Fuels, V-Power quality?
fuel
16 replies to this topic
#1 _scoops_
_scoops_
Posted 26 April 2017 - 04:46 PM
Hi Everyone!
  I usually tank up with VPower at the Lygon st Shell station, but my last tank there resulted in pinging. Which was disappointing.
  Just wondering does anyone else find that fuels fluctuate in quality between pumps at the same pump station?
  Should I go down the path of adding octane boosters? Or try BP's 98 offering?
Thanks!
#2 _76lxJAS_
_76lxJAS_
Posted 26 April 2017 - 07:36 PM
Interesting u say pinging from fuel.
I always use BP and have some pinging also..?? Am waiting to take it to the dyno to see how all my timings are etc only as I can't be botherd changing distibutor weights etc.
#3 _Inj gtr202_
_Inj gtr202_
Posted 26 April 2017 - 08:47 PM
I once blamed fuel for pinging, I found that gradual oil/carbon deposits in the combustion chamber was the real cause. Oil was getting drawn in through the inlet manifold and causing the problem.... Just a thought as I was retarding timing to compensate until I found the cause.
#4 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 26 April 2017 - 10:47 PM
You never put Shell fuel in a motorcycle so why put in your car.
#5 RallyRed
  • 8,158 posts
Posted 27 April 2017 - 08:43 AM
I have found over the years that if ever a fuel was going to cause pinging...it is always..shell.
No idea why or how, as you'd have to imagine it would be tested pretty well before release into the truck at the definery?.......maybe they occasionally have a bad batch, and just trickle it into the good batches to get rid of it?
#6 Bigfella237
Posted 27 April 2017 - 09:41 AM
I avoid Shell fuel like the plague, every time I've had to use it over the years I've regretted it... pinging, surging, bad economy, frankly I don't know how the company is still in business, obviously most users are oblivious to what their car is doing, or just don't know any better? Or maybe I've just been unlucky enough to get a bad batch EVERY TIME?
These days I will drive out of my way to use BP Ultimate, or Caltex 98 in a pinch.
Also, if your car sits around between drives for any length of time you should stay clear of any ethanol content if possible, unless you're able to drain and flush the system with straight petrol before storage. Ethanol is hygroscopic (meaning it absorbs moisture), which is not that big a problem unless the fuel sits around for any length of time, then the moisture causes the ethanol to separate from the fuel it was suspended in, making it settle to the bottom of the tank with the petrol floating on top.
#7 _scoops_
_scoops_
Posted 27 April 2017 - 02:03 PM
Thanks for the posts everyone.
Agree most users would be oblivious as the engine management would compensate for crap fuel.
My engine is clean from deposits so it's not detonating for that reason.
Think I'll try BP ultimate and see how I go.
Does anyone know if the fuel is all shipped as 98 to the station or is it up to the guys at the pump station to put in the additives?
#8 Rockoz
Rockoz
  • 4,036 posts
  • Name:Rob
Posted 27 April 2017 - 02:28 PM
I was told by my dealer not to use BP in my bike.
Go figure
#9 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 27 April 2017 - 04:42 PM
Go figure
I don't use BP either In my bikes.
#10 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 27 April 2017 - 07:32 PM
Are you guys all running close to the ragged edge tuning wise? Maybe I've been lucky but I haven't had a problem with any of the 98 octane fuel offerings in the moderns or the old beasts.
#11 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 27 April 2017 - 09:03 PM
this...
#12 _Axewound_
_Axewound_
Posted 27 April 2017 - 09:11 PM
Knock knock
who's there? Sensor
Sensor who? Knock sensor...
Maybe back off the timing or add an octane booster and see how that goes, also ambient temperature and altitude plays a role in detonation too.
Sent from my Pixel using Tapatalk
#13 RallyRed
  • 8,158 posts
Posted 28 April 2017 - 09:19 AM
in my case at least...stock as a rock, over a number of years, same roads, same trips...and so on.
Other fuels all good.
Shell   =  ping. Not every time, but certainly a long term trend.
#14 _Axewound_
_Axewound_
Posted 28 April 2017 - 09:50 AM
Maybe its the nitrogen detergent additive they put into the V-Power that is causing the pinging.
#15 RallyRed
  • 8,158 posts
Posted 28 April 2017 - 10:16 AM
Ha ha....so clean its squeaking..not pinging
#16 _Axewound_
_Axewound_
Posted 28 April 2017 - 11:05 AM
Yep lol
#17 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 29 April 2017 - 07:40 AM
It seems to depend on where you live, in some regions they swear by BP, others by Caltex, etc. It's as if different refineries from the same brand around the country are putting out different product.
s
Also tagged with one or more of these keywords: fuel
