Rear Suspension hitting over bumps
#26
Posted 19 October 2016 - 04:29 PM
Modify the axle tubes by adding the bracket from the standard diff housing. The L34 and A9X used the same size rubber bump stop as a normal LH/LX. A metal tube was welded in to raise the height of the bump stop mount over that of the standard.
#27
Posted 23 October 2016 - 08:12 AM
I was asking if u can buy a higher bump stop rubber.
If i put a set of air bags in the rear, would that illuminate the rear from bottoming out?
#28
Posted 23 October 2016 - 04:33 PM
Easiest way is to cut the top of the bump stop off, get some 2 inch steam pipe or thick wall tube, roughly 2 inch diameter weld the top to it and join to the diff in the same location. memory says they are 75mm long. There is a picture of one if you look in my garage under A9X 4 door, the garage icon under my Avatar. page 3.
Edited by myss427, 23 October 2016 - 04:33 PM.
