Dual cast , or non dual cast JP blocks .
#176
Posted 17 April 2016 - 11:39 AM
We have argued this 500 cars for 73 group c eligibility before in a previous thread and Bruce eluded to some sort of production certificate stating this that CAMS has on file.
#177
Posted 17 April 2016 - 11:55 AM
I think CAMS could help us all by releasing any documentation they have to the public in scanned electronic format. It's all from quite a long time ago, so I don't understand why they don't want to.
Yes there is reported to be a production certificate stating 500 cars were built in the 1st half of 1973.
It appears GM-H may have been covering all their bases by reporting the production figures for all 82911's built, regardless of whether it was to fulfill compliance or not.
#178
Posted 17 April 2016 - 12:11 PM
It appears GM-H may have been covering all their bases by reporting the production figures for all 82911's built and sold in Australia, regardless of whether it was to fulfill compliance or not.
#179
_Skapinad_
Posted 17 April 2016 - 12:17 PM
Let me guess, start slinging shit and try and get the logical discussion (which you are losing) closed ?
#180
Posted 17 April 2016 - 12:44 PM
Byron , in regards to JP390021 , I,m guessing one is duel cast and the other is single cast ? so why not xray them both , that will bring the truth out .
I,ve probably missed something here as i don,t spend a lot of time on this forum like the good old days when Amigo,s weren,t around .
I don't know, I'm just reading between the lines and from what I've heard outside of here.
#181
Posted 17 April 2016 - 12:48 PM
Does anyone know who owns that JP390021? (not the one Aldo had...)
#182
Posted 17 April 2016 - 05:16 PM
This is all very interesting,this story must go a bit further than what is being told ??
If all 6 cyl. blocks regardless of capacity were given a serial # and ran in a continuous numerical sequence it would seem that
they were all made out of the same material , the shop manual does not even state "except XU1" when engine block is mentioned but
in other areas of parts it does.However "service letters" make mention of the what has already been shown regarding "revisions" done
by GMH.
SBXU1.JPG 233.29K
8 downloads
One picture over the other seems to make for a very good re-stamp (or something else) even if one picture was not that flash to start with , looks like the one with white # has had chalk rubbed over it to bring up the number ?
Block/s # 389020? Ser.#JP390021
JPOL.jpg 43.64K
2 downloads
I think they were basically a race car was that road legal , maybe they did have to jump through hoops with CAMS to race them , still does not make those not on the list any lesser a JP blocked XU1 does it ?
#183
Posted 17 April 2016 - 07:34 PM
There is Documentation for the 200-Aug/Sept 1972 LJ XU1's (Coined by Press (Bathurst Cars) as in the CAMS 2/2V Homo paper for the Sprintmaster Wheel on that Doco Paper, Dated 10/8/1972 the Sprintmasters were the Start of said Cars, so Harry Firth told me and he said they were the Cars on the Chevron HDT DVD as well.
#184
_Skapinad_
Posted 18 April 2016 - 08:12 AM
Yeah, sort of. 250 (50%) to be sold before the amendment can be accepted but the total build number of 500 was required to be made and sold for the homologation to be completed (according to Bruce).
BTW the above clause is from the CAMS Series Production (200 cars) rules not Group C.
No such clause exists in the Cams Group C rules (valid until 31 December 1973) that Bruce has posted 1000 times over on this Forum.
The LJ XU1 was Recognised on 3/02/1972 by way of C.O.D H2-3 for Group E - Series Production Touring Cars.
All vehicles eligible for Group E were also eligible for Group C in 1973.
As all LJ XU1 amendments relate back to H2-3 the minimum production requirements of 200 cars for the original C.O.D still applied in 1973.
So what is the new information that CAMS gave you when you rang them Dave ?
#185
Posted 18 April 2016 - 08:20 AM
I asked The C.A.M.S what Bruce told Ian (Chaos) to ask. "How many LJ XU1's were required for amendments 8/8e and 9/2e".
In a nutshell the reply was 'no more than 200'.
This is the reason why only 200 required.
As I understand it The C.A.M.S decided after the supercar scare in 1972 to move over to Group C to reduce the number and potency of high performance cars the manufacturers were required to build. Not increase the number.
Edited by S pack, 18 April 2016 - 08:25 AM.
#186
Posted 18 April 2016 - 08:38 AM
To me reading this it suggests that once 50% of the the cars had been sold (250). The "Normal Evolution of Type" and "Variant" would be accepted by way of additional forms.
So if correct, once 250 cars were sold, the "normal Evolution" of the cars was done and noted by way of forms. So no real need to make any more than 250 cars, as their evolution only needed to be recorded on Forms ... CW
Weaver,You've nailed it,you finally got it ..............
Edited by crabba67, 18 April 2016 - 08:49 AM.
#187
Posted 18 April 2016 - 08:57 AM
So let me get this straight. I'm not agreeing with you, I just want to understand what the theory is.
In your opinion there were 250 identical engines counting backwards from the final XU1?
For the CAMS paperwork to be correct (which seems to be your bible so must be assumed to be infallible) there must have been 250 XU1's produced after 1/8/73?
