XU1 Swaybar Clamp
94 replies to this topic
#76 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 13 July 2017 - 10:35 PM
Correct, Lovells didn't make anti-sway bars. As I have told you before, Lovells branded anti-sway bars were made for them by Selby's.
The V8 XU1 (XW7) was to be equipped with the normal 82911 front anti-sway bar and no rear bar.
The front anti-sway bar that is currently fitted to 24C is not the anti-sway bar that 24C would have raced with.
As i told you before, Selby's and KMAC were the only Companys making Sway Bars for Torana's in the Early 1970's as told by the Selby's Family and Lovells ONLY made Coils in that time frame. The blue on my front sway bar is not the same blue as the blue on Lovells Coils. Selby's family said it is one of there front sway bars.
The 82911 front sway bar is not listed FULL STOP in the XW7 stuff, The V8 LJ Homologation Papers were never sent into CAMS but were done, 24C has the same front sway bar as my GTR, i was told that 24C used that Selby's front sway bar at the start of the 1973 season when Sway Bars were Free under Group C Rules.
#77 S pack
  • 15,717 posts
Posted 13 July 2017 - 10:57 PM
The normal 82911 anti-sway bar was not listed on the XW7 EPL because it didn't need to be. If a part is not on the EPL means it didn't vary from the part used on the normal model.
#78 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 13 July 2017 - 11:19 PM
The Heavy Duty 308 V8 Clutch and Pressure Plate and Rat Trap is not listed FULL STOP on the XW7 EPL list as well, must of been going to use Fresh Air as a clucth and pressure plate to change gears in the XW7.
Edited by xu2308, 13 July 2017 - 11:22 PM.
#79 meanmachine72
meanmachine72
  • 2,036 posts
  • Name:Jono
Posted 14 July 2017 - 08:13 AM
talking sway bar clamps here so stop your spamming the thread..you had your chance for a show and tell yet your still hiding it...start a new thread al and put up proof or shut the frock up
Edited by meanmachine72, 14 July 2017 - 08:15 AM.
#80 S pack
  • 15,717 posts
Posted 14 July 2017 - 11:46 AM
Funny then that Brocks #1 XU1 at Bathurst 1973 is not sporting a Selby front sway bar.
#81 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 14 July 2017 - 02:47 PM
Sway bars were Free for 1972 Rules and 1973 Rules as I Checked the CAMS Rules :)
24C is not the Brock Car and the Brock No.1 1973 HDT LJ XU1 had a Front Sway Bar it is still on the Car :)
Edited by xu2308, 14 July 2017 - 02:48 PM.
#82 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 14 July 2017 - 02:51 PM
We are talking sway bars :)
#83 S pack
  • 15,717 posts
Posted 14 July 2017 - 02:53 PM
Better check the rules again. Anti-sway bars and springs were not free in 1972.
Brocks #1 car at Bathurst 1973 would have had a front anti-sway bar but it is not the type you have on your SMP GTR.
Bonds #24 car at Bathurst 1973 also did not have a front anti-sway bar like yours.
Edited by S pack, 14 July 2017 - 02:54 PM.
#84 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 14 July 2017 - 02:56 PM
Sway Bars were Free
Check the Rules for 1972 and 1973 Group C
They had Sway Bars, No.1 HDT LJ XU1 still has the front sway bar on it
#85 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 14 July 2017 - 03:14 PM
24C front sway was the same in Early 1973. And then the last half of the year they did changes for the last half of the year to Shocks and Coils and sway bars to the 1973 HDT LJ XU1's.
Edited by xu2308, 14 July 2017 - 03:16 PM.
#86 S pack
  • 15,717 posts
Posted 14 July 2017 - 08:44 PM
Sway Bars were Free
Agree, under Group C rules sway bars, springs and shock absorbers were free however, under Group E rules only shock absorbers were free.
#87 S pack
  • 15,717 posts
Posted 15 July 2017 - 09:06 AM
The same front bar as used in '72 or the same front bar as the front bar fitted to your SMP GTR?
#88 S pack
  • 15,717 posts
Posted 16 July 2017 - 10:37 AM
Neither are hundreds of other parts that would also be needed to build a completed 82911 with RPO XW7.
Were they going to use fresh air for those parts also?
Perhaps they could have used real buckets in place of bucket seats.
#89 S pack
  • 15,717 posts
Posted 18 July 2017 - 08:27 PM
This one?
#90 Potta
Posted 18 July 2017 - 11:44 PM
Can you buy aftermarket clamps for aftermarket bars?
I have a big fat whiteline bar that I would like to put on the GTR but have no clamps, and it doesn't taper at the end like the stock one.
Also does it attach somewhere in the middle?
Maybe Al could put up some pics of his so I can see?
#91 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 19 July 2017 - 06:43 PM
Hi Craig, i can't remember if whiteline will do the brackets separately for their bars, if you have a contact at repco, they deal with whiteline so they should be able to ask, may take a couple of hours to get a response, they make good quality parts though. Gary
#92 Potta
Posted 22 July 2017 - 11:54 AM
Thanks Gary, when I forget that I'm never going to Repco again I will ask.
Although judging by the service I got last weekend those kinds of questions could get me killed lol.
#93 lx308
lx308
  • 2,843 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 22 July 2017 - 12:50 PM
A photo would probably help them out heaps Potta!
#94 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 28 October 2023 - 03:59 PM
Thanks Bazza, however I feel I should inform you the torque specs quoted in the above article were again revised during LJ production plus measurements were also published for the positioning of the stabilizer bar and clamps.
Holden's have informed me they will sue me if I publish this information without their written consent. :)
Hi Dave, are you able to PM me the LJ Front Stabilizer and Clamp positioning measurements.
Jaso :)
#95 S pack
  • 15,717 posts
Posted 28 October 2023 - 07:41 PM
Jaso :)
Jaso, I shall make it so. But not tonight.
