A9X Hatchback Tribute build
110 replies to this topic
#51 Heath
  • 18,365 posts
Posted 21 April 2016 - 10:48 PM
Sweet!
#52 308 Sunbird
308 Sunbird
  • 972 posts
  • Name:Stuart
Posted 22 April 2016 - 12:56 PM
Brake Calipers trailing may foul the x-member Dave? A9X had them leading.
#53 _Lightyear_
_Lightyear_
Posted 22 April 2016 - 02:26 PM
I wasn't sure which side they went on. Heath would know. I can swap them over if need be.
#54 _Lightyear_
_Lightyear_
Posted 25 April 2016 - 07:58 AM
The sandblaster turned up. He came late, and had to leave before the job was done. But I can bring the panels down to get finished elsewhere. All of the inside was done, engine bay done. All hinges, and bits done. Doors are done. The bonnet, nose cone and hatch have been sandblasted already, but I need to strip off the old undercoat and redo them.
upload img
#55 Heath
  • 18,365 posts
Posted 25 April 2016 - 08:59 PM
Calipers are to be fitted to the leading side ***
As per standard Torana.
#56 _Lightyear_
_Lightyear_
Posted 26 April 2016 - 01:43 PM
Ok, I will swap them over. Should have taken pics.
#57 _Lightyear_
_Lightyear_
Posted 26 April 2016 - 01:46 PM
I think I will spend a stupid amount of time cleaning all the sand up. It's incredible how much is on the car. Probably worse that he didn't high pressure wash it as he was in a hurry. Some parts are already covered in surface rust. The exhaust manifolds are the worst. They look like they have been sitting in an ocean for a year.
#58 cameron
cameron
  • 371 posts
  • Name:Cameron
  • Car:LX SS Hatchback
Posted 27 April 2016 - 12:29 AM
I use diluted phosphoric acid on a rag then rub the rust away. Saves grinding, blasting or sanding and making the metal thinner each time. You just flush it off with water which neutralizes the acid so it doesn't eat into the metal. Use rubber gloves its a mild acid but still will turn your hands yellow and burns a little. The panels don't rust for ages once treated.
Cameron
#59 Jay#2
Jay#2
  • 94 posts
  • Car:1976 LX 4 door
Posted 27 April 2016 - 04:33 AM
I had mine blasted about 10 years ago, it's been pushed about the garage since then but not finished. There is still sand in certain areas and I think there's quite a bit in the sills and chassis rails, the sand picks up moisture quite easily too it's best to get it all out.
#60 _Lightyear_
_Lightyear_
Posted 27 April 2016 - 06:58 AM
Probably good I didn't blast the bottom. So there isn't any sand in the sills. I spent about 6 hrs making sure I got as much sand out as possible. Rubbed it off and vacuumed it. I have the KBS paint system I will use to treat the metal. This morning I will do the clean wash, then the metal treatment on the shell and all the bits. And hopefully I can get some epoxy primer on this arvo.
#61 _Lightyear_
_Lightyear_
Posted 28 April 2016 - 08:01 AM
I have to go over it one more time to finish the prep, then a good wipe down. And it's ready for the epoxy primer. Can't wait...
picture host
#62 _Lightyear_
_Lightyear_
Posted 28 April 2016 - 02:24 PM
After spending a couple of hours going over all the bare metal, then wiping it all down. It was finally red for the primer. Takes a while to paint the car inside and out. The underside has a light coat, as it is getting the stone guard. I might give the outer panels a couple more coats so I don't sand through as quick when I do the body work.
But, it's coming up nice. Will paint the floor inside with KBS rust paint..
images hosting
#63 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 28 April 2016 - 07:31 PM
Looking good!
#64 Tyre biter
Tyre biter
  • 982 posts
  • Car:Should have gone with Palais...
Posted 28 April 2016 - 07:55 PM
Fantastic build David - I love this build thread - keep the updates coming please.
I noticed a difference in a panel in the boot between your car and mine.
Your car (I have circled the area of difference):
And my car (photo from 2011):
I see that our floors are completely different as well - I have the depression for the sedan spare wheel.
I wonder what the story is with this difference?
It appears mine has had a hit in the back somewhere back in time - I wonder if the boot floor in mine is a replacement from a sedan or if there was a change over in model year specification somewhere along the line?
Cheers, TB
Edited by Tyre biter, 28 April 2016 - 07:58 PM.
#65 Heath
  • 18,365 posts
Posted 28 April 2016 - 08:35 PM
Tyre biter, this car is a UC. Yours is an LX
#66 _Lightyear_
_Lightyear_
Posted 28 April 2016 - 09:51 PM
Yep. Thanks for the pic. I haven't seen the difference before. Only been told the LX floor is lower.
#67 Tyre biter
Tyre biter
  • 982 posts
Posted 29 April 2016 - 03:07 PM
Ah, didn't realise it was a UC to LX conversion - my bad.
Cheers, TB
#68 _Lightyear_
_Lightyear_
Posted 29 April 2016 - 04:58 PM
My mechanic rang to give me an update on the 308 motor. Turns out its needs more work than I thought. I bought it because it was a runner, thinking it will just need a freshen up. But it needs boring, new pistons, etc. Heads need doing. He said about $3,500 to rebuild it. So I might put that on hold for now.
My chrome sill covers just turned up. And the seat trim kit I bought should be here early next week. All going well, except the motor.
Next job is to mask up the car so I can spray the underbody.
#69 _Lightyear_
_Lightyear_
Posted 30 April 2016 - 06:04 PM
I prepped and painted the underside today. Sound deadener coat with chassis black over the top. Should be quite as a mouse. Front end can go in tomorrow. Yay.
adult image sharing
#70 purrlx
purrlx
  • 1,330 posts
  • Name:Danny
  • Car:LX hatch
Posted 30 April 2016 - 07:18 PM
Wow fast and nice work so far, Well done
#71 _Lightyear_
_Lightyear_
Posted 30 April 2016 - 09:38 PM
In about a week it will appear to have progressed a lot. Should be on all 4 wheels, and all panels primed and bolted on.
#72 rodomo
  • 18,019 posts
Posted 30 April 2016 - 09:39 PM
Shut up! :banghead:
#73 Ice
  • 15,174 posts
Posted 30 April 2016 - 11:20 PM
Shut up! :banghead:
Pull your finger out
Well done David i keep checking up on this every day
#74 _Lightyear_
_Lightyear_
Posted 01 May 2016 - 01:17 PM
If only I had tyres. The car is ready to come off the rotisserie now that the diff and front end are bolted in. Can't wait. I know where I will be first thing in the morning. MSWT..
gifs upload
#75 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 01 May 2016 - 09:18 PM
Great work so far David, off to get some fat tyres no doubt :)