So Crabba since Bruce didn't answer, you appear to support this theory, are my questions correct?
#188
Posted 18 April 2016 - 12:10 PM
250 engines, 250 cars, produced after the 1/7/1973
Under the Group C ( 1973-1984 ) and the Group A ( 1985-1992 ) rules a minimum of 500 cars were required.
Under the group E ( 1970-1972 ) rules a minimum of 200 cars were required.
To allow any amendments or homologations to take place under the 1973 Group C rules a manufacturer was required to have 50% or 250 cars sold before CAMS would accept any amendments or homologations.
#189
Posted 18 April 2016 - 01:03 PM
So does that mean you are telling us that there are 250 x identical cars with identical engines counting backwards from the last XU1? Excluding exports and of course excluding the odd car here or there missing from the Service/Warranty report.
BTW and not relevant to XU1, I think Group A was 5000 units, followed by the intention to build 500 "evolution" versions. This is why GMH built the V5H 308 and later 304, so that the VK Group A could then be raced with a minimum of 500 of those. The key being the intention to build 500., as history shows only about 300 VN Group A were built.
#190
Posted 18 April 2016 - 01:31 PM
302 VN SS Group A commodores, with a minimum of 50% or 250 cars being required to have been sold.
500 VL SS Group A Walkinshaw,s followed by a further batch of 250 cars 50% to allow the homologation of components, 750 cars in total.
etc etc etc etc
The 50% Rule..........
#191
Posted 18 April 2016 - 01:55 PM
https://en.wikipedia.org/wiki/Group_A
Well Bruce, you've just proven to the world that you know SFA about CAMS rules. Normally I don't like WIKI as it is only as good as the idiots who modify it but in this case it essentially shows that the facts are very different from your version of them. I can't post text on this site, but above is the link for all those that wish to see that what has been stated is BS.
Plus you still haven't answered the primary question, just posted more BS.
#192
Posted 18 April 2016 - 02:01 PM
etc etc etc etc
I thought I better include this just in case you change it once you realise you are wrong.
#193
Posted 18 April 2016 - 05:26 PM
LOL
" QUOTE "
Wikipedia
Homologation
the FIA allowed " Evolution " models to be homologated with a minimum of 500 cars.
( CAMS ) fully homologated the vn commodore for racing.
" END QUOTE "
LOL
Wrong about what ??????????
#194
_ChaosWeaver_
Posted 18 April 2016 - 05:44 PM
Whilst I think that is what the terminology is saying ...... I believe that neither Ford, Chrysler or Holden, were ever held to these figure's by CAMS or anyone else ..
I may be wrong, but I believe they made no where near 250 identical RT Chargers, Ford GT phase 3 may have had the numbers, but still maybe there is some doubt about 250 identical cars..
Remember the Ford Sierra, I doubt they ever sold the numbers here that was needed, to race, but they raced... Dick johnson's Mustang, Neville Creightons Volvo ..
Different rules for sure, but you can't tell me that exemptions haven't been given ?? .....
#195
Posted 18 April 2016 - 06:07 PM
To allow any amendments or homologations to take place under the 1973 Group C rules a manufacturer was required to have 50% or 250 cars sold before CAMS would accept any amendments or homologations, unless the vehicle was homologated under Group E rules in which case the minimum number required was still 50% of 200.
Fixed it for you.
#196
Posted 18 April 2016 - 07:14 PM
That's so funny ( LOL ) all most as funny as Byron. You do understand that Group E finished in December 1972 with Group C taking over from the 1st of January 1973 don't you ????????????? LOL
#197
Posted 18 April 2016 - 07:20 PM
So you reckon you know more about The C.A.M.S rules and how they were applied than The C.A.M.S!
#198
Posted 18 April 2016 - 07:30 PM
I think you need to have another chat with the C.A.M.S. if there documentation is confusing you........
#199
Posted 18 April 2016 - 08:02 PM
If you have an issue with the information I have posted then I can only suggest you contact The Confederation of Australian Motor Sport and take your grievance up with them.
#200
_ChaosWeaver_
Posted 18 April 2016 - 08:22 PM
The E49 R/T Valiant Charger raced in 1973, and they only made 149 in total ....
The VJ Charger was released in 1973, but the range was reduced to three models; Std, XL or 770 (even though a few six-packs still managed to hit the market). The VJ brought higher equipment levels, round headlights, a new grille and new tail lights. However, the R/T was gone forever. E49 was the ultimate Charger, with only 149 built. Here is a breakdown of how many were made in each colour.
The E49 "six-pack" engine came with a baffled sump, tuned length headers, special shot-peened crankshaft, conrods, pistons, rings, cam, valve springs, a twin plate clutch and triple 45mm dual throat Weber carburettors. Chrysler quoted this engine as producing 302 HP which, in a 1372 KG (3000 pound) car, made for rapid acceleration. Road tests of the era recorded quarter mile times of between 14.1 and 14.5 seconds. 0-100 mph (160 km/h) in 14.1 seconds was the norm. This compares to times of between 15.2 and 15.6 for the next quickest accelerating Australian muscle car, the mighty XY GTHO Falcon.
