Anyone looking for some milling work?
Needs to be made from 6061 alloy, prob a 30 mm x 65 mm x 178 mm billet or larger. More details / drawing on request.
prototype1.JPG 41.22K
7 downloads
prototype2.JPG 58.36K
6 downloads
Posted 13 January 2017 - 08:03 PM
7 downloads
6 downloads
Posted 13 January 2017 - 09:26 PM
Why bother when a similar thing is available off the shelf?
Posted 13 January 2017 - 09:58 PM
Posted 13 January 2017 - 10:17 PM
A commodore bracket is available off the shelf
Assuming your thinking CP5200 AP style calipers
But not a HQ/Torana style bracket
Posted 13 January 2017 - 10:45 PM
If there is an off the shelf bracket to suit a LH torana with cp5200, I would like to know where ...
Posted 13 January 2017 - 11:17 PM
Nope
Never made one or come across one
To suit 330mm disc ?
Theres a few kits around people have made for themselves... but they all use different stubs
Torana, HQ, CRS dropped
Posted 13 January 2017 - 11:35 PM
Yes to suit a DBA 046, stock LH stubs and steering arms.
Would make it myself if I had the mill, the stock (and the time!)
Posted 14 January 2017 - 12:59 AM
I usually make them out of wood
Trim and trial fit alot till they are right
Then take the sample to an engineer and price it up
Haven't had to do that for 10 yrs though... so not sure who could help locally.
Posted 14 January 2017 - 10:45 AM
Yes I roughed it out with a wood sample, with the caliper clamped around a 2.5mm shim and the stub fixed in place. I'm told I can get a prototype 3D printed in Asia for about the same price, delivered, as the router bit and the wood stock!
20170113_154236.jpg 91.54K
7 downloads
I'm going to try and mount leading side, too high up and perhaps hits UCA, too low and hits the steering tie rod. On LH (at least my stubs) the caliper mounting holes are not level with each other, perhaps because one has to mount the dust shield. Will need to include that in the bracket design rather than sit a washer in there.
Posted 14 January 2017 - 03:36 PM
Posted 14 January 2017 - 05:57 PM
Yep HSV used a few setups
All lug mount not radial
C4
c4b.jpg 20.01K
4 downloads
c4b1.jpg 19.25K
4 downloads
c41.jpg 24.92K
3 downloads
C5
c5b.jpg 20.84K
3 downloads
c5b1.jpg 19.71K
3 downloads
c52.jpg 17.84K
5 downloads
Then the AP.. but the AP bolted straight to the stub as it was a lug mounted caliper not a radial also
Posted 14 January 2017 - 07:26 PM
Just to clarify. If you want an adapter to mount AP or Brembo calipers that are radially mounted AND with a 152mm between the centres to bolt up to a stub axle that has 3.5" mount (just like HQ and Torana), then they are available off the shelf. Have been for years.
Posted 14 January 2017 - 08:47 PM
And who has such brackets available ?
Posted 14 January 2017 - 10:55 PM
I've been told UPC quoted "from $3500" for a kit to suit LH Torana
Hahaha no way you could trust that to fit first time given the reviews out there
Posted 15 January 2017 - 02:29 PM
Details of the bracket:
Untitled.png 303.57K
6 downloads
Available here from Summit:
https://www.summitra...-6309/overview/
Posted 15 January 2017 - 02:57 PM
ewww...wilwood
Posted 15 January 2017 - 03:51 PM
Thanks for the suggestion although I think that particular bracket is too short radially for a 330 mm disc (instead of 28.9 mm should be around 45 mm), and the axial offset is out by like 5 mm (instead of 6.6 mm should less than 2 mm).
Posted 15 January 2017 - 07:26 PM
ewww...wilwood
Have you used them?
Posted 15 January 2017 - 09:37 PM
Not those actual brackets
But I have in a past life used wilwood products
Or better yet... removed and thrown in the bin wilwood products and fitted better stuff
For budget gear and visual wank they are ok for some applications
But I personally wouldn't use their products
Posted 16 January 2017 - 01:19 AM
But those brackets may be fine and if nothing else could be used for a test fitment to get a "proper" bracket made? I think it would be better to get a bracket made using that as a sample, as you would then know what fine tuning would be needed. It wood be more expensive than your block of wood method, but a lot quicker.
Posted 16 January 2017 - 04:20 PM
Out of curiosity Neil, what is your preferred metal for making caliper adapters with?
Posted 16 January 2017 - 08:04 PM
Just stick with the light weight balsa
6061 or 7075 if the guys got lots of money
Posted 17 January 2017 - 02:10 AM
Damn, why don't they make a 3D Printer that squirts molten alloy?
Posted 17 January 2017 - 08:28 PM
You can do something akin to Powdered Titanium from a 3D printer...
Posted 21 January 2017 - 09:51 AM
Holden Tech →
Driveline →
Hydraulic clutch conversion, how long is weld on tab for pedal?Started by fuzzypumper , 24 Oct 2020 ![]() |
General →
General Discussion →
What suspension set up is this.Started by _Daryl34_ , 20 Jun 2019 ![]() |
Holden Tech →
Electrical →
Where does this part fit? SLR ClusterStarted by _Eagle75au_ , 22 Apr 2018 ![]() |
General →
Business Discussion →
Zinc plating in SydneyStarted by Toran the Carbarian , 19 Apr 2018 ![]() |
Holden Tech →
Brakes, Wheels and Tyres →
Willwood Caliper SetupStarted by _HDT05_ , 03 Aug 2017 ![]() |
