GTR and XU1 verification thread
model identification verification vinplate Body identification
1964 replies to this topic
#701 S pack
  • 15,726 posts
Posted 22 August 2012 - 03:38 PM
Can someone please help my Toran has the following Tag numbers and I need help decyphering them
82911JL214533
LJ82911
960-A
1842-40
567-13884
G/day and welcome Jeff.
First of all this should have been posted in the GTR & XU1 Verification thread but seeing as your new here I think you'll be excused.
82911JL214533 relates to an Adelaide (Elizabeth plant) built GTR XU1 completed on 14/09/1972.
It was sold in September 1972 to Dealer 000X which is GMH Export.
960-A is the body number.
Trim 40X??? Black vinyl.
567-13884 is Chateau Mauve Metallic
There is no engine number listed as it was an export vehicle.
Note: It is one of 4 Adelaide XU1's that have consecutive VIN numbers that were completed on the 13, 14, 15 and 20 of September 1972 and all four cars were exported.
Dave.
Edited by S pack, 22 August 2012 - 03:42 PM.
#702 Dr Terry
Dr Terry
  • 3,325 posts
Posted 22 August 2012 - 04:43 PM
Note: ALJ######A = Model year1972 LJ Torana. It has been speculated the A & B prefixes are associated with the ADR's but I don't know if this factually correct.
Hi Dave.
The A or B (or C, D etc.) are quite definitely for the ADR groups. Each time during a model run that a new group of ADRs was introduced, the first letter of the chassis number is changed.
When the first run of any model series is released the number begins with an A, e.g. ALJ. When the ADRs were updated for Feb 73 (amber blinker, crash panels etc.) they used BLJ. When the next batch was introduced (ADR27 etc.) in Sept 73 the prefix changed to CLJ.
HQ & WB went all the way to EHQ & EWB. This was irrespective of either calender year & GM's model year.
Dr Terry
#703 _mikecatts_
_mikecatts_
Posted 22 August 2012 - 05:37 PM
Mike.
Betsbac 44203C0 reads as:
4 = 2dr S
4 = 138 ci 6 cyl
2 = M20 4spd (Aussie)
0 = No Power Steering
3 = Disc Front Brakes
C = 3.08 Ratio Diff
0 = No A/c
The Chassis No. code BLJ is B = Model Year 1973. LJ = Model code LJ Torana. The A at the end of the chassis number means Adelaide.
Even though the B indicates the cars model year is 1973, it is for all intents and purposes a 1972 model.
The model year changed in September each year (I think it was) however this is strictly a GMH internal operations thing and has no bearing or consequence on the fact the car was built in 1972 and is a 1972 LJ Torana.
The Chassis number on the Compliance plate should exactly match the number stamped into the left inner wheelhouse panel.
If the only difference is the letter C instead of J and the compliance tag says 'LJ 2 dr sedan' then I would say it is probably a factory stamping error and shouldn't cause any rego problems.
Hope this has been helpful to you.
Dave.
P.S: I'm sure Bazza will chip in if I have missed something or gotten something wrong.
Almost forgot: The file you want to look at on the Vin disc is coded (10). Mine is read in Adobe.
Thanks Dave..You gave more than I expected..
#704 S pack
  • 15,726 posts
Posted 22 August 2012 - 05:48 PM
Hi Dave.
Dr Terry
Thanks for that Dr Terry.
One slight error in all that, and call me anal if you want. The front indicator lens change from translucent to amber occurred during December 1972 production for the LJ and HQ.
Dave.
#705 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 22 August 2012 - 06:08 PM
Hi
+ BLJ went to the end of '73 because ADR27 came in on 1/1/74
Bazza
#706 S pack
  • 15,726 posts
Posted 22 August 2012 - 08:07 PM
Hi
Bazza
^^^ ADR 27 was legislated to come into effect on the 1/01/1974 however GMH introduced ADR 27 into production on the 1/10/1973 in line with their policy of making these type of production changes as early possible.
So, if the BLJ prefix continued until the 30/12/1973 then maybe the prefix is not linked to ADR changes???
