2 inch SU info
219 replies to this topic
#126 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 08 March 2016 - 08:34 AM
Warren i have another set of HS8's here and they are all Jag items, & they all open to 100%.
They have the needles BAW x 2, BBC x 1 in them, but these are all still .100" swing.
Are they supposed to be .125" standard?
I'm guessing not as i doubt you would bother going from a .125" fixed to .100" swing on a HS8?
SU Midel do a needle conversion kit but this is for turning fixed needles into swing:
http://www.sumidel.c...-bush-and-screw
#127 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 08 March 2016 - 10:10 AM
The later model carbs were spring needles. You can convert your carbs to take a fixed needle by getting a bush made similar to the link for Midels. I haven't got any 2" carbs with spring needles to compare with, but the Midel pic almost looks like it might convert from spring to fixed, not the way it is listed, not sure why you would convert to spring needles, there's a better choice with fixed, maybe a phone call to Midels to confirm.
#128 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 08 March 2016 - 11:57 AM
Agreed. I thought it was the other way around when I saw the pic too, worth a phone call.
Do I need to get a main jet to suit the .125" needles or can the one for the .100" stay?
#129 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 08 March 2016 - 12:34 PM
And we're right, after a phone call to Midel those conversion kits will allow for a fixed needle to be fitted.
#130 warrenm
warrenm
  • 2,117 posts
Posted 08 March 2016 - 10:55 PM
I have successfully drilled .090" jets out to .125" which are still in the HS8's that I have, they ran the car to 13.2 over the 1/4 until I fitted the HD8's so I could run alky.
I didn't think they looked right.
#131 N/A-PWR
  • 9,639 posts
Posted 08 March 2016 - 11:14 PM
Mate , that is information Warren.
Like button for you too.  :clap:  :spoton:
#132 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 08 March 2016 - 11:52 PM
Cheers Waz,
So all up, i'll have to get 2 of my lids machined, three matching .125" needles with conversions, possibly new jets(but haven't checked them yet), carby kits, and look into getting 30 degree angled fuel bowls....
Not much if you say it fast I guess!
#133 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 09 March 2016 - 06:06 AM
I just bought all of the above from SU Midel Jonesy and it was quite reasonable. $300-$400 will get you it all for the three carbs.
Just curious, but do you recall what mph you ran with them ( the HS8s with drilled jets) back then Warren? Also, what tyres were you using then- was it still full slicks?
#134 warrenm
warrenm
  • 2,117 posts
Posted 09 March 2016 - 08:41 AM
What manifold are you using Jonesy? You may get away with a slight mod the the bowl pivots, whilst not technically ideal it works, that's what I had with the "Torana" Armours.
LC-GTR-1969
101.22mph with 235/60x15 M/T drag radials.
#135 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 09 March 2016 - 08:47 AM
I have the 30 degree armours Warren, which looks like it might need a bit more than a tweak.
#136 _Bomber Watson_
Posted 09 March 2016 - 10:36 AM
The only real difference is the carb flange is turned down 15 degrees on the other armours, would be pretty easy to do?
#137 warrenm
warrenm
  • 2,117 posts
Posted 09 March 2016 - 11:49 AM
This is the "Torana" version.
Attached File  P1020111 (600 x 450).jpg   73.91K   4 downloads
#138 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 09 March 2016 - 06:47 PM
LC-GTR-1969
Great, thanks! Was that time with about 1.8-1.9 60 foot? Sorry, just curious and comparing this to my current mph etc to my times, which I need to work on.
Edited by LC-GTR-1969, 09 March 2016 - 06:48 PM.
#139 warrenm
warrenm
  • 2,117 posts
Posted 09 March 2016 - 10:53 PM
1.8/1.9 sounds about right.
#140 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 18 April 2016 - 05:47 PM
Bit of an update...
So it has been very busy round here, and I have a few projects on the go, but I have started rebuilding my 2 inch SUs... got 2 out of three done.
Firstly, what a great carb to rebuild. Marvellously simple. No need to even refer to a manual or anything they are just so straight forward.
