Relief to the bore
#1 _Muzzy_
Posted 14 May 2016 - 10:20 AM
I'm running a 93mm bore
1.740" intake
And 445" lift base on 1.5:1 rockers or .480" if I use 1.6:1 rockers
The head has had .040" removed from it
I'm stuffed if I can work it out on measurement and depth gauge, it's not looking good without .100" or relief
Have looked on the web and get mixed answers?
#2 _repco_
Posted 14 May 2016 - 10:37 AM
Hi Brian. You need to start by putting the head gasket on the head and the block and then scribe around the fire ring of the gasket. Then you will see how things look and also have a measurement to work with. Do not go lower than the top ring at tdc. Phil.
#3 _Muzzy_
Posted 14 May 2016 - 10:53 AM
I have done this on the head , and taken measurements not on the block will do no keep me surfing, I do understand the max relief would be no more than 2-3mm as a scallop
#4 _Muzzy_
Posted 14 May 2016 - 10:56 AM
Auto correct gotta live it,
I will measure the block with head gasket on it and scribe, Not sure where surfing comes into it LOL
#5 _repco_
Posted 14 May 2016 - 10:59 AM
You need to mark the block. and machine the relief out to the scribed line.
Bloody wax head.... LOL
Posted 14 May 2016 - 11:25 AM
Keep valve clearance to a minimum as the compression will lower.
#7 _oldjohnno_
Posted 14 May 2016 - 03:13 PM
At what point do you need to relieve the bore
1.740" intake
It's unlikely you'll have to do anything. Sit the head on the block with a gasket and with an intake and exhaust valve fitted to one cylinder with no springs. Clothes pegs are an impressively hi-tech way of holding the valves up while you drop the head on. Use verniers to measure the distance from the tip of the stem to the top of the guide with the valve closed then push the valve down til it touches the block and measure it again. Hopefully the difference between the two measurements will be equal to or greater than the valve lift plus a bit for clearance, say 0.040". Don't hack away at the top of the bores unless you have to, but with small cams it usually isn't a problem anyway.
Edited by oldjohnno, 14 May 2016 - 03:15 PM.
#8 _Muzzy_
Posted 14 May 2016 - 03:59 PM
I measured the bore to gasket and have 2mm I measured the gasket to intake valve and have 3.50 mm so I should be right, however I will do that, sit the head on and check depth ,
Thanks all
#9 _STRAIGHTLINEMICK_
Posted 14 May 2016 - 04:35 PM
Edited by STRAIGHTLINEMICK, 14 May 2016 - 04:36 PM.
#10 _STRAIGHTLINEMICK_
Posted 14 May 2016 - 06:03 PM
Posted 14 May 2016 - 11:26 PM
As oldjohnno said, I don't think you'll have a problem with a cam with small lift.
If you had another .100" valve opening you would be getting closer to the bore.
Posted 15 May 2016 - 12:09 AM
Just for information my 9 port has 100 thou shaved from it,
which is down to the witness marks,
and with 1.625" diameter inlet valves,
they are only 5/16" from the deck on the port side,
and 1/2" from the deck on the plug side.
The closest to the bore's edge is half way between the two.
In my case, the valves misses the bore in a 208ci
#13 _STRAIGHTLINEMICK_
Posted 15 May 2016 - 08:49 AM
Yep usually you'll be ok but it needs to be checked when youre getting close to .500 lift.
Posted 15 May 2016 - 01:18 PM
#15 _rich243_
Posted 15 May 2016 - 03:50 PM
#16 _Muzzy_
Posted 15 May 2016 - 04:31 PM
Do the 1.6 ratio rockers muzza is using make much difference?
I don't know, I haven't brought them as yet, going off the SBC figures and engine size I reckon about 8-10 HP on a 202, I m happy to here others who have them
#17 _rich243_
Posted 15 May 2016 - 05:03 PM
Posted 16 May 2016 - 01:30 PM
Oldjohnno has valuable information here:-
http://www.oldjohnno.id.au/page16.html
http://www.oldjohnno.id.au/page14.html
and
here is your answer:-
http://www.gmh-toran...xu1-valve-size/
Edited by NA-PWR, 16 May 2016 - 01:43 PM.
#19 _imperial engines_
Posted 21 May 2016 - 05:57 PM
Hi, you say you are running a 93mm bore, what pistons do you use?
#20 _Muzzy_
Posted 21 May 2016 - 09:09 PM
Off set bowl ACL duralites II ( NOS)
#21 _Muzzy_
Posted 11 June 2016 - 01:10 PM
Very close
With a used gasket fitted
The exhaust are all fine
Intakes vary, however 3 are sitting at 020" clearance, they hit just on the edge of the bore, where the machined taper is, the other 3 hit, but clear the taper and hit the Bore that gives me more than enough with 1.5:1 rockers
Mm mm
I think I will touch up the taper with my little Dremel, I'm not happy with .020" clearance
#22 _Muzzy_
Posted 11 June 2016 - 04:02 PM
Posted 11 June 2016 - 05:55 PM
Wow the top of this piston bowl area looks like course sandpaper but the adjacent piston looks to be machined. Is the grainy look an optical illusion?
#24 _Muzzy_
Posted 11 June 2016 - 06:02 PM
Any views on the bore reliefs
#25 _oldjohnno_
Posted 11 June 2016 - 10:09 PM
Just that I'd take off the minimum necessary to provide 0.030" - 0.040" clearance. Nothing fancy, just a small and simple chamfer with the Dremel.
