hj problem
Gump
, Aug 07 2006 12:53 PM
7 replies to this topic
Posted 07 August 2006 - 12:53 PM
Hi all
not that i have the car yet im wanting to fix things on it already, when you wind the window down (both rear) then wind it back up it dosent follow the window seal and leans into the car so when you wind it up you have to press your hand against it to get it to go up properly.
cheers gump
cheers gump
Posted 07 August 2006 - 01:16 PM
Sounds like the rubber (bailey channel?) bit doesn't extend far enough down into the track...there could also be an alignment issue...if you pull the door trim off all will be revealed..a bit of tighening and greasing will sort it i am sure.
Posted 07 August 2006 - 01:34 PM
cheers for that yeah i have to wait till pay day to till i can say its mine then all i need to do is get a good master cylinder hopefully of dattoman then she's all good to go. if dail up wasnt so slow i would put picks up but its very slow.
Posted 07 August 2006 - 03:12 PM
Id say fastEH is right!
Rare Spares sell kits for bailey channels and also repair kits if the winder mechanism is buggered..
Cheers!
Cheers!
#5 _Yella SLuR_
Posted 07 August 2006 - 03:43 PM
Sounds like it's missing an inner door belt (rubber strip along inner side top of door). Also check alignment of rear window divider/runner.
Edited by Yella SLuR, 07 August 2006 - 03:44 PM.
Posted 07 August 2006 - 05:38 PM
cheers i cant wait to bring it home and start fixing the little things up
#7 _devilsadvocate_
Posted 07 August 2006 - 09:52 PM
Sounds like the channel/rail that holds the window in place as you wind it down is not tight enough...could be rubbers have worn too......but try tightening them up, there will be a bolt under the door trim where you can adjust them.
Posted 07 August 2006 - 10:13 PM
take the door trim and hardware off and make sure all the bolts that hold the regulater in place are tight and not slipping up and down.
Edited by surfmaster, 07 August 2006 - 10:13 PM.
