in. plus have new diff centre installed and spoken to trimmer
#171 adrianh08
adrianh08
  • 219 posts
  • Name:Adrian Haynes
  • Car:1974 LH
Posted 06 May 2020 - 09:09 PM
Bloody great thread. I hope the car is continuing to progress.
#172 Doubledip
Doubledip
  • 95 posts
  • Name:Justin
Posted 06 May 2020 - 09:13 PM
Yes it is. But don’t update on here anymore .
#173 jeffblanco
jeffblanco
  • 388 posts
  • Name:Mando
Posted 07 May 2020 - 08:03 AM
WHY?
#174 horsepowerhowie
horsepowerhowie
  • 90 posts
  • Name:Howie
Posted 08 May 2020 - 12:56 PM
I second that tank mockup too, great idea and 70L tank is gonna look sharp.
