accelerator cable
22 replies to this topic
#1 _LX355SLR_
_LX355SLR_
Posted 01 May 2016 - 03:03 PM
Having issue with adjusting the cable for my 355 with qft 750 double pumper. Just noticed it was not pulling the throttle linkaga all the way open. i have moved the cable connecting ball to the lower setting and this apears to have not made much difference. I have moved the pedal as far forwad on the uipper slot on the firewall bracket (inside car) but i am still loosing a good portion of my secondaries and im thinking there is somehing missing from my setup as if i tighten it so it doesnt move on the slot the pedal becomes hard to press so maybe there is a bush missing?. As you can see in the photos i have a lokar cable and aluminum bracket so cable is coming from rear.
#2 ls2lxhatch
  • 5,335 posts
Posted 01 May 2016 - 06:31 PM
The factory accelerator pedal bolt has a threaded section then a nut built into the bolt then another threaded section. Tightening the bolt to the firewall bracket does not effect the tightness of the pedal. The pedal can be removed without removing the bolt from the firewall bracket.
You can see the permanent nut on the bolt in this picture .
Edited by ls2lxhatch, 01 May 2016 - 06:44 PM.
#3 _LX355SLR_
_LX355SLR_
Posted 01 May 2016 - 06:45 PM
that photo isnt working but if you can see from the photo i uploaded there is no nut on the left of the pedal arm and the nut on the right is what i used to move the pedal this does cause the pdeal arm to tighten. Am i right in assuming that welded cylinder section is some sort of pivot bush and mine must be seized
#4 ls2lxhatch
  • 5,335 posts
Posted 01 May 2016 - 08:19 PM
From left to right, nut, spring washer,  flat washer, pedal arm (missing), wave washer, firewall nut (missing)
This is a photo of just the bolt.
#5 ozyozyozy
ozyozyozy
  • 953 posts
Posted 01 May 2016 - 08:25 PM
That big hole on the acceleratir linkage on the carby above were yours is connected is actually the correct spot to connect the accelerator in a holley type carb.
There is a 2 piece bush you can get that goes there and the ball joint bolts to that.
Very common not to be able to get full throttle.
"Lokar" make cables that can be cut to length and have 2 adjustment points
#6 _LX355SLR_
_LX355SLR_
Posted 01 May 2016 - 09:49 PM
Yeah my pedal lever must have seized to that bolt as it is just slightly loose and pivoting on the bolt. Must have been like that for 2 years! Does anyone know if you can buy the bolts above from rares etc
#7 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 01 May 2016 - 11:19 PM
Had a similar issue on a WB. Just pulled everything apart and repaired.
Had to drill and tap a threaded section into the shoulder bolt because it was frokd.
Re-assembled with some grease and it worked a treat.
#8 _LX355SLR_
_LX355SLR_
Posted 05 May 2016 - 09:42 PM
so i have replaced the pedal with a Uc pedal which has slightly more leverage and cleaned and greased the bush bolt. Pedal is so much better and am now getting 95% throttle but still cant get the 100% its almost as if the cable binds and doesnt have the strength to pull it all the way back
Edited by LX355SLR, 05 May 2016 - 09:51 PM.
#9 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 05 May 2016 - 09:54 PM
Have someone push the pedal down, or use a brick
Then manually open the carb to 100% at the other end of the cable.
If the cable goes slack then you don't have enough leverage on the pedal.
Pedal can only go as far as the floor, and you don't won't the accelerator to high.
You can only get so much travel, the rest is done with leverage.
Not sure about the UC pedal, but my LC cable conversion has a adjustable stop (screw) to set the height of the pedal.
Then the floor sets the other extreme.
I had the other problem, only had to move the pedal half way to achieve 100%
I'm just making a bolt on linkage for the carb to get it just right.
#10 ozyozyozy
ozyozyozy
  • 953 posts
Posted 05 May 2016 - 10:30 PM
Its not about the strength to pull it, its trying to adjust the cable to be able to pull the throttle linkage over a centre point of its travel at a particular angle.
Edited by ozyozyozy, 05 May 2016 - 10:31 PM.
#11 _LX355SLR_
_LX355SLR_
Posted 06 May 2016 - 08:29 AM
well if it was to go in the top larger hole it would make it a lot easier to lever but i dont think it has the length of travel. he bottom hole looks like it has the length but not the strength. You can see the cable begin to tighten within the sleeve as it gets to a point but the carby lever stay still.
