Interpreting Holden documentation ?
210 replies to this topic
#176 _ChaosWeaver_
_ChaosWeaver_
Posted 20 January 2017 - 05:18 PM
And this again.....    You all can see what is written here...   And I see no reason,  not to believe what is written here, if where to take people at their word ..
*  Revised crossmember to clutch to clear starter motor – lip removed on passenger side strut...
These are the listed 35XW7 (Export Vehicle) Spec's ......  If anyone was serious about proving what they are saying is legit, they would provide pics of the below changes to their car ?...
TORANA XU-2 SPECS ENGINE
  • 308 ci engine
  • Rochester carburettor
  • Revised brake booster support
  • Revised throttle linkages
  • Revised pistons and rings
  • Revised connecting rods and bearings
  • Revised exhaust ports
  • Revised valve springs (chev PN 3927142)
  • Revised cylinder case
  • Revised main bearing caps
  • Studs and nuts used instead of three centre main bolts
  • Windage tray fitted to main cap studs
  • Revised main bearings
  • Revised crankshaft
  • Oil pan sectioned to clear front crossmember assembly, ears added to maintain capacity (3.9 litres), drain relocated to rear lower part of oil pan
  • Revised oil pick up
  • Revised intake manifold
  • Revised fuel pump
  • Revised fuel lines
  • 2 into 1 exhaust system with resonator at the front, a Y junction and a standard XU-1 muffler
  • Revised water pump rotor
  • Revised rocker covers
  • Revised flywheel
  • Engine mounts with 100-thou spacers
  • Revised camshaft (PN 2825910/1)
  • Relocated 35 amp alternator (driver side)
  • Revised splash guard
  • Revised radiator and cap
REAR SUSPENSION
  • Revised upper and lower control arms
  • Harder bushings
  • Revised springs
  • Revised springs and shock absorbers
  • Revised shock absorbers
FRONT SUSPENSION
  • Revised crossmember to clutch to clear starter motor – lip removed on passenger side strut
  • Revised springs
  • Revised bump stop and rubbers
  • Reinforced lower control arm as per XU1
  • Revised wheel alignment settings
  • Revised upper control arms (bushings) assembly. Revised attachment bolts
  • Brake disc 60-thou thicker than XU-1
  • Revised disc calipers for thicker discs
Search for:   Holden Torana The XU-1 File
Compiled by George Nolevski © 2001
For more information email:[email protected]
#177 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 20 January 2017 - 07:51 PM
Chaos
Remember Pre-Production Cars are Different to the Final Road going car that is built from the Engineering List, Like  GT 001 that Larry mentioned is different to the road going GT that was made, Perfect Example.
#178 S pack
  • 15,723 posts
Posted 31 January 2017 - 10:05 PM
Chaos
So exactly what is your car Allan? Is it an engineering hack, a mule, a prototype, a pilot or a pre production vehicle?????
#179 rodomo
  • 18,038 posts
Posted 31 January 2017 - 10:21 PM
The real deal.
#180 S pack
  • 15,723 posts
Posted 02 February 2017 - 04:48 PM
Now where i am not wrong on it, i will explain
The XW7 Engineer said that they EXC the 6 Cyl Clutch Pedal and 6 Cyl Rat Trap
then they EXC the XW7 Clutch Pedal and the 6 Cyl Modified Rat Trap that they did Due to Components were breaking, Due to the 308 in the LJ GTR's had a Heavy Duty Clutch and Pressure Plate that Harry wanted in the GTR's, so then they made up a Hybrid HT/HG rat trap to fit in the GTR's, Now this Rat Trap was under test at the Proving Ground (That is why its called the Proving Ground).
There was ment to be a Revision Drawing done for this, but they had not done it at that stage due to more testing was needed, and then the Program was Stopped by Bill Gibbs and the Revision was never done
He also said if you look in the XW7 Parts List the Heavy Duty Clutch and Heavy Duty Pressure Plate was left out and the Clutch Pedal and Rat Trap, these were left out Due there was going to be a Revision on them as they were under test.
Revisions can be Added just before production and during production and after production.
The Engineers name and contact details or ^^^^^ is just psychobabble.
The parts you talk about would have been tortured and proven on test rigs at the Holden Tech Centre for days on end before they would have had any chance of seeing any action at Lang Lang.
#181 rodomo
  • 18,038 posts
Posted 02 February 2017 - 10:40 PM
That's a touch harsh Dave?
#182 u1 71
u1 71
  • 477 posts
  • Name:peter
  • Car:torana
Posted 05 February 2017 - 11:53 AM
Would Barneys shirt be part of the XW7 project and if so would it have the revised clutch pedal ?
#183 LC69GTR
LC69GTR
  • 2,761 posts
Posted 05 February 2017 - 07:14 PM
:fool:
Edited by LC69GTR, 05 February 2017 - 07:15 PM.
#184 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 08 February 2017 - 01:21 AM
Laz, I was told Santa was real too .................   But when I asked for proof, I got told,  if I persist with the questions, no more presents...  So I stopped asking questions....   But they never really proved Santa was real either ...
