Liquid intelligence 115
6 replies to this topic
#1 _nodster_
_nodster_
Posted 21 December 2015 - 01:25 PM
Is anyone running this waterless coolant liquid intelligence 115 in their 202 holdens
#2 _Bomber Watson_
Posted 21 December 2015 - 02:25 PM
THeres a very very long winded thread on waterless engine coolant somewhere, Dave will be along later to link you probably.
End of it everyone was pretty divided, half thought it was a waste of money, the other half seem to have way to much money to waste.
#3 _ljxu1torana_
_ljxu1torana_
Posted 21 December 2015 - 04:25 PM
coolant is for alloy head and corrosion.it dosenot make your car run any cooler.
#4 _LS2 Hatch_
_LS2 Hatch_
Posted 21 December 2015 - 04:54 PM
Gives us the reasons you are thinking of using it, and someone will give you reasons against for the same reason.
As noted above, it's a great idea if you have alloy components and the engine sits for long periods without being ran. If it is for normal useage on a regular used engine, there is basically no reason to use it.
The thread did give some good reasons both ways, but as I said, why are you considering it?
#5 N/A-PWR
  • 9,639 posts
Posted 21 December 2015 - 06:44 PM
Here DJ:-
http://www.gmh-toran...erless-coolant/
#6 ls2lxhatch
  • 5,332 posts
Posted 21 December 2015 - 08:17 PM
The above thread was about Evans waterless coolant which was proven to have higher corrosion rates and lower cooling capacity than water with no-rosion added.
Liquid Intelligence 115 is a different product to Evans waterless coolant. It may have the same problems as the Evans product or it may actually be better. Only independent testing, as was done with the Evans product would prove it one way or another.
#7 _LS2 Hatch_
_LS2 Hatch_
Posted 21 December 2015 - 08:51 PM
I was sold on using the Evans product. It was you Andy that pointed out a few very good points that steered me clear. With the amount of times I have dropped my water for various reasons, I am now very thankful for that advise.
