186 piston sizes
186 pistons sizes 202
5 replies to this topic
#1 _bilby64_
_bilby64_
Posted 29 September 2016 - 12:03 AM
Hi all,
I have been given a 186 engine and have pulled it down.
5 pistons have a part number 7429479, this number is on the inside of the piston.
1 piston has RAZ202Z 040 10P 01 QE, these numbers are on top of the piston.
Are the 5 pistons equivalent to a 202 piston 4 thou over.
Is anyone able to help?
Thanx,
Bill.
Attached File  Piston 1.jpg   33.98K   2 downloads
Attached File  Piston 2.JPG   39.31K   1 downloads
#2 dattoman
  • 16,487 posts
Posted 29 September 2016 - 12:12 AM
40 thou over
#3 S pack
  • 15,727 posts
Posted 29 September 2016 - 12:58 AM
RA2027 040 T0P 001 CE
#4 _bilby64_
_bilby64_
Posted 29 September 2016 - 01:23 AM
Thank you and would that the same for the 5 Pistons.
Bill.
#5 warrenm
warrenm
  • 2,118 posts
  • Car:1972 LJ Torana
Posted 29 September 2016 - 06:48 AM
Should be .040" over for all pistons, unless someone has done a dodgy job. Clean the tops of the other pistons to see.
#6 yel327
  • 13,658 posts
Posted 29 September 2016 - 08:30 AM
Bill
It looks to me like someone has replaced a busted 186 piston with a 40 thou over 186 piston as a cheap job.
202 and 186 use an identical bore but 202 has a longer stroke with the same rod length hence the pistons are not interchangeable. Every other Holden red-blue-black 6 from 130ci to 186ci shared the same stroke and used a bigger bore but 202 is the only one where the stroke was increased. So for example a 179 is a 173 +0.0625" (or 1/16") bore, a 186 is a 179 +0.0625" bore.
Also tagged with one or more of these keywords: 186, pistons, sizes, 202
