transmission lines to radiator adaptors, help sought
14 replies to this topic
#1 _livo74_
_livo74_
Posted 01 April 2017 - 03:19 PM
howdy, just purchased a new set of transmission lines for my v8 torana
thought would save a lot of hassle and just bolt straight in.
so i go to install
and the thread is far to big
so i contact the seller and he says i am missing the adaptors
so i reasarch and found this "new radiator" for sale ad saying this..
"Designed with 1/2 UNF transmission oil cooler fitting to eliminate the 1/8 NPT male to 1/2 UNF female  Transmission line adaptor fitting. "
http://radiatordirect.com.au/HOL012PAT
anyone else have this trouble?
should i be trying to source the adaptors from..?? pirtek?
or ebay?
am sure will get thread wrong. !
might be these..
http://www.ebay.com....fYAAOSwB4NWxS8f
or just buying a whole frOcking new radiator
______
nor does the rear into transmission fit! aargh!!!
need these.. ish..??
arrghh!
any thoughts/advice would be much appreciated
mat
Edited by livo74, 01 April 2017 - 03:43 PM.
#2 dattoman
  • 16,485 posts
Posted 01 April 2017 - 04:13 PM
Finding some adaptors would be the easiest
Doubt its 1/5 npt though... thats the same thread as your temp sender... seems too small (about 9.5mm tapered thread)
Can the seller tell you the correct thread of the nuts on the pipes you bought ?
Then you need to identify the rad threads... do you have the old pipes ?
#3 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 01 April 2017 - 05:32 PM
basically the way i see it provided the flare nuts are the same size on each end , all you need is four original fittings  that screw into
the transmission , 2 go in the radiator and after you remove the nipples from the transmission the other 2 can be fitted to transmission?
#4 _livo74_
_livo74_
Posted 01 April 2017 - 06:19 PM
thanks datto, have just contacted seller to ask for threads info, awaiting response
as for 1/5, was just quoting what that radiator seller was stating theirs is/eliminates
no old pipes came with car unfortunately, would of used if could
#5 _livo74_
_livo74_
Posted 01 April 2017 - 06:24 PM
howdy eunuch,
fancy me needing to come on forum to ask for help! whoda thunk it, aye..?! hahaha
flare nuts on pipes are all same
and....
removed nipple out of trans... and... it fits the radiator hole/s!
so, you have given me a portable way of taking CORRECT size/thread with me to pirtek!
because..
" four original fittings  that screw into the transmission"
i wish! my kingdom for 4 of those
can't find ANYONE discussing here, or elsewhere
darn it
Edited by livo74, 01 April 2017 - 06:25 PM.
#6 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 01 April 2017 - 08:46 PM
The ones in the radiator are normally the same as stromber/Holley fittings/adaptors.
I found the adapters and a flared fuel line fitting with a barb at a local auto performance shop, then ran flexible lines.
The adaptors are often found to be brazed into the radiator as a result of a repair. Finding second hand ones is tough.
When you fit and remove the fittings I was advised to use a good ring spanner. Apparently they deform easy.
Lightly does it, so you don't damage anything.
Edited by Lc69, 01 April 2017 - 08:47 PM.
#7 _Bomber Watson_
Posted 01 April 2017 - 09:02 PM
The fact that your ebay seller lists a manual trans option for trans cooler lines indicates there probably not entirely onto it.
1/8" NPT is correct for the trans if your running a Trimatic, if that screws into the rad then thats good to.
1/2" UNF must be the thread on the flair fitting....
YOur first ebay search seems right, four of them should short you, but I may be wrong as i've never done what your doing.
#8 _livo74_
_livo74_
Posted 01 April 2017 - 09:15 PM
cheers tony and dj. will be careful removing if find second hands,
and hoping 1/8 npt and 1/2"unf indeed right. be darn nice to just add adapters and have lines sorted.
and certainly makes my job lot easier, that now can take my trans pipes and the nipple adapter with me when go to pirtek dandenong..
and know for sure have right parts, which can all just bolt together
#9 _Bomber Watson_
Posted 01 April 2017 - 09:46 PM
Welcome to the struggle, Its very rare something "just bolts up"
All I know is when I was running the braided hose for the trans cooler lines to my car I needed -6 to 1/8" NPT fittings to screw into the trans, im assuming V8 and 6 banger Trimatics have the same oil cooler fittings and if your trans fitting screwed into your radiator than it will be the same.....
#10 gtrboyy
gtrboyy
  • 3,204 posts
Posted 01 April 2017 - 10:14 PM
Commodores usually have those nipples at trans then small length of hose to steel lines back to radiator.
Must have been bad idea as next model change was steel lines from trans onto radiator with last bit hose for engine movement.
Commodore lines would have been too long & wrong side for your car anyway.
Yeah Bomber 6 & 8 supposedly same.majority of parts so they say & true whenever hearing 'bolts straight up' means some finesse' required haha
Edited by gtrboyy, 01 April 2017 - 10:18 PM.
#11 _Bomber Watson_
Posted 01 April 2017 - 11:37 PM
"Some finesse" = "some extra expenditure that we didnt tell you about but we can supply the parts that you didnt get because you didnt specifically ask for them, you should have known better"
:tease:
#12 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 02 April 2017 - 06:58 AM
So in the radiator you need something like this, with the flare on the female side to seal against the tube flare.
Thread seal this into the radiator.
http://www.ebay.co.u...sd=170474198890
The I used something like this and ran flexible lines: can get straight and bends.
http://www.ebay.com....N-/262335954715
They recommend double clamps when running flexinble lines.
You need to find yourself a good performance shop that sell carbs and fittings etc.
Then buy extra for next time, ha ha
I think I have one spare if you need a photo.
#13 _livo74_
_livo74_
Posted 02 April 2017 - 08:47 AM
heya gtr, my trans came from a vb/c commodore so had the nipples and short piece of hose at trans just like you say
and bomber, been copping a LOT of "finesse" and "bolt straight up" nonsense on my travels ;)
#14 _livo74_
_livo74_
Posted 02 April 2017 - 08:53 AM
been wondering out that, realized would at least need to make sure the pipe fitting butts up before it can screw in all the way, and a lot of teflon tape or goo.
proper grommet way seems even better, cheers for links to show examples
#15 gtrboyy
gtrboyy
  • 3,204 posts
Posted 02 April 2017 - 02:14 PM
Should be a tag on side of trimatic..will have codes on to tell you model/specs etc.
Found out my trimatic has silly 10 tooth drive gear grrr...finesse it with a sledgie one day....
Yeah reason for nipple & hose concoction is engine movement as commodore trans lines mounted to chassis rail.