Edited by S pack, 22 August 2012 - 08:08 PM.
#707 Dr Terry
Dr Terry
  • 3,325 posts
Posted 23 August 2012 - 04:50 PM
What I've noticed in most cases, is that the changes were made on the production line well before the relevant ADR made them compulsory.
AFAIK, BLJ began on 1/2/73 even though the amber lenses etc. came online a few months before. It doubt that a 12/72 build with amber lenses would have ADR6 on its compliance plate.
While on the subject of ADRs, it is common knowledge what changes were made to the regular 6 & V8 motors, as far as PCV plumbing is concerned, but what about GTRs. The last XU-1 was built before ADR27, but what about the stock GTR 202 motor? Did it lose its chrome air cleaner & gain the stock black one (with the snorkel). Or were there no ADR27 GTRs.
Dr Terry.
#708 Balfizar
Balfizar
  • 493 posts
  • Name:Chris
Posted 23 August 2012 - 05:26 PM
Dr Terry.
I believe ADR's mandatory compliance was based on delivery date, e.g. cars delivered (ex-GMH) after this date were required to comply. Therefore all stock holdings on non-compliant cars had to be depleted before the introductory date, hence the big lead-in time for production changes. The question is, were GMH delivery dates to dealers the cut-off or dealer sales to customers the cut=off date. It would make sense that dealer stock was immune to ADR changes, old unsold stock would have to be returned to GMH for modification or the ADR requiremnts (parts) shipped to dealers and then modified, and I see no mention of this in service letters to dealers. It may answer some questions for some non ADR compliant GTR's. But it would not be the first or last time I have seen non compliant items float out the door at GMH.
Balfizar
Balfizar
#709 S pack
  • 15,726 posts
Posted 23 August 2012 - 05:30 PM
Dr Terry.
AFAIK the LJ GTR's didn't have a chrome air cleaner like the LC GTR. They had all the standard 202 gear.
It is most likely all LJ GTR built on and after the 1/10/1972 would have had the closed positive crankcase ventilation system fitted.
The only engine that was excluded from the ADR 27 changes was the XU1 and there weren't many XU1's made on and after 1/10/1972.
Also if you read Mikecatts recent post in this thread you will find he has asked about a 20/12/1972 Adelaide built LJ Torana S which has a chassis number that is prefixed BLJ.
#710 S pack
  • 15,726 posts
Posted 23 August 2012 - 05:37 PM
Balfizar
Balfizar
Hmmm, from what I have read a vehicle has to comply with the ADR's that were in force at the time of manufacture.
Based on this I don't see why a vehicle that has a compliance date of say 6/73 would have to be updated to comply with ADR 27 if the dealer didn't sell that vehicle until say, for example, February 1974.
Edited by S pack, 23 August 2012 - 05:38 PM.
#711 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 23 August 2012 - 06:06 PM
Hi
I can't find any LJs with ADR27 on the compliance tag. The earliest "27" I can find is on an LH.
BTW I have lots of examples of LJs completed in early '74 with BLJ prefix. In fact I have only come across 2 CLJ prefixes.
Bazza
#712 Dr Terry
Dr Terry
  • 3,325 posts
Posted 23 August 2012 - 06:48 PM
I always believed that LJ GTRs, even though their engine was the stock 202, still had a chrome rocker cover & an open style chrome air cleaner, although the base was the single barrel type. The LJ GTR air cleaner that I've seen was similar to an LC GTR except it had the small hole at the rear for the PCV hose clip.
I realise that parts books are often not gospel, but M37608 (June 75) lists 2 types of 202 chrome rocker covers, one pre-ADR27 & one to suit ADR27.
Dr Terry
#713 S pack
  • 15,726 posts
Posted 23 August 2012 - 07:08 PM
^^^ Ooops, made a typo. Should read: 'and there weren't many XU1's made on and after 1/10/1973'.
Edited by S pack, 23 August 2012 - 07:08 PM.