I will need to wait a while now though as unfortunately I have a hole/ crack in one of the fuel bowls from an accident, but I have ordered a new bowl from the UK- not expensive, 40 bucks or so, but it will take a while to arrive I imagine.
I want to port out the warnerford manifold as much as I can to match the 2 inch carb (they are designed for 1 3/4 carbs by the look of it). However, i have to find my die grinder first. STuffed if i know where it is...
#141 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 18 April 2016 - 07:20 PM
They sell a bush with a grub screw to convert to fixed screw. I have some here as I needed to convert mine. Not expensive and easy to setup.
I will try to get a pic and will post back.
#142 _ljxu1torana_
_ljxu1torana_
Posted 18 April 2016 - 09:29 PM
a friend of mine has a set of 2 1/2 inch su on his eh holden they might be of a old jag,his manifold is the g t x stamp on it.
#143 warrenm
warrenm
  • 2,117 posts
Posted 18 April 2016 - 11:54 PM
Bit of an update...
Parts from the UK generally turn up reasonably quick.
Not sure about 2 1/2" but there was a 2 1/8" fitted to some Jags.
#144 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 20 April 2016 - 02:26 PM
Gday again, the rebuild is progressing nicely... still a few things to do but waiting on the new fuel bowl so no rush...
[/URL]">http://IMAG1231%201.jpg
I havent polished things to the enth degree as at the end of the day I am just experimenting with the 2 inch SUs. Iff I fall in love with them, I will probably improve the finish on them. I soda blasted them and gave the dashpots a quick rub with wet and dry but thats it for the exterior.
The internals are all new though.
Quick question... As I am running a warnerford, which I know is a little short so not ideal (but its what I have and it came with the carbs- so I figure I may as well just use it for now), I was thinking of making some extenders for the manifold out of some plate and allum. pipe to effectively lengthen the manifold say 2 inches... However I then remembered that some spacers came with my box of parts- i havent cleaned these up at all yet as I wasn't sure whether I would be using them...
Here are some pics of them;
[/URL]">http://IMAG1233.jpg
[/URL]">http://IMAG1234.jpg
I figure that these spaces could be good for increasing the runner length... With the spacers, plus 3 inch bell mouth trumpets (which I will be buying from SU Midel), the runner length from the face of the manifold to the end of the bell mouth will be 14 inches. Not sure exactly of the measurement to the valve though, maybe 17 inches?
So my question is, what is the ideal runner length for peak power at 6000rpm and a powerband between 4-6500rpm? I have seen phenolic spaces for 2 inch carbs from the UK so it would not be hard to extend the length a little more if needed.
#145 N/A-PWR
  • 9,639 posts
Posted 20 April 2016 - 02:35 PM
Great stuff,
 longer manifolds are used for more torque and high rpm,
 and 8 inch long armours are able to be purchased for $650.
Edited by NA-PWR, 20 April 2016 - 02:35 PM.
#146 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 20 April 2016 - 03:06 PM
Longer manifolds should make more Torque and shorter manifolds should make more top end power but each engine combo will like different lengths depending on which part of the rev range you are tuning for. Just see how u go with what you have.
#147 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 20 April 2016 - 03:16 PM
Cheers Mick, thats my plan so far...
Great stuff,
Cheers Dave but as this is just an experiment and some R&D at this stage I am not really keen spending more than I need to at this stage, hence I will stick with the warnerford for now. Unless someone wants to swap some 'torana' armours for my warnerford? (Unlikely I know but i'll try my luck LOL).
#148 _Bomber Watson_
Posted 20 April 2016 - 03:44 PM
Wha?
#149 N/A-PWR
  • 9,639 posts
Posted 20 April 2016 - 05:10 PM
Here DJ,
are now made to order, from $688:-
http://www.revheads....lds_holden.html
Wha?
to suit 1 3/4" or 2" SU's.
#150 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 20 April 2016 - 05:23 PM
Here DJ,
Its handy to know that you can get the made up if needed. What do armours go for on the second hand market?
