Hi I hope this is in the correct section.
I have been gathering information about removing the motor 253 and auto gearbox by dropping the K frame for an upcoming paintjob. The air-box will be changed back to its original one for air-conditioning so no way the motor will go back from the top. I just want to know if I have a all the information required.
I remove the radiator ,transmission lines, wiring, steering, exhaust, tail-shaft speedo cable, cross-member ,brake lines. What else?
I then get the rear higher with ramps or simular. I undo the 6 bolts ? holding the K frame in place and lift the front of the car high enough to remove the K frame, motor and gearbox.I think it would just be reversed to replace it?
This is a project myself or girl have never done this before but never afraid to have a crack.Any information or tips would be appreciated as I have gathered lots of small bits of information from several different sources and like to what to ensure I am on the right track.
