Project LSX 454
72 replies to this topic
#51 myss427
myss427
  • 1,636 posts
Posted 23 March 2016 - 08:16 AM
Yes he made the mold from A9X 4 door flairs, which he joined together and put a hatch lower section on. Talked to him about it when I got mine.
#52 _Viney_
_Viney_
Posted 04 April 2016 - 08:14 PM
Talked to Fat Pipes today, cars been fitted with 17/8 extractors and 31/2 inch twin exhaust. System will be a full system including tail pipes, will be able to remove tailpipes and dump before the diff for the strip! Cannot wait for start up!! I will keep you updated.
You guys are right! Cannot buy wide flares anymore, looks like I'll be making my own!
#53 _Viney_
_Viney_
Posted 09 April 2016 - 07:45 AM
#54 _Viney_
_Viney_
Posted 09 April 2016 - 08:15 AM
Fat Pipes finished extractors Wednesday, off to the coaters! Excellent job by these guys, great to deal with. Each extractor is in two pieces 17/8 primary's into 31/2 pipes!!
#55 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 09 April 2016 - 08:25 AM
Hi Chris,
Great build you are doing.
Those pipes look fantastic!
#56 _LS1 Taxi_
_LS1 Taxi_
Posted 09 April 2016 - 08:33 AM
Yep, horn pipes.
#57 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 09 April 2016 - 12:22 PM
Nice build. Fat tires under a LX Hatch does it for me!
#58 _Viney_
_Viney_
Posted 10 April 2016 - 11:36 AM
Decided to leave the hatch in Brissy for a couple more weeks and get some extra work done!
Getting bored while the hatch is away so have pulled the SLR out and continuing with its resto!
Tunnel work above, previous owner moved the hole for the shifter back and stuffed up the tunnel. I was going to fit a donor tunnel, but decided to tidy it up and fit a T5
#59 _Viney_
_Viney_
Posted 10 April 2016 - 11:40 AM
Rebuild 308 about to be fitted!
Funny 308 that one!!
#60 _Viney_
_Viney_
Posted 10 April 2016 - 11:55 AM
image_zpsieyjacev.jpeg[/URL]
I give up!!!
#61 _Viney_
_Viney_
Posted 10 April 2016 - 01:40 PM
#62 _Viney_
_Viney_
Posted 10 April 2016 - 01:45 PM
And it is in, and I got the photos sorted!
#63 _Viney_
_Viney_
Posted 16 April 2016 - 05:21 PM
New coils, shocks, diff done, only a banjo, new wheels and tyres!
#64 _mello92_
_mello92_
Posted 15 May 2016 - 08:15 AM
How do they recommend sealing the primary pipe to the collector? Fantastic build by the way!
#65 _Viney_
_Viney_
Posted 16 May 2016 - 07:40 PM
Tell you the truth, I don't know I never ask, it was a suprise when the car turned up. Each extractor is made up of 4 individual pipes, as you can see they are tuned and have to be fitted in order to get the setup in position, they go to 3 1/2 to the muffler and then go to 3". All up including coating $4500. Not bad I thought!
#66 _Viney_
_Viney_
Posted 16 May 2016 - 07:44 PM
#67 _mello92_
_mello92_
Posted 16 May 2016 - 09:00 PM
Damn that looks good. Very reasonable price judging by the pictures.
#68 _kayesem_
_kayesem_
Posted 17 May 2016 - 09:38 PM
squishy!
The only good system is a sound system : )
#69 orangeLJ
Posted 18 May 2016 - 04:46 PM
Generally we fit with a bead of high temp silastic. That combined with ten generally being a tolerance fit, plus a bolt/slide tab to hold the pipe in place.
We don't usually get many leaks
#70 cameron
cameron
  • 371 posts
  • Name:Cameron
  • Car:LX SS Hatchback
Posted 18 May 2016 - 08:27 PM
Headers look fantastic. Fat pipes do some very nice work, for such quality it is well worth the $$ and when coated they look amazing. I used the aeroflow slip on collectors in a 2" to 3.5" collector and with interference fit you get zero leaks. After you coat the fit is very tight but we still put on retainer tags, bolt-able flanges and o2 tuning bungs.
With the LSX your hatch will go very well.
Cameron
#71 myss427
myss427
  • 1,636 posts
Posted 19 May 2016 - 10:33 AM
The only thing I would worry about is ground clearance on the pipes that go under the cross member, but they look very well made.
#72 IMORAL
IMORAL
    Bored
  • 2,568 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 19 May 2016 - 01:11 PM
Scott Rods did my set the same a few years back. 1 7/8 primaries to twin 3" All individual pipes and same collector.
I thought they would leak too but somehow they don't. I put anti seize on mine to make the collector come off easier because it was a real Cunning Stunt the first time I had to remove it.
Are you getting it dyno tuned? I'm interested to see the figures for RWHP as I have a similar drive line and I've always worked it out around 28% loss
Looks like it will be fun regardless of the number. I bet you're busting to go for a spin ;)
#73 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 24 May 2016 - 06:23 AM
Had the pipes on my challenger done by fat pipes. Awesome to deal with and do a great job.
