Thanks for all the reply's, Here are some flow figures I have been able to compile, the first three sets of figures are from a cylinder head shop that posted them online,(I have adjusted the figures from 25" water as tested to 28" for the sake of comparison) The last two are my standard head test and the modified head test. My throat diameter (smallest diameter below the seat leading to the bowl) is probably a lot smaller than most using 1.68 inch valves at 1.42 inches but this, combined with the seat geometry is what makes it flow so well at low lifts. This will however start choking the port and limiting the outright flow above about 550 lift. The seat geometry is close to the picture below, I tried a lot of other profiles but this seemed to work best.
Clearly despite all of the pissing around the motor hasn't really gone that well, but I don't think there is a problem with the head, as TK383 has said it might just need a little more duration and tighter lobe centers to wake it up.
I am more than aware that there would be a lot of other combos making better power with less cam and less flowing heads (the HQ race engines are a good example) but without knowing the exact specs of the entire engine its hard to compare.
What hp figure could you gain from a decent balanced bottom end with tight clearances, low tension rings, thinner oil etc etc. 10-20-30hp?
Extractors over cast manifolds?
Delete the engine driven fan?
Setup a cold air box?
Insulate the carb from manifold heat?
If I can get to 150-160 with just a cam swap I would be pretty happy, and that's most likely what I will be doing.
