LX Hatch Chassis ID
SS A9X Hatch Chassis ID Help
8 replies to this topic
#1 _andyham_
_andyham_
Posted 24 September 2016 - 07:35 PM
Hi all,
Apologies if I've missed finding this in another thread, but hoping any experts out there can confirm if chassis number CLX044XXXM is LX SS hatch?
Certain its not A9X but would it then be SS or was CLX 0... also reserved for standard S/L hatch also?
Many thanks!
:spoton:
#2 Justlookingtobuyone!
  • 62 posts
  • Name:Mike
Posted 24 September 2016 - 08:28 PM
Hi there, without the original tags it's just a hatchback shell. It's hard to determine what it may have been originally without them.
Cheers Mick
#3 Redzone
Redzone
  • 517 posts
  • Car:Mini torana's - Gemini coupe 10.787@123mph, log booked Group A DOHC Gemini under resto..
Posted 24 September 2016 - 08:50 PM
CLX just means it's the third "series" of the LX model. Series changes usually coincide with ADR revisions.
#4 Bigfella237
There's nothing to be gleaned from a chassis number alone, they were simply a numerical sequence allocated across the entire Torana range, it didn't matter if it was a hatch or sedan, A9X or Sunbird, it was just whatever came down the line next got the next number.
CLX044xxxM is likely a June '77 compliance (so a few months early for an A9X) but, as above, without tags it doesn't really matter what it was, you have no way to prove it.
#5 _andyham_
_andyham_
Posted 24 September 2016 - 11:05 PM
Cheers Mick, Red, Big.. noted.
Was just hoping there may have been a sure fire lead in there to confirm SS.
Thanks again!
#6 Tyre biter
Tyre biter
  • 982 posts
  • Car:Should have gone with Palais...
Posted 25 September 2016 - 07:55 AM
SL hatches had the silver trim around the tail lights and so the panel had holes for the trim's pins to insert:
Thread on the trims here: http://www.gmh-toran...-mounting-lugs/
Photo of trim in place below:
Not sure about Sunbird hatch having these but SS variants didn't have this trim or holes.
The QLD Torana Club says Sunbird hatch was not released until mid 1977 which is right around Bigfella's estimated build time of you car: http://www.qtcc.org.au/lx_specs.php
Might be something to check to get you on the scent (assuming the rear valance hasn't been replaced at some stage).
Cheers, TB
Edited by Tyre biter, 25 September 2016 - 07:59 AM.
#7 S pack
  • 15,723 posts
Posted 25 September 2016 - 08:11 AM
Cheers, TB
Hi T.B
The OP has already covered this in his first thread about an LX hatch identification.
http://www.gmh-toran...identification/
Edited by S pack, 25 September 2016 - 08:13 AM.
#8 yel327
  • 13,635 posts
Posted 25 September 2016 - 08:13 AM
Thanks again!
Go and talk to Holden Historical Services. For some LH-LX you can figure out what the PSN of the car was from the chassis number.
#9 _andyham_
_andyham_
Posted 25 September 2016 - 09:44 PM
Cheers TB, Yel..
Many thanks for the info and links!
Andy
Also tagged with one or more of these keywords: SS, A9X, Hatch, Chassis, ID, Help