​Guess your Parents never knew of the Real Santa ?????? Saint Nicholas. There was a Santa :)
http://news.national...s-st-nicholas/
Chaos
Larry owns a HDT LC XU1 Torana (Saggy Sarah) and he has spoke to all the Players of the Day about Saggy and they have told him what they ran in the day. Larry's good friend owned 24C HDT LJ XU1 as well, so i think he would have a big handle on what went on from speaking to them Players at HDT.
Edited by xu2308, 08 February 2017 - 01:50 AM.
#185 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 08 February 2017 - 01:46 AM
Dave D
You went and seen Ben that Runs HHS, and Ben has told me what HE TOLD YOU.
So you know what MY GTR was, as Ben explained to you what it was, One of the Three LJ GTR's that Holden Experimental Engineering put the 308 V8's in.
You only took notes and do not have any of the XW7 Drawings or XW7 Engineering Parts List at all. As Ben would not let you have a Copy of them, Ben got the XW7 Drawings from me, the XW7 Engineer that gave them to me does not want them Public at all and i respect his wishes.
I will not tell you who the XW7 Engineer is ever, He must be real cause how did i get the XW7 Stuff, or Did Saint Nicholas drop them off at Xmas time :)
#186 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 08 February 2017 - 02:46 AM
You will never get his Details Dave D
You never worked at Holden Engineering Dave, i didnt work there as well, the XW7 Engineer did and he knows what went on.  You didnt.
Edited by xu2308, 08 February 2017 - 03:13 AM.
#187 S pack
  • 15,723 posts
Posted 08 February 2017 - 07:47 AM
One day I will find out who it is but I won't name him on the Forum however I will PM you so you will know I know. :)
#188 S pack
  • 15,723 posts
Posted 08 February 2017 - 07:59 AM
What about the selection of drawings published in Torana Tough? Did you disrespect his wishes when you gave Norm those drawings to include in the book?
#189 Redzone
Redzone
  • 517 posts
  • Car:Mini torana's - Gemini coupe 10.787@123mph, log booked Group A DOHC Gemini under resto..
Posted 08 February 2017 - 09:40 AM
From what i know about it, engineering hack, mule and prototype sum up what it was?
#190 _ChaosWeaver_
_ChaosWeaver_
Posted 08 February 2017 - 05:05 PM
How can it be a "Protype"??? ...............
NOUN
  1. a first or preliminary version of a device or vehicle from which other forms are developed:
    "the firm is testing a prototype of the weapon"
Engineering hack, most likely ...
Just my guess on things..  If Holden were building 3 V8 LJ Torana's .....  My guess would be that 2 would have been developed as race car's for their debut at Bathurst.  The other one would have been developed as a road version..  Not saying i'm right, or even that I have a clue, but it does kind of make sense to me...
And again only my guess,  but when the V8 LJ program was dropped, Holden engineering would have unbolted the whole front end assembly (and all the v8 modifications) engine and all as one item.   And then refitted a complete 6 cylinder front end motor and all.  It is the easiest and quickest way to do it...
That is why Al may or may not have any of the modifications that were engineered into his car at Holden ...    Just guessing, so no need for any tantrums ...
#191 rodomo
  • 18,038 posts
Posted 08 February 2017 - 08:34 PM
The three of them would have been engineering hacks. One had duel fuel fillers. Doesn't make any of them a lesser car to what they are.
#192 S pack
  • 15,723 posts
Posted 08 February 2017 - 08:37 PM
Allan says two of them had the twin fillers, the orange car and the pink car but only the orange car had the 36gal fuel tank.
#193 rodomo
  • 18,038 posts
Posted 08 February 2017 - 08:42 PM
Woteva.................they were all engineering hacks................that's how prototypes go.........just look at the gear shifter holes.
#194 _ChaosWeaver_
_ChaosWeaver_
Posted 09 February 2017 - 06:11 AM
This is a prototype ....  Not some 3 year old Torana coupe with a hacked out gearbox hole, and hammed down suspension lips .......
#195 rodomo
  • 18,038 posts
Posted 09 February 2017 - 10:24 AM
https://en.wikipedia.../wiki/Prototype
I noticed in that clip it was spoken a lot by Aussies and they referred to the car as a 4 door coupe.
Edited by rodomo, 09 February 2017 - 10:29 AM.
#196 Shiney005
  • 9,599 posts
  • Car:Toyota Mirai
Posted 09 February 2017 - 11:25 AM
 4 door coupe.
Hopefully, we will never see those words in Holden documentation.
#197 S pack
  • 15,723 posts
Posted 13 February 2017 - 11:10 PM
There was no revised clutch pedal. The normal LJ 6cyl clutch pedal and clutch actuating mechanism is what the V8 LJ was going to use.
#198 S pack
  • 15,723 posts
Posted 17 February 2017 - 06:00 PM
sloper35
  • photo-thumb-10516.gif?_r=0
Posted 14 March 2012 - 03:04 PM
The only Engineering aspect that was not fully engineered at the time of the programs cancellation was the fuel system. The tank was designed and fillers had been fitted to the three prototypes quarters but the bits between the fillers and tank was missing.
Edited by S pack, 17 February 2017 - 06:00 PM.
#199 rodomo
  • 18,038 posts
Posted 17 February 2017 - 08:16 PM
Why have you only underlined part of that statement Dave?
#200 LC69GTR
LC69GTR
  • 2,761 posts
Posted 17 February 2017 - 09:41 PM
