Shed Insulation
124 replies to this topic
#76 hanra
  • 10,936 posts
Posted 16 December 2020 - 07:09 PM
Yeah it’s all concrete. Was also thinking of hiring a scissor lift if I end up lifting sheets. Or if I try attaching it underneath to the battens. .
#77 LXCHEV
LXCHEV
  • 3,548 posts
  • Car:'76 LX - 383 Chev
Posted 17 December 2020 - 08:52 AM
I'm keen to understand a bit more about the box looking ridge vents - how do they work compared to the older style spinners?
#78 hanra
  • 10,936 posts
Posted 17 December 2020 - 09:03 AM
Just based on convection. The spinners tend to fly off roofs during cyclones. You have to get up on the roof and cover them up with a few wheelie bin bags prior to a cyclone.
https://www.andyssheetmetal.com.au/
Edited by hanra, 17 December 2020 - 09:04 AM.
#79 LXCHEV
LXCHEV
  • 3,548 posts
Posted 17 December 2020 - 09:56 AM
Quite interesting - I certainly don't mind the look of them.
#80 hanra
  • 10,936 posts
Posted 17 December 2020 - 10:06 AM
For a house you also need to have eave vents obviously so air can be drawn in. Sheds are not as air tight I imagine!
#81 hanra
  • 10,936 posts
Posted 17 December 2020 - 10:13 AM
This is the Ridge Vent that I fitted to my old shed. Ive seen some installation where this takes the place of the ridge cap in that section. But I just added this over the top of the existing ridge cap and cut out a section for the throat.
Edited by hanra, 17 December 2020 - 10:14 AM.
#82 dudley
dudley
  • 83 posts
  • Name:Wayne
Posted 17 December 2020 - 12:18 PM
Try this guy for DIY insulation. He lives in your state of QLD. Brilliant stuff and so easy to install, no lifting any sheets, its all magnetic strips! Highly recommend to anyone.
www.shedinsulationdiy.com
Here is a picture of my shed. I have since insulated the roller doors as well. Its now at least 12 degrees cooler inside.
cheers,
Wayne
#83 RallyRed
  • 8,109 posts
Posted 17 December 2020 - 01:49 PM
Love the cars.
That product may be really useful to me mate.
I have been exploring insulation for our double width panel lift garage door.
The door cops full sun until around 11 am, that means the garage is hot as hell even before the day heats up.
Have been looking at the spray on coating and the push in Esky foam type stuff.
Your product looks good, and simple, as long as the magnets don't loose strength over time?
#84 hanra
  • 10,936 posts
Posted 17 December 2020 - 02:01 PM
Must be rare earth magnets. Would have to be strong?
#85 hanra
  • 10,936 posts
Posted 17 December 2020 - 02:08 PM
Got any pics of your ceiling?
#86 dudley
dudley
  • 83 posts
  • Name:Wayne
Posted 17 December 2020 - 02:24 PM
Thanks Col, I love my cars too!
Yes it is a cheap and easy method to insulate both the shed roof, walls and the roller doors. Check the link I attached earlier and watch his videos of how to install the insulation. Great product and great service. It IS so effective and will address your roller doors. And Brad, yes they are rare earth magnets on metal strips ( you can cut to size). He even supplies additional small spare magnets for any tight spots, such as roof spinners.  I get a lot of strong winds where I am and the magnets/insulation have not been affected. As mentioned I would recommend to anyone. My best investment apart from the hoist. :D
Wayne
#87 dudley
dudley
  • 83 posts
  • Name:Wayne
Posted 17 December 2020 - 02:32 PM
Brad, here is a picture of the roof and the roller doors.
Wayne
#88 Ice
  • 15,190 posts
Posted 17 December 2020 - 05:34 PM
Mine is a Colourbond 6x9 shed its like 50 to 55 degrees inside  on a good hot day
i need to this so bad
#89 yel327
  • 13,597 posts
Posted 17 December 2020 - 06:04 PM
My roof is really high (like 5-6m) and so are the roller doors. Roof is insulated but it does get very hot up on the mezzanine still. If I have the doors open and have the BAF running it is bearable up to about 35deg. Today was only 30 but near 95% humidity, bloody awful anywhere!
