Shed Insulation
124 replies to this topic
#101 hanra
  • 10,986 posts
Posted 15 July 2021 - 09:32 PM
So I’ve ended up going with Foilboard. 60 sheets that are 1200 x 2400 x 20.
I’m starting to think it would have been easier to rip the roof off this shed. 2 bays took me 2 full days. And my neck is stuffed from working upside down and going up and down ladders for each and every screw….
This is going to take a while…… it’s hard going trying to do this on your own…
Edited by hanra, 15 July 2021 - 09:37 PM.
#102 yel327
  • 13,658 posts
Posted 15 July 2021 - 09:34 PM
Hire a scissor lift for a day. Worth every cent.
#103 hanra
  • 10,986 posts
Posted 15 July 2021 - 09:36 PM
Yep I just got a few quotes for 5 days. Range from $376 at Global Hire through to $1000 from Kennards. All for a 19ft lift.
I’m currently going up and down an 8ft and a 12ft ladder as it’s 4.1m at the peak, 3.3m at the gutter.
Edited by hanra, 15 July 2021 - 09:39 PM.
#104 Ice
  • 15,204 posts
Posted 15 July 2021 - 09:42 PM
Looks good
#105 hanra
  • 10,986 posts
Posted 15 July 2021 - 09:53 PM
I think having that 100mm air gap will allow it to perform pretty well. Instead of having it placed directly under the sheet of iron.
#106 yel327
  • 13,658 posts
Posted 15 July 2021 - 10:04 PM
Hire the scissor and get your light sockets and pendant chains and wires hung etc. even run compressed air lines.
What actually works well if you don’t have overhead obstructions is a semi-taut wire run across the shed between posts. Put some sliders on it (nylon or trolley like below link) and put a 15-20m heavy duty lead and compressed air hose along it hanging from the trolleys. Just loop the hose and lead so you can slide it back and forwards across the shed. A length of rope or plastic chain at the end with lead socket and compressed air socket so you can tie the two to it and so you can pull it along. Just put a GPO at the wall/fixed end of it and plug the lead in.
https://www.pacifich...-cable-trolley/
Edited by yel327, 15 July 2021 - 10:05 PM.
#107 hanra
  • 10,986 posts
Posted 15 July 2021 - 10:19 PM
That is a clever idea!!!!
#108 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 16 July 2021 - 10:00 AM
Brad, how much are you paying per sheet of the foilboard if you dont mind me asking?
#109 hanra
  • 10,986 posts
Posted 16 July 2021 - 10:20 AM
No one stocks the 20mm sheets up here. But Bunnings have 25mm sheets in stock. This changed a little. I’ve got 60 sheets and 3 boxes of fasteners. Looks like $47.87 inc GST per sheet.
Edited by hanra, 16 July 2021 - 10:22 AM.
#110 hanra
  • 10,986 posts
Posted 24 July 2021 - 07:51 PM
Scissor lift is certainly making the job more efficient. Still hard on the neck. Taking me a day to do 1 half a bay…..
#111 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 25 July 2021 - 05:19 PM
Looks great Brad- it's going to be a great set up when finished.
#112 RallyRed
  • 8,157 posts
Posted 25 July 2021 - 07:15 PM
Looks good mate, but it reminds me of how much I hate working upside down,
#113 hanra
  • 10,986 posts
Posted 25 July 2021 - 07:33 PM
Tell me about it…. I actually feel that it would have been an easier job to remove the roof and solar panels.
#114 hanra
  • 10,986 posts
Posted 25 July 2021 - 07:37 PM
Making a start in the other side now…. Never ending.
#115 hanra
  • 10,986 posts
Posted 28 July 2021 - 07:39 PM
Scissor lift has been returned. Best $376 I’ve spent. Sad to see it go. Had it for a week and made good progress. All the sheets are up that needed the lift. Also got all the LED lights fitted and wired. Next up is 5 new 1400mm ceiling fans. Might be a job for next weekend….. back on the ladder again….. doh!!!!
#116 RallyRed
  • 8,157 posts
Posted 28 July 2021 - 08:11 PM
$376 per week...bargain!
#117 hanra
  • 10,986 posts
Posted 08 August 2021 - 08:00 PM
Got 4 of the 6 new fans wired and hung.
#118 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 09 August 2021 - 11:59 AM
You going to do anything to the walls insulation wise?
#119 hanra
  • 10,986 posts
Posted 09 August 2021 - 01:03 PM
I should. And it will help a lot as the western wall on the right of the image gets hot. I removed some Kingspan foam type insulation that the previous owner had attempted to fit on the ceiling.... Im thinking of just screwing that to the walls. I think it will look a bit un-tidy though, the way it did on the ceiling.... The walls are East/West facing. The eastern face has 3 roller doors and 2 bays of wall. The northern face also has roller doors. So its only the 2 eastern facing walls and western facing walls that I could do anything with.
Edited by hanra, 09 August 2021 - 01:04 PM.
#120 yel327
  • 13,658 posts
Posted 09 August 2021 - 01:16 PM
Go around to a few building sites once lockdown finishes and see if you can get hold of left over roof and wall insulation. They normally have a few bales over ordered that get chucked. Either they’ll let you have it or have a few longnecks in the car as payment. Over three or four building sites you’ll probably get enough.
#121 hanra
  • 10,986 posts
Posted 09 August 2021 - 01:40 PM
Otherwise I was thinking of more foilboard on the walls...? Im just worried about it getting punctured or damaged.
#122 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 10 August 2021 - 12:17 PM
We did my mates with R3 bats behind 22mm particle board. Was expensive but was well worth it :-) Especially here in Canberra ...
#123 hanra
  • 10,986 posts
Posted 10 August 2021 - 12:38 PM
Thats the go. Can mount stuff to it then also.
#124 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 11 August 2021 - 12:09 PM
 It is also good for sound proofing. He now has a very cosy mancave with all his memorabilia mounted nicely :-)
#125 hanra
  • 10,986 posts
Posted 11 August 2021 - 12:38 PM
Any ideas on cost at all? A 2400 x 1200 x 20 sheet of Foilboard is $47. Just wondering what bats and particle board would end up costing?
