commodore trimatic? selector shaft/linkage into a torana lx help needed
12 replies to this topic
#1 _livo74_
_livo74_
Posted 01 February 2017 - 07:56 PM
i think my cars got a vb commodore auto. i believe the selector shaft/linkage is on the passengers side of these.
i seem to have the right tbar for it.  was given it loose with the car.
but when i ebay search for a vb commodore linkage/selector shaft .. zero come up. even in completed listings. ??
asking for little info/help on why i cant find one? lots turn up for hq's lx's etc:)
___________
info posted earlier
seems my my motor and trimatic are from a vb
engine prefix "vr", with early number.
and "K O" transmission prefix
info found..
===VB Commodore (Series 3 Trimatics):===
KO 253 (4.2L) V8
#2 yel327
  • 13,572 posts
Posted 01 February 2017 - 08:06 PM
Yes, that is a HQ-HZ TH400 T-bar which will shift the LH shift trimatic. Just look for a RH shift trimatic rod and the shifter selector that bolts top the box and swap it over to the left (may have to bend it slightly), or if not get one from a UC 6cyl Torana with T-bar as these were mostly left shift and the T-bar itself is all but the same except for the stuff at the top to hold the shift indicator. VB Commodore T-bar looks very different.
Give Greg at Classicozwreck a call, he'd probably have what you need. Also grab the wiring harness too, it'll plug straight into your harness.
#3 _livo74_
_livo74_
Posted 01 February 2017 - 08:15 PM
ok, search i did seems to show up linkages now
http://www.ebay.com....hifter&_sacat=0
am confused, my shifter does not seem the same as vb commodore ones??
do i want a torana linkage or commodore?? aargh!
here is the vb shifter/linkage example from ebay
#4 _livo74_
_livo74_
Posted 01 February 2017 - 08:21 PM
cheers yel! was typing up my post and didn't realize you left info. and found on my search what you were talking about with the difference!
was puzzled and about to buy ALL the wrong things.
and i need a harness to so will be sure to ask greg
muchos gracias!
#5 yel327
  • 13,572 posts
Posted 01 February 2017 - 09:34 PM
Search "Holden t-bar" on Ebay. There is a used loom on there for $77, plus a whole repro HQ-HZ TH400 shift rod and associated bits for $95. This gets you the trunnion and the rod, all you need is to find the shift plate if your box is missing it. The TH400 will do the job too but might need some bending - they are pretty easy things to make work, the rod is a simple attachement at the shifter, and the trunnion is adjustable at the box with the bolt holding the tension on the rod. Very simple setup. If you look at item 262831557673 you can see how the rod works (the shifter in the auction is a trimatic one for a RH shift despite what the ad says). The bolt head you can see in the trunion is what holds the shift rod in place, as you undo it, it allows the rod to slide in and out of the trunnion, set it up so you have all gears and do the nut up, simple as that.
#6 8BALL
8BALL
  • 187 posts
  • Name:..
  • Car:yep
Posted 01 February 2017 - 09:48 PM
Are you sure thats a hz th400 shifter?
They're cable from memory.
Not linkage.
#7 yel327
  • 13,572 posts
Posted 01 February 2017 - 09:56 PM
Not linkage.
No they are rod type from HQ-HZ. Only the Statesman ones are cable type (for less vibration). It can only be a TH400 one anyway as it is LH shift and the only LH shift boxes used in HQ-HZ are TH boxes. They are normally easy to pick as they have M40 or M41 written on them with Crayon, from memory pink or yellow.
Edited by yel327, 01 February 2017 - 10:00 PM.
#8 _livo74_
_livo74_
Posted 01 February 2017 - 10:09 PM
cheers again, yel:)
i think this is loom you mean.
http://www.ebay.com....IoAAOSwUdlWgJJ1
been wondering, do i need one with a "globe/lamp" to see gear selection at night?
have not been around a torana for twenty years and it's showing in my lack of knowledge, and car was basically an empty shell when bought it.
and think this is one you mean for $95
http://www.ebay.com....~QAAOSw6DtYV3K-
this linkage cheaper, still correct??
http://www.ebay.com....EIAAOSwKtlWsR5r
and i don't think??? i have the selector plate, will jump under car and have a look tomorrow
and haven't seen any of these shift rods in person but suspected could loosen and slide trunion.
can't find item 262831557673 yet
#9 yel327
  • 13,572 posts
Posted 02 February 2017 - 05:30 AM
That harness is missing the globe.
Yes cheaper one looks the same. This is how GMH did it and built hundreds of 1000's of them.
Just copy and past the number into Ebay search, and the t-bar comes up.
#10 _livo74_
_livo74_
Posted 02 February 2017 - 08:27 AM
here is the uc
http://www.ebay.com....bsAAOSwL7VWpWGD
here is the whole repro HQ-HZ TH400 shift rod and associated bits for $95
and here is the used one, shown on a rhs shifter
it doesn't "drop down" before going sideways, like one above.
http://www.ebay.com....EYAAOSw2GlXIybX
as they arent shaped anything like the UC, are you sure will fit? you mentioned might have to do some bending, which is no problem.
and as for loom
do i need a specific one just like the uc
when i search "trimatic loom" only these come up (all have the globe)?
http://www.ebay.com.... loom&_sacat=0
Edited by livo74, 02 February 2017 - 08:28 AM.
#11 _livo74_
_livo74_
Posted 02 February 2017 - 08:46 AM
(this search engine seems to have ALL available linkages)
http://www.ebay.com....orana)&_sacat=0
#12 yel327
  • 13,572 posts
Posted 02 February 2017 - 08:59 AM
The difference is the left side shift is different to right side shift. That UC one is left side shift. There will be slight differences due to the box shape on each side and also for the TH boxes. I used a UC shifter and rod in my HZ Overlander when I converted it from column to T-bar as I didn't want to use a console. It connected straight up to the TH400. I just used a vinyl boot around the whole thing that I had fabricated. The UC harness plugs straight into the HZ harness.
For the harness you want a HQ to WB one or LH to UC.
#13 _livo74_
_livo74_
Posted 02 February 2017 - 09:49 AM
massive cheers! and sorry for repeated questions yel, just trying to get me head around it,
will call greg to check if has linkage and harness to bulk buy.
and typical, all those harnesses i link were unapplicable! ha!
