10 Bolt is Salisbury? Yes?
Posted 07 August 2006 - 06:38 PM
Posted 07 August 2006 - 06:50 PM
_ChiaLX_
Posted 07 August 2006 - 06:52 PM
Posted 07 August 2006 - 07:29 PM
_Herne_
Posted 07 August 2006 - 07:30 PM
Herne
Posted 07 August 2006 - 07:35 PM
_UCV80_
Posted 07 August 2006 - 07:58 PM
iv flogged the shit out of one, now its in my gf's v8 uc, and its been in a skid comp, and gets flogged heaps, still going good
nathan,
_coupe202_
Posted 07 August 2006 - 08:20 PM
_Herne_
Posted 07 August 2006 - 08:58 PM
BW seems to be the way to go these days and if I were to be looking for a low budget diff a BW is what I would be looking at.
Then again if money was no object I would have a Ford 9" set up properly in preference to them all.
Herne
_Lostit_
Posted 07 August 2006 - 10:28 PM
Behind a turbo , six they are brillant unless of course yuo using a transbrake where it makes no diff what engine combo you running lol.
Lostit
_high_rpm_
Posted 07 August 2006 - 11:05 PM
Posted 07 August 2006 - 11:09 PM
so to get technical a 10 bolt is a chev diff and a salsbury adopted the name for its similar looks.
Posted 07 August 2006 - 11:43 PM
Posted 07 August 2006 - 11:45 PM
Posted 08 August 2006 - 12:42 AM
Dave
_coupe202_
Posted 08 August 2006 - 06:10 AM
Posted 08 August 2006 - 11:18 AM
_gtr-xu1_
Posted 08 August 2006 - 01:37 PM
The VL or even a VN diff BW (vn diffs are cheaper) and spools are also available
10 bolts are too heavy and not a real great improvement
Ford 9 inches are way too heavy to much power loss
Then you just have to find someone to do the conversion with out stuffing it up
Edited by gtr-xu1, 08 August 2006 - 01:38 PM.
Posted 08 August 2006 - 05:43 PM
_on the limit_
Posted 08 August 2006 - 06:48 PM
#21
_gtr-xu1_
#22
Posted 09 August 2006 - 08:53 AM
You can use the Banjo Crown wheels etc, to make up the 2.78, 3.9 and 4.11s........
Easier to change a Banjo centre tho, hehehe.
BW is the way to go the VL Turbo and VN being identical.
And you can take the brakes you get with it too.
Grant..
#23
_MYLJ_
Posted 09 August 2006 - 09:26 AM
Grant please check your facts !!!!!!Salsbury's get bigger axles, but the bits that matter inside are the same as Banjos. Tonner centres are stronger than std ones, and you get a better spread of ratios with the Salisbury.
Grant..
there are several types of "sailsbury " diffs fitted to Holdens, firstly there were the ones fitted to HK/T/G , chev type unit.
then there is the V8 large sailsbury that was fitted to all V8 HQ to HZ holdens, available in single wheeler or LSD, ratio choices are 2.60 , 2.78 , 3.08 , 3.36 , 3.55 and 4.44 (4.44 was the one tonner ratio, they also have a thicker axle in tonners) also fitted to WB statesmans and 5.0 ltr WB utes / vans/ tonners , they are also standard fitment in all 5.0 commodores from VB to VK . and A9X's.
then there's the third group, small sailsbury, fitted to UC torana/sunbird, all non 5.0ltr commodores up to vl. and non 5.0ltr WB's , this is the type that uses the same internals as the banjo diff centres.
there is no 4.11 ratio holden sailbury (or banjo) .
#24
Posted 09 August 2006 - 10:02 AM
To add to what MYLJ has posted, the Large Holden Salisbury was fitted to ALL 1-Tonners from HQ to WB both 6 & V8.
The Large Salisbury was available in the ratios:- 2.60, 2.78, 3.08, 3.36, 3.55, 3.90 & 4.44.
The Small Salisbury was available in the ratios:-3.08, 3.36, 3.55 & 3.90. These gears are the same as banjo diff gears, so the old HK/HT/HG 2.78 gears would also fit into the Small Salisbury centre, if required. If you really wanted to the old 3.89 (48 to EJ gears would also fit.
Dr Terry.
#25
_on the limit_
Posted 16 August 2006 - 06:26 PM
very true, but no 3.9's in large 10 bolt salsbury's ... sorry to be picky! lolHi Guys.
Dr Terry.
