* * * * * 3 votes
Tonnys lx torana
119 replies to this topic
#51 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 27 November 2017 - 11:40 PM
The lh rear quarter I picked up is rough but I will atempt to make it work using the uc as repair cuts. It has had a previous dodgie patch repair in the wheel arch which I cut that out to see how bad it was, the whole repair will sit beneath the level of the flare.
Attached File  9A814566-B193-433C-93E6-78C9E7BBD4B9.jpeg   184.37K   18 downloads
Attached File  37A9FBC9-0AF9-4554-AE17-6F35B94A1FE4.jpeg   189.44K   15 downloads
Attached File  9681238C-8E4E-4640-846B-4462B9723CEC.jpeg   89.99K   15 downloads
Edited by Kantong, 27 November 2017 - 11:42 PM.
#52 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 27 November 2017 - 11:51 PM
Then I bolted up my wheels again for inspiration haha and hung taped on flares. The flares are borrowed L34 but I recon a A9x set on skinnier 265 tyres instead of 295s will be the go.
Attached File  AD09B765-E214-46E7-AAC9-CF1969C767F9.jpeg   217.19K   15 downloads
Attached File  E1888950-6CB8-4E85-B879-0E7B20576CA6.jpeg   236.43K   16 downloads
Attached File  B5127D04-D4E6-4CA5-AB37-7A27FE48C1D5.jpeg   109.78K   14 downloads
Attached File  B78A5255-0E2C-4DEB-BB5D-3F2441D862E2.jpeg   225.71K   14 downloads
Attached File  A0DF53DF-A556-447D-B60A-C56A0FBE1D47.jpeg   138.1K   15 downloads
#53 Heath
  • 18,403 posts
Posted 28 November 2017 - 10:29 PM
Awesome thread!
Hadn't spotted this until now. Love your work.
#54 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 03 December 2017 - 07:46 PM
Thanks Heath, if you have any tips or see something I could improve don’t be shy to let me know as I’m just winging it.
#55 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 03 December 2017 - 08:02 PM
Awesome thread!
Didn’t get much done this weekend but started on the quarter repair.Attached File  476DC1DF-7EEA-4A1B-ADEC-FB19E45AE4E9.jpeg   217.47K   11 downloads
I sandblasted inside and outside to get back to sold metal while keeping the inner structure as a reference for fit up.
Attached File  F8F695D9-F8E6-4BD5-9655-C4800FA4807D.jpeg   247.94K   11 downloadsAttached File  B8F496D5-F347-4748-9C00-1F53DDED38E4.jpeg   178.22K   11 downloads
Then started the fit up, you can see where the flare will sit on the top line and the lower line is what will be cut away once it comes time to mount the flares
#56 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 03 December 2017 - 08:13 PM
Attached File  D8B313BE-480E-42C5-BFE8-7DB177E8491A.jpeg   189.16K   11 downloads
Attached File  4834EEA8-FE71-4BCF-8D5A-348677079451.jpeg   177.52K   12 downloads
Attached File  25C96F8D-34BD-44D7-B132-66D37C976C89.jpeg   223.38K   12 downloads
As you can see if all goes to plan the flare will cover it all. Now to spend an hour or two getting the new panel file fitted up and then start slowly tigging it in. Fingers crossed haha
#57 _Potsie_
_Potsie_
Posted 04 December 2017 - 08:05 AM
What size are your wheels Anton? I'm looking at 15 x 8 for the front and 15 x 10 for the rear for my LX but have been told that the front tyres might rub on the arches, suspension, etc. Have you sought advice on this?
#58 myss427
myss427
  • 1,636 posts
Posted 04 December 2017 - 12:36 PM
If you are running flares, you can easily go 10 inch on the front with minor mods. Rolling diameter is the biggest hurdle.
#59 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 04 December 2017 - 12:48 PM
#60 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 04 December 2017 - 12:55 PM
The Indy’s Ive got are 15x10s for the rear and 14x8s on the front all in Torana stud pattern. I’ve only looked briefly at the fronts but I assume they will be fine as these wheels came of a running driving lx hatch but I might investigate it further. At the moment I’m hoping to find some 15 or 16x8 Indy’s in hq pattern for the front ready for a brake upgrade anyhow.
#61 CI 0308
CI 0308
  • 737 posts
  • Car:77 LX SS, VX SS
Posted 04 December 2017 - 03:47 PM
I have all but given up on running 15 x 10's on the front of mine as tyres arnt available that will fit in 15" size. you need something in a 40 profile that isnt available. Ill just stick to my 14 x 10's with 245 50 14 tyres.
Edited by CI 0308, 04 December 2017 - 06:27 PM.
#62 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 17 December 2017 - 02:38 PM
I got a bit done today, I got my new panel magnets from Eastwood which work great and are super strong so I gapped up the repair piece and got it in place file fit
Attached File  BE4AB528-39BD-4DDC-BF9B-3C584080A668.jpeg   202.58K   17 downloads
Then I grew some balls and Tig’d it in. I forgot to take photos of the process but I’m happy with how it came out. I tacked it in and then I fuse welded 90% of it in which worked well. Then spent and hour or so gently tapping, filing and sanding to get it right.
