Hi all, I'm trying to help my nephew get his Belmont well body back together & with budget as
tight as it is, need to solve a minor hiccup as cheap as we can. So he's keeping the 6 for now
but the diff that's in it is a V8 Salisbury (1" cup yoke), years ago I did a similar swap for a bloke
& I'm certain I just bought a uni that was Banjo on 1 axis & Sals the other. Had a bit of a look on
the net today but nothing, has anyone heard of this type of uni in these sizes?
If someone's got a catalogue, spec's are:
banjo-6
A. 25.4mm Cap dia
B. 65.2mm Cap to cap
C. 43.5mm Clip to clip
Salsv8 (not tonna)
A. 25.4mm
B. 80.4mm
C. 59.5mm
So basically a RUJ 1786 (banjo) one way & RUJ 2030 (sals) the other.
Yes it'd be easier to just go get a V8/Sals shaft out of a Stato,wagon,van or well body but cash for
that & probly a couple of uni's will take money from other areas slowing it all down (I need the shed-
-back for my LJ).
thanx,
I've been playing with HQ-WB since I was 14 years old when HZ's and WB's were still new cars and I've never heard of or seen a Uni that adapts a 6cyl to V8 (V8 Salisbury uni is the same as V8 banjo uni afaik). You can buy a V8 to tonner adapter uni, the only difference is one pair of uni cups are 1.125" diameter and the other pair are 1". With the 6cyl and V8 the cups are the same but two would be about 7.5mm further towards the centre - I can't see it working.
I also recall banjo and Salisbury tailshafts being slightly different in length, like near to 10mm. I remember striking this when I put a A9X diff in my LX Hatchback, I used a V8 LH-LX tailshaft but it was very tight and should have been 10mm shorter for the Salisbury.
In my opinion the cheapest way out would be to go find a V8 tailshaft with useable unis on it. When you say Belmont I assume its a HQ ute or van or HQ-HX wagon? Also assume Aussie 3/4spd or trimatic? If so just grab any 253 HQ-WB ute, van, wagon or statesman tailshaft. Many others are the same too: HQ 308 Statesman/wagon/ute/van, HJ-HZ 308 manual ute/van/wagon and post 1981 WB Statesman. It is probably the most common shaft after a 6cyl of the same origins and 6cyl sedan/coupe, surely someone in WA has one they've kept out of the weather that will keep your nephew going. I can't imagine paying more than $75 for one here. Try Greg at Classicozwreck, he'd have one but freight might be $50 to WA.
