Bolting/welding an LX diff into thin air
5 replies to this topic
#1 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 06 March 2017 - 07:26 PM
The short story is I am doing some welding for an ex-forum member. The entire floor from the firewall to the beaver panel has to be removed. The sills may will probably have to go as well. This will be a competition car (maybe not competitive though), so it will be a six point roll cage welded to a 3/4 chassis with an LX body attached. So structural integrity of the shell isn't important. Where I would like to go next is the removal of the factory rear suspension and adjacent floor area. Once removed, we won't have anywhere to bolt a diff to. The car needs to be a roller at minimum at all times and if possible, drive-able as well.
Option 1: Use the LX banjo diff with the factory rear arms and make some brackets to weld to something. Remember, the floor and sills won't be an attachment option.
Option 2: The owner has the complete rear suspension and diff from an HQ/WB commercial. As the mount points for the leaf springs will be parallel to each other, it may be a simpler option.
But
what is the distance from the outside of one spring to the outside of the other? If it's wider than the inside of the B pillar, it could be very awkward.
Option 3: Insert idea here.
Discuss.
#2 _Bomber Watson_
Posted 06 March 2017 - 08:12 PM
Trailer axle?
Not drive able obviously but simple and cheap/free.
#3 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 06 March 2017 - 10:08 PM
That's not a bad idea. In fact, that gives me an idea for a variation on option 2 that would only require a couple of bits of scrap angle and possibly make it drive-able.
NB:
It only needs to be drive-able for the sakes of getting it onto a trailer, up a steep driveway etc. It won't need to travel any great distance or faster than walking pace.
#4 _Lazarus_
_Lazarus_
Posted 07 March 2017 - 02:04 PM
Go down to Bunnings and ask for some 50mm skyhooks.
#5 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 07 March 2017 - 05:01 PM
Drop it onto a sheet of 25mm plywood with rollerskates tekscrewed under it.
#6 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 07 March 2017 - 06:20 PM
After what you posted in this thread:
http://www.gmh-toran...-maths-problem/
I really shouldn't expect any better than that from you.