#90 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 17 December 2020 - 07:46 PM
I have Air - Cell Glaresheild insulation in my sheds apart from the smallest 1, my Brother has the same, now it's not cheap, i think a 36 square shed is around $2,200 to purchase enough to complete, but the temperature reduction is worth every cent. Cheapest here to buy through any shed builder's. Another thing popular with the car guy's here is the solar powered whirly birds, the hotter the day, the fast they spin. I've heard of in ceiling cavity reductions of 21° & 12° in an outdoor area. Certainly things to consider.
#91 hanra
  • 10,936 posts
Posted 17 December 2020 - 08:03 PM
I used Kingspan Glareshield XL in my last two sheds. I got my rolls for $290 cash from the shed shop. Each roll does 30sqm.
Edited by hanra, 17 December 2020 - 08:04 PM.
#92 dudley
dudley
  • 83 posts
  • Name:Wayne
Posted 17 December 2020 - 09:33 PM
Gene,
The lightweight foil blocks 98% of the radiant heat which is the massive contributor to the overall heat rise inside any shed. Apparently they made this stuff for the Astronauts to wear for their spacewalks. FYI - Adelaide had a 48 degree day earlier this year and the inside air temp reached 33 degrees with the doors closed. I don't have to worry about the interiors of my cars melting anymore, especially the one parked on top. The cars are also cool to touch.
Wayne
#93 Ice
  • 15,190 posts
Posted 17 December 2020 - 10:19 PM
Cheers Mate im gunna look into it
#94 dudley
dudley
  • 83 posts
  • Name:Wayne
Posted 18 December 2020 - 01:50 PM
By the way, my shed is identical in size to your shed 9 x 6 metre, colourbond green. I managed to insulate the entire roof, two roller doors and several walls that were exposed to direct sunlight, and then whatever was left over I did my 3 x 5 tool shed roof. In total it cost me $1,100 and the only things I had to do was cut the foil to size, cut the magnetic strips to size and attach it. Probably take you a day to do.
Wayne
#95 8BALL
8BALL
  • 187 posts
  • Name:..
  • Car:yep
Posted 22 December 2020 - 07:59 AM
The issue with the magnetic strips tho can be seen after a few weeks/months.
If you go outside the shed and look closely you start seeing little circles of metal shavings etc that stick to the outside of the shed to the magnets. Then they start rusting and staining the outside of the shed etc.
#96 Rockoz
Rockoz
  • 4,018 posts
  • Name:Rob
Posted 22 December 2020 - 09:39 AM
Is the foam insulation fire rated though?
Pretty sure its the stuff that turned a couple of high rise buildings into super candles.
Would be checking on it, and check your insurance policies to see if they have added any fine print excluding it from their liability.
Rob
#97 hanra
  • 10,936 posts
Posted 22 December 2020 - 09:59 AM
Fire Testing on the Foilboard stuff.
Edited by hanra, 22 December 2020 - 10:00 AM.
#98 xu1kid
xu1kid
  • 364 posts
  • Name:anthony
  • Car:lj gtr xu1
Posted 24 January 2021 - 10:33 PM
Love the cars.
hey mate i install panel doors and roller doors , go to bunnings and buy the sheets of foam with silver back cut them out and slip in your panel door ,bit of silicon dab on back, dont add to much weight to door as u will need springs retensioned
#99 RallyRed
  • 8,109 posts
Posted 25 January 2021 - 05:30 AM
Thanks for tbe info.
As I seem to go to Bunnings 3 times a week, I'll check it out. Thanks again.
Edited by RallyRed, 25 January 2021 - 05:30 AM.
#100 hanra
  • 10,936 posts
Posted 25 January 2021 - 08:02 AM
https://youtu.be/_grGQV3bbDI
