A bit off topic but sort of related.
In this computerized world which can be a bit a bit of a thing if we don't have all the cam specs we can calculate DCR with a dial gauge and vernier.
Install cam and some sort of spring on intake.
We already know the stroke so set up some sort of arrangement so that the dial gauge can read valve lift @ the valve.
Turn over engine until the intake valve is fully closed after induction , zero the dial gauge and turn engine over again until intake
is 50 before zero , this should mean that with some sort of cam that the piston is now on the upstroke.
Stop at 50 and measure the stroke and use the usual way to calculate CR.
That should hopefully give us the DCR ?
Don't be surprised if the piston is up to an inch or more up the bore creating a short stroke ?
