2006 Yamaha Kodiak 450
41 replies to this topic
#26 hanra
  • 11,033 posts
Posted 07 October 2016 - 09:11 AM
I was going to get the entire frame and suspension powdercoated... but then it would end up sitting in the shed with the other two cars and never get used....
I still need it to be safe and reliable. So hopefully after this Ill never have to really touch it again.
Edited by hanra, 07 October 2016 - 09:12 AM.
#27 RallyRed
  • 8,213 posts
Posted 07 October 2016 - 09:26 AM
good one....should go for a 100 years
#28 hanra
  • 11,033 posts
Posted 07 October 2016 - 09:38 AM
I reckon I might even be able to fire it up again after this weekend
#29 _Skapinad_
_Skapinad_
Posted 07 October 2016 - 04:03 PM
Good job mate. Is it 4wd ?
#30 hanra
  • 11,033 posts
Posted 07 October 2016 - 06:01 PM
Yep. 4x4 with front diff lock.
#31 _Skapinad_
_Skapinad_
Posted 07 October 2016 - 06:03 PM
Is it shaft driven ?
#32 hanra
  • 11,033 posts
Posted 07 October 2016 - 09:22 PM
No it's a CVT drive setup with a drive belt. Then a tail shaft and two unis at the back. Front shaft and two unis again.
#33 hanra
  • 11,033 posts
Posted 07 October 2016 - 09:27 PM
I actually just refitted the primary CVT Sheave back on tonight.
9560041E-AF28-4B60-BAF5-BD411E5B2144_zps
#34 hanra
  • 11,033 posts
Posted 07 October 2016 - 10:48 PM
Refitted my CVT sheave today. Also fitted a 1mm shim to give it some more low down gearing. Had a trick way of holding the sheave. Just shoved a pinch bar under it on the thick fin. Held it no worries and torqued it up to 100nm.
58FDA537-5CA5-406E-82C5-5626681629D5_zps
07C437C7-89A6-4F16-810F-090C4D5327A3_zps
FDB20080-B273-4DBD-9915-349EBB4F61C3_zps
#35 hanra
  • 11,033 posts
Posted 10 October 2016 - 08:32 PM
Had a quick go at tidying up the plastics. Still need a bit more attention....
2A4DD001-3A11-4351-88E7-3B42A437C3B5_zps
158AF13B-4318-45EA-97E0-757102767FD6_zps
014FE446-A811-4B63-B087-83622C8C7104_zps
#36 _Skapinad_
_Skapinad_
Posted 10 October 2016 - 08:33 PM
Camo wrap !!
#37 hanra
  • 11,033 posts
Posted 10 October 2016 - 08:40 PM
What's that stuff like to work with? This has a lot of edges and grooves etc.
#38 hanra
  • 11,033 posts
Posted 16 October 2016 - 05:21 PM
Got the electrics all working again. The multifunction display was actually unreadable previously, the plastic was totally crazed. I sanded it back on the linisher and then wet/dry sand paper.
Looks like this old girl has certainly done some work...... yikes.
F8F1BA62-AF96-4897-B02C-1067F4DA329D_zps
#39 hanra
  • 11,033 posts
Posted 30 October 2016 - 07:48 PM
At idle: https://youtu.be/kENjEcS6lRU
0F666EF6-1509-42B0-87CF-53CE741667CE_zps
6052DA73-6DE1-4EB4-AC61-7304393269B0_zps
DCEC0047-B4E7-424D-94F8-093974EB12DD_zps
Edited by hanra, 30 October 2016 - 07:49 PM.
#40 Dodgey
Dodgey
  • 437 posts
  • Name:Steve
Posted 31 October 2016 - 06:19 PM
You've done a great job with that hanra
#41 hanra
  • 11,033 posts
Posted 31 October 2016 - 07:47 PM
Thanks mate. Still going to get the racks and rims powder coated and fit the new tyres and recover the seat. On the home straight.
#42 hanra
  • 11,033 posts
Posted 18 December 2016 - 09:05 PM
Got the rims/racks and bumper powder coated. New tyres fitted. And just finished up re-covering the seat. The rear brake is still a bit ordinary. I'll try re-bleeding but it may just need bedding in?
Also got a 55L spray tank for it that I'll have to jimmy up and get it mounted so that I can poison the property a bit easier.
I think the rear left outer CV joint might be stuffed. It clicks on left hand turns.
06D843CE-FD89-4102-8A30-4FA6D8273CF1_zps
2AB74623-8386-431F-B1FE-A0B4D87E28C5_zps
7B3D8C27-C506-4A32-9C82-EF5F9623DA80_zps
DD6B64E8-43A9-4BFF-B198-3007382BF5DE_zps
1AD5F16F-CE87-4C28-8952-A73D37E0DBBE_zps
1DA0870C-A204-4093-A337-8D117A2DA81D_zps
13BFB574-465C-47EA-B16A-9420AD062428_zps
Edited by hanra, 18 December 2016 - 09:07 PM.