Attached File  D69A5CE6-AE25-4AEB-BE7E-B10F54CEB3C0.jpeg   168.51K   19 downloads
Attached File  4F1F7DF0-06A3-4A42-99F1-ACF2C8E5ECE1.jpeg   119.18K   15 downloads
Attached File  D6106DB5-386B-46C2-8858-0ED62A983EEF.jpeg   93.27K   15 downloads
#63 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 17 December 2017 - 03:06 PM
Then hit it with Matt black to check the body lines, I could tap it up further but it’s not crucial as it will all be either cut away or covered
Attached File  EA055FE4-29A4-49D1-8E70-6D0394F4C9E1.jpeg   201.33K   21 downloads
#64 Heath
  • 18,403 posts
Posted 17 December 2017 - 09:52 PM
Nice one. Did you planish the weld before it was fully ground flat?
I recommend doing that, and also putting a big radius on any corner where possible - you had a bit of a sharp corner there that could have been opened up a bit, which would have pulled a bit more gently during the process.
#65 Rockoz
Rockoz
  • 4,065 posts
  • Name:Rob
Posted 18 December 2017 - 09:13 AM
Reasoning behind planishing first?
Work hardening perhaps?
#66 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 18 December 2017 - 10:39 AM
Nice one. Did you planish the weld before it was fully ground flat?I recommend doing that, and also putting a big radius on any corner where possible - you had a bit of a sharp corner there that could have been opened up a bit, which would have pulled a bit more gently during the process.
Thanks for taking the time to give advice Heath, I need all the help I can get.
I did planish the tacks once it was in place to relieve the join but then from there I fuse welded it so I had virtually nothing to grind at the end, I just slowly bumped the low spots and spent a bit of time on that corner getting it right then tidied it up with a light file and sand. I’m not sure if this is right as my experience is purely trial and error and what I’ve read?
I definitely should have done that on the corner mate as that’s where I had to move the most metal, I can see how that’d help, it seems like an obvious tecnique now you have said it haha I will do that next time.
#67 Heath
  • 18,403 posts
Posted 18 December 2017 - 11:56 AM
As the weld shrinks as it cools, skillfully planishing the weld squashes it out a bit and relieves the tension. Also after welding the area will have pulled away from where the arc was, and this is a good opportunity to beat it back into line.
Don't bother trying to planish a MIG weld, though. The material is too hard.
Planishing the tacks is a good idea too, certainly can help with setup and get you out of a sticky situation when an edge is getting tight.
I normally use a little bit of filler material everywhere, and that does make it easy to planish. If you just fuse the parent materials, it won't be proud as you say. Is my suggestion better than what you're doing? I don't know. Not having to heat up the filler material means there'll be less heat in the job overall, that may be a minor advantage.
#68 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 21 December 2017 - 07:48 PM
Something terrible happened today, while moving things I sat the lower dash down, it slipped, it broke, I yelled....I can’t believe I buggered it up. My missus thought I’d hurt myself only to find it was this I was in agony over...
It’s a clean break, any ideas to fix it or someone who can as I’m fussy?
Attached File  4DCA82FF-2B96-45E8-8796-B155E9FDCFEA.jpeg   116.84K   11 downloads
#69 Ice
  • 15,221 posts
Posted 21 December 2017 - 08:08 PM
Bad place for a break find another one would be easier
Oh and love your work Anton
#70 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 21 December 2017 - 10:14 PM
Awesome fabwork Anton.your making it look
easy.
#71 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 23 December 2017 - 06:11 PM
Bad place for a break find another one would be easier Oh and love your work Anton
Yeah it sux, if repaired it will be right in front of my eyes behind the steering wheel, I think your right I’m gonna just have to hunt out another.
Thanks for the appreciation too Gene, it helps to keep chipping away.
#72 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 23 December 2017 - 06:17 PM
easy.
Thanks Maz, I appreciate the comments. I assure you it doesn’t come easy to me haha lots of reading before chopping
#73 gtrboyy
gtrboyy
  • 3,241 posts
Posted 24 December 2017 - 10:29 AM
Similar piece on my lc gtr was broken in 2 pieces like that luckily it was mostly hidden by steering column so I used araldite from inside where you cant see to hold it together with strength..wiped/dabbed the top part with a rag then when it all dried got thin tipped paint pen to blend in the crack.
Noboby spots it unless you tell them.
#74 Statler
  • 6,332 posts
Posted 24 December 2017 - 11:42 AM
The stainless gutter moulds on the parts car are desirable now.
#75 Kantong
Kantong
  • 96 posts
  • Name:Anton
  • Car:Lx
Posted 24 December 2017 - 12:58 PM
I think they were mostly damaged from memory but I might go back and have a better look now you mention it.