#714 S pack
  • 15,726 posts
Posted 23 August 2012 - 07:37 PM
Dr Terry
This example appears to have a fairly original engine bay. First chrome LJ GTR air cleaner I've ever seen.
http://australianmus...1-lj-gtr-torana
#715 Dr Terry
Dr Terry
  • 3,325 posts
Posted 23 August 2012 - 08:16 PM
I do know of several original cars, that's why I didn't doubt the fact that the LJ GTR air cleaner top was the same style as the LC GTR. What I was asking, given that the parts catalogue lists a chrome version the ADR27 rocker cover (3 hole HJ/LH type), where did the PCV return hose go to ?. They must have used the black snorkel type air cleaner for those few that were built. If in fact they do exist, they must be the rarest of all LJs.
Dr Terry
#716 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 23 August 2012 - 09:03 PM
Hi
Only 2 LJ GTRs completed in 1974 - 1 in Adelaide on 15/1/74 the other Brisbane 16/1/74. Most LJ GTRs completed by mid Dec 1973. It is impossible to say why these 2 were so delayed, the PSNs are not in isolation but mixed up with cars completed a month earlier. My guess is that they wouldn't have been ADR27 compliant.
Bazza
#717 S pack
  • 15,726 posts
Posted 23 August 2012 - 09:05 PM
Dr Terry
The GMH Parts & Accessories News parts list covering the HQ & LJ positive closed crankcase ventilation changes lists the ADR 27 type chrome rocker cover for 82911 model with the notation 'excl XU1'.
There is no mention in this parts list of any special chrome air cleaner for the GTR.
The stock ADR 27 air cleaner is listed for 6cyl eng. 'excl XU1'
There were LJ GTR's made in and after 1/10/1972 and into early 1974, so they do exist, the question is what parts were they fitted with in regards to ADR 27.
Dave.
Had to edit this slightly
Edited by S pack, 23 August 2012 - 09:19 PM.
#718 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 23 August 2012 - 09:08 PM
Dave - see above
Bazza
#719 S pack
  • 15,726 posts
Posted 23 August 2012 - 09:20 PM
Dave - see above
Bazza
Yep saw your post Bazza.
#720 dattoman
  • 16,487 posts
Posted 23 August 2012 - 09:43 PM
Wrong thread for ID of tag numbers guys... would you like your own thread ?
#721 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 24 August 2012 - 12:03 AM
Hi
Bazza
Hi Bazza,5 GTRs in 1974 in adelaide 15/1 L258479,17/1 L258562,15/1 L258880,15/1 L258921 and 15/1 L258961.
cheers anthony
#722 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 24 August 2012 - 12:27 AM
Hi
Yup - my mistake - "More haste - less speed". My main point was that these cars were commenced much earlier, but for some reason weren't completed at the same time as their 'siblings'.
Bazza
Datto - I think this sub-topic has been done to death on this thread so perhaps needs its own.
#723 Dr Terry
Dr Terry
  • 3,325 posts
Posted 24 August 2012 - 08:29 AM
Hi
Bazza
It's highly unlikely that GM-H ever let a car out of the factory which didn't comply. I seem to remember that they had to go to all the trouble of making special bits for the 1978 LX Toranas for ADR25A (ignition lock). This was probably less than one month's production.
I've recorded a car where the chassis number was restamped at the factory from CLX.... to DLX.... made during this time.
Dr Terry
#724 _sunburst73-xu1_
_sunburst73-xu1_
Posted 24 August 2012 - 09:50 AM
I have a 12/72 LJ with a BLJ chassi prefix that has clear indicator lenses.
#725 Dr Terry
Dr Terry
  • 3,325 posts
Posted 24 August 2012 - 10:16 AM
Well that throws a spanner in the works. That one's got to be a mistake. It doesn't comply, yet has the BLJ prefix 2 months before it was required.
One other thing though. It's not just the presence of amber lenses (anybody could swap those), it's the extra wiring etc., for the parking light in the headlight which distinguishes the later cars.
Dr Terry
Also tagged with one or more of these keywords: model identification, verification, vinplate, Body identification
