The grit from grinding will be great for your assembled engine. Not
Relief to the bore
_Muzzy_
, May 14 2016 10:20 AM
28 replies to this topic
#26 _repco_
Posted 11 June 2016 - 10:13 PM
#27 _Muzzy_
Posted 12 June 2016 - 05:36 PM
All done, thanks for the advise, used my Dremel with a mini sanding drum, have just on .500" on all valves which gives me .050" clearance on the cam I'm using
#28 _STRAIGHTLINEMICK_
Posted 14 June 2016 - 08:27 AM
Yep as johnno said will work and you can also reduce the margin on your intake valve to 1.71" for clearance and and this will also assist with un shrouding .
