Hi guys
Ive got a stock 202 in an HZ wagon, and it has a stock stromberg carby on it. Im in the process of installing a flashlube kit and am struggling to find a place to connect the outlet hose so that the upper cylinder lube actually gets sucked thru.
There are 2 ports on the carby (that face the rocker cover) that have been blocked off. I tried each of these but there is not enough vacuum to draw the fluid thru.
So where can I connect this so that it works?
The only other place i can see is the dizzy advance vacuum lead that plugs intot he base of the carby. Can i put a "T" piece into this or will it cause issues if I plumb into it?
