Speco Centre Shifter
Gearbox
13 replies to this topic
#1 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 14 March 2016 - 02:50 PM
Hello to All,
I have a very long project that will be finished soon I hope .
I have a BW super T10 in my lx hatchback .
If I use a speco centre shifter , does that mean I will not have to cut the tunnel to clear the linkages ?
Thankyou for your response .
If so I would like to purchase one of these shifters .
#2 SS hatch
SS hatch
  • 104 posts
Posted 15 March 2016 - 09:34 AM
Is possible with minimal cutting stretching and linkages can be reversed or remade shifter mechanism leads to console cutting. The mechanism needs space being fitted to side of rear extension housing. with some remade linkages and shifter engineered to bolt closer to housing you can sneak shifter in without cutting console which I recon is the worst part of install. Mines a  Hurst / Mr gasket with shifter bridged to center.
#3 _LS1 Taxi_
_LS1 Taxi_
Posted 15 March 2016 - 11:31 AM
Buy this.
https://www.ebay.com...tm/272166751708
#4 76lxhatch
  • 7,208 posts
Posted 15 March 2016 - 12:42 PM
The linkages will still need re-working to suit as they run on the opposite side to the Aussie 4 speed linkages where there is less room.
As above it is also possible to use a Hurst shifter with some modifications.
#5 Ice
  • 15,204 posts
Posted 15 March 2016 - 07:57 PM
Buy this.
Bit rich Wayne
#6 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 15 March 2016 - 08:58 PM
Hey Guys, Thankyou for the input , I do have a hurst shifter on there atm . Have purchased the bent shifter handle and 4spd knob . Was just hoping not to have to do any tunnel work . Its off to the mechanic in two weeks to be finished . Is a hole cut in the tunnel such a bad thing if done well ?
#7 Ice
  • 15,204 posts
Posted 15 March 2016 - 09:02 PM
If done neatly no
#8 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 15 March 2016 - 09:07 PM
Bit rich Wayne
gene if you want the bit,s you gotta pay the price
otherwise we would all be driving around in XU-1 torana,s
or A9X hatch backs that we only paid $1000.00 for
and that,s what makes a genuine car worth every cent
may it be wright or wrong it,s the reallity of demand!
if you want it buy it
as everything is only worth what someone will pay
i,ve paid alot for bit,s and considered everyone of them an absolute bargain
#9 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 15 March 2016 - 09:09 PM
I suppose my question is . Buy the centre shifter and have the mechanic work his magic or work with what I already have and get over it . This car has sat in my container for many years because I purchased the gearbox with the motor . I think it would be nice to drive with this combo ? . I could have just purchased a 4 speed anywhere but the T10 is a good box .
any feed back will help
#10 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 15 March 2016 - 09:47 PM
Hey guys , thanks again for your time . Should I send my car to the mechanic with the Speco Centre Shifter ?  or with the items I already have ?
Will post a pic of car when finished .
#11 76lxhatch
  • 7,208 posts
Posted 16 March 2016 - 05:27 AM
If you're paying for the time to do the modification work then the Speco shifter is probably still cheaper, even at that price. The Hurst shifter will be stronger/better quality but if poorly modified you could lose that advantage.
Tunnel mods don't matter too much but the main thing is to get it inboard far enough that it doesn't interfere with the console if you're planning to have one.
#12 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 16 March 2016 - 07:23 AM
Thanks for the information guys , I will bid for the speco shifter and if I win will send it with the car . If I don't win then car gets sent without . that way its up to the gods on how it will be finished .
I really do thank all for there time and efforts on replying on my thread .
I don't have any other torrie mates to reflect ideas , now I have joined this forum I feel that I do have torrie friends .
I should have joined 13 years ago
#13 SS hatch
SS hatch
  • 104 posts
Posted 16 March 2016 - 08:35 AM
My original install had tunnel cut to accept mechanism. Then a open sided box flanged to bolt screw to tunnel .This covered in carpet and console cut around  box protruded out the side of console maybe 25mm.Hardly noticed it but removing console required box removal prior. All this done at home with a arc welder grinder drill. Now having more toys the box is gone with a new uncut console it helps to have good tooling making the finished project as it can be done in a professional workshop.
#14 _Mox_
_Mox_
Posted 16 March 2016 - 08:55 AM
If done neatly no
You should of been banned from talking about tunnels Geno, moderators can you please fix this up,
Also tagged with one or more of these keywords: Gearbox