#12 ozyozyozy
ozyozyozy
  • 953 posts
Posted 06 May 2016 - 09:05 PM
Its hard to try explain it through a msg.
were your current position is, the linkage will rotate to eg180degrees layed flat, what it actually needs to do is rotate to 185degrees to get full travel, no amount of pulling the cable will be able to change that unless the pivot point is moved.
to be honest the factory accelerator cable is just pure junk, when try to adapt to aftermarket stuff.
Its a tricky thing to setup properly, takes a bit of time and screwing around, you will find most people are having the same problem and just havent bothered to look very hard at it.
If its only a few degrees away from full travel, you prob wont even notice the difference between that and true full throttle.
#13 _LX355SLR_
_LX355SLR_
Posted 07 May 2016 - 05:52 PM
ok well i have moved to the top hole (large) to give better leverage but it still wont go to full throttle. made no difference with the spring out so im thinking the cable is binding and not letting it open fully
#14 76lxhatch
  • 7,225 posts
Posted 07 May 2016 - 09:47 PM
There are two different pedals with different lever ratios too, that's why there are two spots in the mounting bracket. The one that fits the top hole has less cable travel than the one that fits the bottom hole.
#15 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 08 May 2016 - 05:07 PM
This might sound like a very stupid question but is there a rubber grommety type thing in the hole on the pedal end of the cable (as per factory )?
It accounts for about a 1/4 inch , if not fitted it may well be part of the problem , if fitted  then that base is covered and disregard question.
#16 _LX355SLR_
_LX355SLR_
Posted 11 May 2016 - 12:26 AM
I have an aftermarket braided cable so no grommet
#17 ozyozyozy
ozyozyozy
  • 953 posts
Posted 11 May 2016 - 10:34 PM
If its only a few mm frim full travel it will be good enough, you won't notice.
They are a pain in the arse, i spent hours getting it to were i was happy
#18 Kirk
Kirk
  • 843 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 12 May 2016 - 12:37 AM
Have you got the correct pedal ?
the V8 and the 6  are different in length from the pivot point to the cable hole
#19 _LX355SLR_
_LX355SLR_
Posted 12 May 2016 - 11:28 AM
I don't think it is anything to do with te pedal, I have changed to the UC pedal which has about 10mm more leverage and if I disconnect the cable from the carbs and put my foot on the pedal the cable retracts further than it needs to when compared to the Darby linkage at full throttle. So it has the pull length but seem to not have the stength. I am thinking the cable itself may be binding so I have bought an Aeroflow braided cable which seem the same quality as the existing lokar cable so hopefully that fixes the issue
All to answer your question Kirk it lines up perfectly with the existing standard hole
Edited by LX355SLR, 12 May 2016 - 11:30 AM.
#20 76lxhatch
  • 7,225 posts
Posted 12 May 2016 - 02:54 PM
Well in that case its because the lever is pulling too far over centre. You need to change the lever at the carb so its on a better angle (but same length) or even better put a linear or even progressive linkage on it (like a pulley) which will give consistent movement and feel.
ozyozyozy mentioned this above, except its unlikely to get even close to 180 degrees because once it goes over centre the cable needs to start pulling downward to get good purchase. The pulley-style linkage eliminates the problem, I don't know why more carbs don't use them.
#21 76lxhatch
  • 7,225 posts
Posted 12 May 2016 - 03:10 PM
Can't tell from the photo, but is it possible to mount the cable under the bracket? That would probably help, as long as it doesn't make it too hard to crack the throttle open at the other end
#22 _LX355SLR_
_LX355SLR_
Posted 13 May 2016 - 08:15 AM
no i think under the bracket would cause interference. Are the carby levers interchangeable or adjustable. This is an out of the box quickfuel 750 double pumper so surely this would be an issue for most if it is just the lever angle
#23 76lxhatch
  • 7,225 posts
Posted 13 May 2016 - 09:05 AM
Less of an issue if you had a pedal with more cable travel and you could use the top hole, that would put the cable below the attachment and help with leverage.
Yes it is a problem for many, as above it seems stupid to me that carbs still use this style lever, you won't find it on many (edit: OEM) throttle bodies.
Edited by 76lxhatch, 13 May 2016 - 09:05 AM.
